-juice
-juice
-Dave
-Dave
BTW, to stay on track: no problems to report with the OBW today.
Steve
I have found that when I play CDs I have burned on my home computer, the quality is very poor and songs get skipped over or stuck (long delays when nothing gets played).
The tech column in today's newspaper had a Q+A about this problem for someone with their home CD player not playing the burned CDs. The writer suggested a Lens Cleaning Disk.
When I stopped at Staples to pick one up today, the salesman warned me to check with the manufacturer about using one on the auto's CD player. And the disk packaging clearly stated it was not to be used on automobile CD players.
Does anyone know or has anyone used one of these lens cleaning disk? Did it improve the performance? Why would they not be allowed to be used on car stereo systems?
Has anyone else had the same problem with home-burned CDs and if so, what has worked
Many thanks for those who take the time to post and offer ideas and advice.
David
-Brian
Ask a friend to burn you a disk (different media and computer), and see if it works any better.
I have no experience with disk laser cleaner, so I cannot comment.
Steve
:confuse:
Is there a way to repair them, or make them less noticeable? I think the more I see them, the more it reminds me of the aggravation from the said dealer.
The Miata's CD player does skip more with those, though.
Rims - most are painted, so you could have them sanded and re-painted. But I doubt the finish would be as durable as the original. Maybe powder-coat them? It might get pricey.
-juice
Steve
The quality of the CD-R and/or CD-RW media you are using is a factor in how compatible the discs are with different players. You may want to stick with higher quality media for use in the car.
I took car to a Subaru dealer who read an engine speed sensor fault (P0500). They checked connections and cleaned ground and fuse holders then ran car for 10 km with no problem. Next day I drove for about 100km without problem, then the symptoms re-occurred. I had to continue driving 50km to next town and noticed that the speedo would recover once speed dropped below 80km/hr, then cut out again a couple of minutes later. CE light came on. Speedo problem became moere and more frequent and eventually several warning lights would come on each time the speed cut out - seemingly random ( seatbelts, at-oil-temp, airbags, etc). Symptoms worsened when headlights turned on. Eventually the car died entirely with no power to dash when ignition turned on - however radio still worked.
My thought is that this could be a malfunction in the engine speed sensor causing an intermittent (possibly now permanent) short to the dash power. Does that make sense?
After reading through the responses, since I have been using Imation and TDK disks (which I trust are quality disks), I thought I would try burning a CD at a much lower speed (4K instead of 40K and I have been using Roxio for years) and the CD I burned at a lower speed played perfectly.
It appears that I may have been burning them at too fast a speed and getting inconsistent quality as a result.
I'll try burning some other favorites at the lower speed and hopefully will find that appears to be the key.
Thanks again for your ideas and help. Hope I can return the favor in the future.
David
In my experience, the relationship between burning speed and quality depends on the hardware and software used to write the discs. As an example, I have a burner now which almost always makes coasters when used at max write speed so I have to take it down a notch or two to get usable discs out of it.
I hate to have to return to the dealer for warranty work. This would be my first visit back, but, still dread it. Anyone have this problem? Also, anyone know if this will be covered under warranty? 2003 with 25k miles. :shades:
Mark
Disappointing, but I am sure that it would be covered in the 3yr, 36k warranty.
Steve
The Subie trannies tend to be robust, but it's not unheard of I guess.
-juice
My wife's car ('98 OB) is having same problem as described in the original post. I'm wondering how nick made out with this...and if Dave might be able to add to his description of the button's location...
I can *not* find such a button. I spent 20 minutes contorting my body into shapes it hasn't been in since working on my junker cars in high school and college. If that button is there it doesn't want *me* to find it.
So who's got pictures? Who knows how to just disable the whole stupid system (one keyfob is lost, the other is junk) so we never have to deal with it again.
It is 2005 going on 2006. We've been operating without the keyless feature for more than a year, but now this 7 year old device has become a pox on us!! For all the convenience it used to provide it is now demanding more in return. Evil! Evil! Pure Evil! Or maybe it just needs to go to a nice home where everyone is dressed in nice white coats.
Okay. I feel better now. Anyone got any suggestions?
Emails to ghaas@fiberpipe.net really, really appreciated...
Cheers,
Greg
Did you ever find the button?
Funny, too, is that on my module there is a yellow circular sticker that says "remove before use". I presume that means use of the module and not the sticker. heheh. Either way, its still on there. Maybe I should scrape that old hardened thing off and all will be good in the world...
tia,
Greg
Others might find this url helpful:
http://autorepair.about.com/library/faqs/bl036e.htm
Cheers,
Greg
Cheers,
Greg
I was digging into my memory...
guess it is faint as I no longer have my '98 OB.
-Dave
Grabbed a wrench and took off the negative battery terminal and was then able to turn off engine by turning key to off. Slight smell of HOT WIRING in the air but at least no fire. Starter was probably running continuously for 3 mins or so(!). Reconnecting battery did not cause the starter to immediately run and I have not tried to start the car since.
