The dealer is going to charge you $800 just to take it apart. That's why they're going straight to the "replace" recommendation. Most consumers aren't willing to pay the $800, is my guess.
-juice
If you'll recall, a certain troll was predicting doom and gloom, you'd have thought all H6s would have blown up by now!
-juice
-juice
Leo - I had heard of the dry ice thing, but not so sure that would work...
Thanks, Matt
Unfortunately we cannot pop the front sunroof. We hold the open switch forever and nothing happens. When we let go and press again the rear sunroof opens. Are we overlooking something?
Also, do you get a free loaner for warranty work like in this case?
I feel fortunate buying a used L.L. Bean because of the free three year maintenance. You know at least the car has been serviced regularly.
While I"m on roll, does any one have any experience or knowledge about bumper repair. I know it's a hot new thing now and relatively inexpensive. Our front bumper on the very bottom is pretty scuffed and all of the corners have the common "garage swipe". Rear bumper has dime to quarter sized pieces of paint scraped off.
Steve
I was just wondering if it was OK with the EPA. They were stinking up the parking lot and paint was drifting onto new nearby Accords. Must be a different type of paint or they're doing it in an illegal manner.
Results seemed to be pretty good. Makes a used car look like it was pampered (like my car!).
So, used car buyer beware....
Ralph
-mike
Any cautionary tips/advice would be appreciated.
Also thinking of changing my own coolant. Do the dealers normally flush the entire system, or do they simply drain and re-fill?
You can also search the Subaru Maint & Repair II thread on Edmunds.
Jim
The Plugs I did on a WRX, not too bad, but you'll need to remove the battery, washer resivoir, and airbox, and you'll need at least a 6" extension, I used a wobble extension and/or u-joint.
-mike
Like Paisan said, remove the washer reservoir on the driver's side, and the air ductowork on the passenger side for easier access.
This probably also goes without saying, but make sure it's a cold engine!!!!
Jon
-mike
mike, any tips in removing the spark plug boots? Hope the dielectric grease I used on the boots help.
Jim (fortunately not due for a plug change for 15k miles)
Jon
-mike
Any ideas on how to get rid of (or at least reduce) the wind noise?
1. Install the yakima spoiler/deflector in front of the leading cross-member. This directs air from the windshield up and over the cross members to help reduce wind noise.
2. Spiral-wrap a heavy cord or wire around the length of the cross-member. This helps shed the wind vortex and reduce noise. (I don't recall the specific term for this effect, but it's been discussed in the board before). Perhaps you've seen some rigid car antennas with a spiral wire bonded to the outside - this is doing the same thing.
sun visor on the driver’s side is difficult to disengage. If I leave it disengaged
for any amount of time, it seems to “slip,” and is almost impossible to get back
into the brackets that hold it. I have in the past moved sun visors around a lot,
but hesitate to mess with my Legacy’s visor because I end up “wrestling” with it
to get it back into place. Not good to be driving and wrestling with your sun
visor at the same time. Has anyone else had this problem, and have you found a
solution? Emma (This may sound like a minor problem, but on a busy freeway,
with a blinding sun shifting position, and you battling to force a sun visor back
into place...it’s an accident waiting to happen.)
OK, if I got this straight, you are having problems with the roof mounted clip near the rearview mirror that holds the round rod on the sun visor - it is too tight.
1) The clip is held to the roof with a philips screw. Loosen it and try rotating the clip just slightly and see how the visor engages and disengages. Sometimes intentional misalignment will help it slip in with less resistance.
2) Try a little lubricant. A tiny touch of vasaline or the like.
3) Trim the lower opening lip ever so slightly with a file or exacto knife until a more acceptable fit is achieved.
Hope this helps,
Steve
Steve
Greg
Jon
02 OBW (30,000 miles)
CanyunTrash here.
I appreciate your response to my comment on edmunds.com OB/Legacy problems regarding brakes and wind noise (#1869).
Just an update here: About two weeks ago, I had a hard braking situation on the freeway. Almost immediately afterward, I noticed brake pulsation.
Yesterday I took the vehicle in to have the wind noise problem repaired under warranty. I also asked to have the brakes checked. The service rep informed me that I had less than 5% left on the front pads and quoted a price. I asked about the rotors and said I'd make my decision based on their condition. He said they would be taken care of with the brake job. I resumed with my work, expecting him to come back with a report. The next thing I know is that my "car is ready" and I'm being charged almost $200 for a brake job. And I never signed an authorization, even though I was waiting in the show room.
I was so upset I just paid the bill and left, as I was already late for a work appt. When I got on the freeway, I still heard the wind noise, the brakes felt mushy(although no shudder), and I had to take a deep breath to keep from picking up the phone and cussing out the dealer.
