Low on power & pinging
Within the last three weeks, My 98 chevy ext-cab Z-71 with 33,500 miles has lost power and is now pinging under load. I changed the fuel filter to no avail. Checked spark plugs but they were still good. I checked for vacumn leaks but couldn't find any. I checked fuel pressure and at idle it reads 54psi. I reved it up real quick and it goes to 62 psi, than drops back to 54psi. When you partially turn key to activate fuel pump it goes up to 61 psi and than drops down. Factory helm service manual says fuel pressure should be 60-66 psi with pump on and motor off. Says it should jump up to about 66psi when you rev the motor real quick. Mine only goes to 62psi. Could I have a fuel pump problem? My pump has also gotton alot quieter than it used to be. Can anyone tell me what elso I should look at to fix this problem? I do not get a SES light and no codes are stored on the computer. No misfires or anything. Truck feels like it has a restriction. You give it gas but it hardly picks up any speed. Gas milage has also suffered. Thanks for any ideas.
Wayne
Wayne
Did you go though the troubleshooter diagnostics in your Helm? I had the same problem, but I was unable to connect a fuel pressure guage to the return line, so I rigged up a rubber hose to the fuel pressure gauge, I dropped the gas tank and connect the other of the rubber hose to the out pipe of the fuel tank. My problem was a bad fuel pump. It was under warranty, so no problem.
My fuel pressure is regulated by the need of fuel. My Helm book informs me that deviation of a few pounds is ok
You could have bad injectors. You need an injector tester find out. If your book tells you that one of the problems could be a leaking injector and that you need to pull all of them out by the rial, turn on the key, and see if any of them leak, do this first, because this would point to your problem.
I don't know where you are at, but some places like Murray's rent them at no change.
What is your oil pressure like? It can affect your performance. You need to do the diagnostics.
MM--would you please not include your logo in all your posts? thank you!
Mr. Shiftright
I hope my post didn't infer that it would. It may or may not be one problem.
wtd - Have you checked for an exhaust restriction?
lean fuel mixture
EGR system malfunction
high compression ratio due to carbon buildup in combustion chambers
knock sensor malfunction
over-advanced ignition timing
high engine temperature
low octane fuel
Severe detonation WILL eventually blow holes through the aluminum piston crowns.
Harry
Getting to the fuel injectors on this truck is kind of a hassle since my intake manifold is a two piece affair with the fuel injectors and fuel regulator under the top section. With such low milage, its hard for me to believe that the injectors might be bad already. I havn't checked the fuel pressure since replacing the two O rings and gas cap so I don't know if it increased.
My air filter is brand new and I had the catalytic converters checked for restrictions which were not restricted. EGR valve checked out okay. Timing is non adjustable on this truck since it uses a cam and crank sensor to control timing. Knock sensor seems okay as it hasn't set any codes. There are no codes of any kind and the SES light has not come on.
I'm going to run a bottle of Chevron Techron fuel system cleaner through the next tank of gas and see what happens.
I still think it may be a fuel pressure problem, since the pressure is less at idle than the Helms manual says it should be. Fuel regulator may be not working right. Any other ideas?
Wayne
The O rings will not help your fuel pressure problem unless they were leaking. It could be a defective regulator.
Truck has again lost power, so I guess I'll have to try and get an injector and regulator test done. I'm getting pretty discouraged with this whole thing.
I have had the same thing happen to me on a Dodge van 318. Kept racking my brain took it in to a small shop they couldn't figure it out, took it to the dealer it was the ignition coil. After hours of time looking for the problem, and lots of money thrown at it, it turned out to be a simple $25 part. Wouldn't set a trouble code, and voltage tested fine, but it had a small crack in it, and when it warmed up it would arc to ground instead of the plug. Your problem may also be caused by a faulty ignition module, the one under the distributor cap, I had a Le Sabre do that to me once, but after a while it would stall out, and not re-start for 20 minutes.
Out of curiosity have you checked the Manifold Air Pressure and Manifold Air Flow sensors?
Other things to check are ALL ground wires, to the engine, frame, battery, and ECM. Knock sensor circuit. Charging System output. EGR valve function.
If all else fails check this site plug in your VIN and see if there is an update for your ECM programming. http://vci.ecomm.gm.com/vci/
Keep us informed.
Truck had started pinging again about a week ago and even with all of the new parts, it still pings a little bit. I guess I will have to live with it since I don't want to spend anymore money on it right now. Replacing all of these recent parts along with the fuel pump has set me back over $500. I just hope this thing is fixed.
I want to thank everyone who gave information and advice.
Wayne