So what's going on? If the battery were LOW as it seemed at first could that cause the starter solenoid to stick somehow?? Or maybe the solenoid is fried? I plan to put the battery on charge before trying to start the car again. Needless to say my wife would freak if that happened to her, so any input appreciated.
- Malcolm.
Just a suggestion - keyless fobs are rather cheap on e-bay. You might want to consider keeping the system and adding a new fob.
Steve
then you've never had a recent Ford !! 95 windstar, new tranny at 45k. 00 windstar new tranny at 38K, and at 60 K something is going wrong again!! why would I get another windstar after the problems with the first?? because Ford bribed a whole bunch of windstar owners so they didn't get a class action law suit because the engine was even more garbage than the tranny! FWIW caravan and odyssey owners have had lots of tranny problems too.
I'm on my 3rd AT legacy and also have a MT WRX, never had any tranny problems yet. sorry to hear you are having problems with yours.
Rotor is scored, and pads are not wearing evenly. My guess is the caliper got stuck on the slide. Car goes in to dealer on Wednesday. I am expecting pads and rotors. At 20,100 miles, would this be covered under warrantee? Thanks! Rob M.
My 99 Outback Legacy Wagon started doing the exact same thing very early this year (overheating randomly, coolant backing up into reservoir). After 3 mechanics, :mad: a change in radiator, plugs, thermostat, etc, they opened her up looking for a head gasket and found a tiny hairline crack in a cylinder.
After speaking with a parts guy at a Subaru dealership, the 1996-1999 dual overhead cam motors all have problems with overheating. In fact, he told me I wouldn't have much luck looking for a used engine because everyone in the world has sort of used them up replacing engines just like mine. He stressed that the 2000 (onward) engines were changed by the manufacturer because Subaru had no idea what was causing the overheating and probably didn't want to take the risk of a major recall. :sick:
A mechanic I used to date has advised us to find an attorney and to contact Subaru HQ directly (they deny everything of course). Thus, I pass that information on to you.
Good luck!
PS: If anyone else has had this problem, I would like hearing from you. It's taken us almost 5 months to figure this all out!
If you are still within the 3yr/36k basic warranty, a seized caliper should indeed be covered, plus any damage it causes (trashed pads and rotor).
Steve
Mark
I first noticed it as a hesitation when going into drive, and since I've never owned a subaru before... thought it might be kinda normal. This past weekend it, though, it took ~3 minutes to drop into drive after backing out of a parking space. Called the dealer today and he said it sounds like a low/reverse piston seal in the transmission... a $2500 repair. Needless to say, I'm pretty mad at Subaru right now.
Does anyone know whether it will hurt the car to keep driving it like this? Also, would a tranny flush help any, or is it just a temporary band-aid? And finally, should I just get a remanufactured transmission, or let the tech do the rebuild?
Okay, so I should probably be thankful that my car has been so reliable (meaning that I only have to do a major repair about once a year or less) thus far, but darn it all. While I am right in the midst of trying to fully diagnose a probable head gasket failure, my darned heater fan goes on the fritz. Now, I can live with junk head gaskets but winter is coming all too fast (today is August 1, so less than 60 days away!) and I cannot start the car up at -30F to find that the heater fan isn't working. At first I thought it was very straight forward: the fan is finished. When I turn the fan speed selector from 0 to 1-4, I can hear the relay engage somewhere within the dash. However, about 35% of the time the fan does nothing. Then (I initially thought it was random), the fan will turn on out of the blue and blow like normal, except that it has this speed-sensitive ticking sound similar to putting a card in the spokes of a bicycle. This all started on Wednesday afternoon while we were returning from a 1,200 mile dipnetting trip down to Soldotna.
This morning my wife was supposed to have the car, so she goes out to start it while I am inside doing the "morning routine" with our little man. After a few minutes (remember, she was just starting the car!), I begin to wonder what is taking her so long. Eventually, she pops through the door and apologizes, but "the heater fan wasn't working and I had to get it going." I asked her what she did to get it going, and she responds "the same thing I did for the last couple of days." Oh! News to me..... so it turns out that if she engages the AC, the fan will blow without fail but that it will only keep blowing after AC is off about 10% of the tries. So, she keeps turning the AC on, then off, then on.... until the fan finally stays on while the AC is off. :confuse: I tried that, and no luck - the fan came on when it randomly wanted to come on. It does work for her though - seemingly without fail. I guess she has the magic touch to which our buggy Subaru responds.
Whew. Okay, any suggestions on what might be the root of the problem? I originally thought it would be a simple fan replacement, but with all the flippin' electrical gremlins in this car, I should have known by now that nothing is ever simple with Subaru electrical. :mad:
Thanks, folks!
