Toyota Echo Maintenance and Repair
1151618202131
  • ray53ray53 Posts: 2
    I have a 2000 echo with 184k miles all origional I just replaced the origional battery, passed smog with flying colors all freeway milles. BUT a few day ago on the freeway it was like running out of gas then it stalled. I towed it home and sprayed some starting flued in and it tried to start. So since all a car needs is air, spark, and gas I figured gas. I replaced the gas pump in the tank and the filter. no go it still will not start, but if i use the starting fluid it tries,,,,help i have spark and air any ideas????
  • kneisl1kneisl1 Posts: 1,694
    Did you check the computer for error codes?
    no I have not the check eng light never came on
  • I have a similar problem to the same question. However the instrument panel lights in the car come on. I have replaced the starter and put in a new battery. Once I turn the key, the clock light dim and I do not hear the fuel pump kick over when I start the car. Any suggestions on what else I can test for?
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 51,055
    Is this an automatic? Have you jiggled the shift lever? Maybe you have a bad neutral safety switch?
    MODERATOR --Need help with anything? Click on my name!
  • Hi All, hope someone can help?, Toyota dealers here in Ottawa not much help,
    I'm looking for a wiring diagram of a 2001 echo tailight wiring, the area were to tap in a trailer wiring harness, i know about the plug in one's, but my trailer has separate turn and brake ( like the car), need color code for wires at the tailight connector in the trunk behind the drivers side trunk liner panel.
    If anyone has this info? it would be greatly appreicated.
    Thanks Tyler ( 2001 echo 4d sedan )
    Turn the signal on (like the left one) and take the bulbs (the socket with the bulb in it untwists from the housing)out until you find the one that is blinking. Then you can see what wires go to it. I use a stick between the seat and the brake pedal when I want the brake lights on for something.
    When you rev the engine on our 2000 ECHO with auto trans and 117k miles there comes a squeek. It does it in Drive while moving and it does it in Park. I imagine this would be the belts. The PS belt is a little looser than the one on my 2001. But the belts were new at 100k miles. Is there anything else this squeek is likely to be? Thanks!
  • nippononlynippononly SF Bay AreaPosts: 12,695
    It has to be an idler pulley, doesn't it? I have a pretty regular squeak now, but mine is only at idle, and just when it is cold out. If it ever became louder or more constant, I would have them go in there and find it, and put a new one in.
    2013 Civic SI, 2009 Outback Sport 5-spd (stick)
    Hmmm no there isnt one on the ECHO. The water pump is driven by the flat of the belt sort of like a serpentine belt. Which I dislike no end. (poor grip compared to the ribbed side) I see "Ford" of one of the belts now so they arent Toyota belts ($80 for the belts themselves BTW at Toyota) Im getting a bad feeling its one of the driven accessories like WP, PSP, alternator, or ac.
    I just pray its not the tranny!
    Heres a little something that makes you think. I have three Toyota dealers nerby and one of them wants $45 for the two belts on the engine and the other wants $85. The place selling them for $45 wants $139 total to change them.
    I bet there's a timing chain tensioner though, isn't there? Could be that is screeching because it is nearing its end. If it is that, don't delay in fixing it. If it blows apart or freezes, consequences could be dire as you know.
    Yes there is one. Its hydralic whereas accessory belt tensioners are spring activated. If the timing chain were not right somehow then the engine would run badly...which isnt the case. Still that would be a disaster to have the chain go! I called the service departments of two Toyota dealers in the area and they both suggested tightening the belts. It not easy but when I get around to it Ill tell you ifn that fixed it.
  • do a search for "2000 to 2002 echo factory service manual torrent" on google and download the *.rar file, It helps a lot
  • Greetings all... I was wondering if anybody out there might have an idea what is going on with my 2001 Echo. Recently I have noticed a subtle "bouncing" in my car at speeds from 10-25 mph. After 30MPH, it is not really noticable. I bought new tires 3 months ago and this problem didnt exist before the new tires. Is this possibly a balancing issue? Any suggestions would certainly be appreciated.
    Thanks all....
