kcram - Pickups Host
I've posted me issue's numerous times, and have gotten no response, my Titan's differential has failed twice in twenty one thousand miles, anyone ever heard of this problem? I own the LE trim titan, 4x4, 6" lift, 35x18x12.5 tires and wheels. yada yada yada
Thanks..
Rickp :confuse:
Denis
Can anyone tell me where the transmission vent is located on this truck? or better yet, post a picture or diagram?
Brian
I hope maybe someone can help me with my 1995 Nissan pick up. I just bought it and it had no radio,,, so,, I decided to put 1 in myself. Well,, it has no speakers. the door panels aren't even cut out. I was wondering how to put in the right speakers since i cannot even get behind them to screw them in. Also,, i have 5 1/4 speakers and they seem a little small. If someone knows exactly what size and how to speakers please help me. Thank you. there must be some kind of addapter to mount the speakers in. I just don't know. Unless I do my own thing,, but i was trying to stay stock if possible.
Andy
Andy
I have a 97 club cab pickup. When it rains I get water sloshing around in my cab body, I can't see where or how its getting there. Has any one seen or heard of this problem? If so how do I fix this, I worry about rust from the inside. There is only the two side windows that open and the rear window, and they seem to be sealed. I'm open for suggestions..
Denis
Crawl under it and look for this around a small black cap that looks like a radio knob.
Andy
2001 Frontier SE V-6 4x4
Brian
Andy
Hey all!!
I have a 2000 Frontier SE V6 crewcab, with all options except 4x4, and it has 77k miles on it. Recently I have been noticing a pronounced squeaking noise at low-to-moderate speeds (anything up to about 50). Sounds like it might be the suspension/shocks, or it could be a wheel bearing? The squeaking occurs on seemingly smooth (concrete) road surfaces, as well as bumpy roads (concrete and asphalt). I don't know how long the squeaking has been going on, as I can only hear it with the windows rolled down, and have had them rolled up all summer with the A/C on.
Anyway, I'm not very mechanically minded, and so I'm not sure what it is, so if anyone else has any ideas or any similar experience, I'd like to hear about it. Also, is this a cause for concern? Should I take it to a dealer to check it out (they always seem to find something else major to do, which is why I'm wary of going to dealers), or could a mechanic fix it?
Other than this, I am very happy with the truck, and it is running great.
Cheers,
p22
It's located under the Intake manifold.
Anyone done this repair? Anyone know what gaskets will be needed?
Can anyone verify this?
How can I tell if mine if build after 5/05?
Well, i'm sure that whoever has an older pick up
must have had problems with the belt tension er squealing
from time to time. I have changed the 1 on my 1987 3 times and the 1 on my 1995 won't give me a break now either. These trucks are great except for 2 things. They rust terrible,, and the belt tension er squeals too much.
Other then that,, the motors Z24,, are great ! Can anyone help me with any new solutions?
High
Anyone else experiencing this problem?
High
High