This is my third new Subie, but the first that required 4 brake jobs in 43g miles... and several trips to get something as minor as a driver door wind whistle fixed, which it isn't yet, but I'm about ready to just give it up.
I did wait until the afternoon to call the dealer and politely express my dissatisfaction with the whole mess.
Anyway, I called SOA this AM, but they're closed. I'll continue to persue this at that level, but thought I'd give you the "heads up".
That sounds similar to what I was experiencing in my '00 Outback. When the weather was warmer (May thru Sept here)the steering would groan when I was stopped. Turning the steering wheel would stop it momentarily, but the groan would come back about 10 sec after I stopped turning the wheel.
After a few visits to the dealer, they used a stethescope to determine that the power steering pump bearings were the source of the noise. They changed the pump under warranty. A year later the noise was starting to return. I never found out why as I had an accident and wrote off the car that winter :-( Happily there were no injuries, and I received a good payout from the insurance company. I am now driving an 03 Outback :-) which is a much better car - smoother, quieter, no groans, chattering clutch, etc.
Hope this helps.
MikeF
Steve
MikeF
that is the problem. The problem is that when I remove the sun visor on the
driver’s side from the bracket, I have a hard time fitting it back into the bracket
because the visor “slips out and gets longer” (sounds strange, but when I
mentioned it awhile ago on a service visit to the dealership, I was told, Oh yeah,
you just have to really push and get it back into place). The person who told me
this was muscular and strong, and I’m sure it was no problem for him. I’m
arthritic and old, and it hurts my back to push it back into place, and it interferes
with driving. Emma
i've got a '96 Legacy L (bought new, replacing an '86 GL10), and my SO drives a 2002 Legacy. So you could call me a subaru fan.
After owning these things for so long, and watching them evolve, i'd like to just back up what other folks are saying about needed changes to the 2005's and beyond. (This isn't just academic for me -- i'll be looking to replace my old legacy in 2006..)
1) Frameless window seals need improvement. The frameless windows are a nice idea, but my experience across several generations of subies is that the seals are imperfect, and cause significant wind noise. This is true even on our 2002. this also goes along with...
2) wind noise from the mirrors, especially on the driver side. It's present in all of our cars. I was really surprised that the 2002 still had this problem. Please, improve the aerodynamics of the mirror, the window seals, or even the thickness of the glass if you have to... just cut down on the noise.
3) weak brake rotors. the front rotors on these cars all seem to warp. I don't ride the brake, nor am i abusive. None of my other cars (hondas) exhibit these problems with warpage.
4) leaky gaskets. For whatever reason i find that these engines tend to leak oil & need to have their seals replaced more often than others. This goes for the 1.8L in the old GL10, as well as the 2.2 in my '96. Still no leaks in the 2002's 2.5, so i'm holding out hope...
I'm hoping that subaru can get these issues resolved for the 2005 model switch-over. If so, they'll continue to have me as a loyal customer.
I've never owned a car where the wind howls so much when driving on the highway. It's not the roof rack either...the noise comes from the A-pillar area. Whirrrl, whooosh. It can drive you nuts.
The brakes are funky. If you press them "normally" I don't notice any problems with their grip or feel. But if you have to hit the brakes hard, they pulse and feel like they have weak knees. It is not very confidence inspiring. I would find it hard to believe that a car with 2000 miles has warped rotors already, if that's what the real problem is.
Enigne oil consumption seems fine. I checked the dipstick last week and the level was still at the high mark.
No clutch chatter but I'll wait until winter before I write it off.
Steve
Steve
The black plastic cover/protector does not wrap down around the top corner of the bumper. If it did, it would have better protected the bumper (at least from my son). I see that there is a Legacy Wagon bumper cover/protector that appears to wrap down and around, but nothing similar listed for the Outback (this is on www.subaruparts.com and www.subaru-parts.com, part #E7710LS000).
Would this cover fit on my OB? Would it fit over the inadequate one that is already there?
--K9Leader
Cheers,
HL
Steve
Test drive any ABS equipped vehicle and this will happen when you slam on the brakes.
Jim
FWIW, my daily driver is a 94 Accord, also a first-of design. It has been incredibly reliable, but just not as much fun as the Sube, and I expect the Sube reliability to improve as it ages (to a point).
MikeF
When I take it to the dealer for the 3000 mile service I'll mention this problem but I won't say "pulse" because they'll tell me it's the ABS. That makes sense but that's not the cause.
I called the dealer but they refuse to discuss the problem over the phone and told me to bring it in and leave it for the day. I know that they will only take it for a test drive and tell me it worked fine for them.
Has anyone else seen this problem?