    Why three new tires? Whats on the 4th wheel? I would start by balancing that 4th tire/wheel. Then rebalance the new three. (or take it back and ask the people you bought the tires from to drive the car)
  • I just finished replacing my water pump but while re-installing the alternator, I heard a spark, my bad for not disconnecting the battery. Now the engine starts and runs fine but I can't get the car out of park and also no mileage showing on dashboard and check engine light is no longer on. Did I blow a fuse or is this more serious??? Any ideas?? If a fuse then which one is likely??
    You need to check the fuses if necessary removing them one at a time. There a fuse box under the dash near the driver and also one under the hood. Check your owners manual. Hopefully some of the fuses are blown and replacing the blown ones will fix the problem. How difficult was changing the WP? How many miles when it went?
  • Never mind, I figured it out...turns out I blew a fusible link when I shorted the alterator. Attached to the positive terminal of the battery is a square box, iif you remove the cover you can see the fusible links. Mine has two and one was burnt through. I bent it back together so the halfs would touch and everything works fine now. Phew! Tomorrow I will go to the dealer and get me a new fusible link.
  • Changing the water pump wasn't too bad...I did curse a few times...there's not much room in there. Drain antifreeze, disconnect battery, remove belt, remove alternator then 3 bolts and two nuts and water pump is out. It is tight to get in in/out but it does go. Careful not to damage the gasket when putting new water pump in. What a difference...no more leaking and no more noise.
    My mileage is about 165,000.
    I always wondered what that box was. Wow 165k miles. I put three pumps in my 240D every 60k miles like clockwork. The Japanese ones seem to go much farther than that. My 2001 ECHO only has 43k miles on it but it IS eight years old. Hopefully Ill never have to do it. My sons 2000 ECHO has 120k so I guess thatll go someday...
  • Hi, no I bought 4 new tires. They were brought back and rebalanced. The problem I'm having with the Echo is a "bounce" from 20-25 mph. I'm thinking it may be a strut/shock issue. Once the car hits 40, its smooth sailing. Any ideas/ suggestions? The car has 100,000 miles and is a 2001. Thanks for your input, its much appreciated.
  • Just to let people know that I experienced slow take off espacially when cold. After changing plug and air filter to no avail i tried a response i saw on this website which worked a treat. It involves cleaning the thin wire air flow sensor on the air intake box with a cotton bud preferrably with a spirit as it had carbon deposits. Note there seem to be 2 of them.
    Now it goes well again.
    Cheers
    Stan
  • I've got a 2000 Echo with about 153K miles on it. For the past three years, I've noticed a chirping noise when the AC/heat is engaged.
    Lately, especially starting up in cold weather, the chirping has been joined by a hideous squeal. The squeal is terrible during the first 30 seconds of use in the morning (it's bad when turning the steering wheel) and then abruptly stops.
    I've narrowed the chirping noise down to the AC clutch when it's engaged, but the squealing has me baffled. I've had the belts checked out twice in the last year and have been told they're OK.
    Would a faulty clutch cause the squealing? Is it as simple as tightening the serp belt?
    Any help would be greatly appreciated!
    The fact that it makes the noise when you also turn the wheels indicates a loose/worn belt. When is the last time the belts were changed? The PS is on a different belt from the WP, AC, ALT. Could still be something like the AC clutch but you really need to eliminate the belts first. Who said the belts were good?
  • We had the same sqealing when we turned on the a/c. Couldn't find it so took it for a service and it came back fine. I think it wass some belt or adjustment on the a/c.
    Stan
  • There's probably 9,000 miles on the serp belt. I'm not sure about the PS belt. A mechanic and friend of the family said the belts looked good.
    I ran the car cold today -- after it sat for five hours in the 32-degree cold -- and drove it home without any heat and the fan off ... no squeal, not even on turns.
    I'm going to let it sit overnight and fire it up again in the cold of the morning without the heater. If there's no squeal, then I'm thinking it's that clutch.
    Any thoughts?
    AC clutch wouldn't squeal. More like rapid chirping, chattering. And it wouldn't go away unless you shut the AC off.
  • marcumarcu Posts: 11
    Hello, i'm looking for a front bumper cover for my Toyota Echo 2003 4 doors sedan. I don't want the primed one (ready to paint) but the BLACK one (textured). Any good address and pricing where to buy AND shipping in Canada? :confuse: :confuse:
    O.K. pals i've found the deal i was looking for! thanks for reading nevertheless ;)
Toyota Echo Maintenance and Repair - Page 18 - Car Forums at Edmunds.com
