kcram - Pickups Host
Thanks :P
Can I reach the clips from under the truck like I can from under the hood, behind the grill?
Thanks for the reply.
Mine is an 06 rather than an 07, I miss-typed the message. I assume there the same.
Thanks for the help.
I'd never buy another Nissan again...
Comments anyone?
Cheers!
"The AC froze up again at the approx 60 mile mark."
What exactly happens to freeze up?
-Low refrigerant
-Insufficient airflow
-Ambient temperature too low
My guess would be the first one. You probably have a leak somewhere that they can't find so they keep changing parts and hopefully will eventually solve the problem. Not exactly the most efficient way.
Nope. Just open it up and look inside to see where it disconnected.
Pleased to this point.
Has anyone experienced a similar problem or know how to correct this problem? Is there something I still have overlooked? Thank you for your interest and any suggestions will be greatly appreciated.
Jim :confuse:
About 2 months ago I noticed that my heat would not warm up in my 2005 Nissan Frontier. I just hit 99k and I thought I had a thermostat issue however my local certified Nissan Dealer tells me different. They told me I have antifreeze in my transmission fluid. I was also told that one of the cooliant lines from the radiator probably has a crack in it and my transmission will soon go. I am starting to notice a little thump sound when I put the vehicle in gear. The Nissan dealer told me it would cost $3600 just for the radiator and new transmission. I know a guy that does transmissions and he said trans are expensive for these vehicles, so we are searching for a low mileage tran, its been 2 weeks and there doesnt seem to be anything available. The Nissan Dealer kind of slipped up when I asked how did you know to look at my transmission, and she said "oh we have been seeing alot of these lately". I asked: so you are seeing this in Frontiers and she said "no many different Nissan models with the same issue, it usually starts with the heat going out." So you may see your heat go out next. It apppears we are in the same boat here, and I would definitely like to stay in touch with you. Due to the age of the vehicle I will be surprised if you can get Nissan to pay for this. Let me know how you make out. Thanks
Raybestos.
Don't know about anyone else but I switched to ceramics on my '91 with no rotor issues. Also switched to ceramics on my '05 Titan at 300 miles cause I couldn't stand all that black dust. Now at 60K miles and no rotor issues. (never had the recall done either) seems the solution to the warping rotors was replacing with ceramics as they generate far less heat than the semi metallic.
