E.D.
Ok, so my 2005 Altima is having issues when starting. When I turn the key on the engine would sound like it's out of gas and won't start, but after 5 secs of holding on to the key the engine will finally start, sometimes shaking a little. I've checked the spark plugs, air filters, and taken my Altima to two Nissan dealers. One told me that the engine's dirty because I didn't use a Nissan brand air filter, (Fram instead) and another dealer said they didn't find any problems with it. It's hard to duplicate the problem. I know it usually happens after I've parked the car for 30mins or so and started it up again. It turns on fine every morning though. Could it be the fuel injection?
Please help. :confuse:
Go for the purchase.
I agree, the ignition switch is not your problem.
Does this car have any kind of "fusible link" for the positive battery cable as it leaves the battery?
There is a fusible link, which is really just a big, 75 amp fuse that sits in the fuse box next to the battery. When I started work on this car, that fuse was blown, & I have replaced it, to no avail.
That's not a good sign...hmm...I need to think about this....
Good Luck,
E.D. ISF
Found a similar problem
having some a/c problems with my 1996 Altima. For the last few summers i've almost died in my car. Sometimes my air works and sometimes it doesn't. It often doesn't work on really hot days. They air will blow cold for a second or two if at all and then it blows out hot, muggy, wet, nasty air. I had my a/c recharged last week but that didn't do anything. I've talked to many mechanics and no one knows what is going on. If anyone has any suggestions please let me know. I've also noticed that the a/c button light doesn't go on when it is hot out side but sometimes at night when it cools down the light will go on and the a/c will work fine. My wife and two daughters are dying without a/c. Please help. Thanks
Good Luck,
E.D. ISF
It is really frustrating to say the least. I had it in the shop today and the mechanic couldn't find an answer for me.
As for the check engine light, when it illuminitates, it always sets a code in the computer. The mechanic should have told you what the DTC (Diagnostic Trouble Code) was. Then you look for the problem that cause the DTC to set.
I think it is very stupid that the car companies don't put a digital readout for the DTC on the dash of the car. It would be very simple to do that.
"They have tried some things, but all its doing is wasting my money" I would maybe pay them the first time for diagnostic time, but not on the second and third time for the same complaint. Take it somewhere else if it happens again.
The only other things that it could be is a leaking fuel injector or faulty fuel pressure regulator. Also, your o2 sensors have a slight change of telling the engine computer to richen the fuel mixture, but most likely not.
I have the same problem, 1996 gxe , automatic, whenever I stop it starts to shake , steering wheel everything, there are times thought its doesnt , like in the morning. Dont know if you have any luck with yours.
Rupert
Rupert.
http://www.automotive.com/2003/49/nissan/altima/recalls/31103.html
2003 Nissan Altima Recalls
Recall ID# 06V242000 - ENGINE AND ENGINE COOLING
Recall Date:
JUL 07, 2006
Model Affected:
2003 NISSAN ALTIMA
Summary:
ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH A 2.5L ENGINE, A VARIATION IN TEMPERATURE OCCURS DUE TO THE UNIQUE LOCATION OF THE SENSOR IN THE ENGINE. UNDER CERTAIN DRIVING CONDITIONS, THESE VARIATIONS IN TEMPERATURE CAN BE LARGE ENOUGH TO CAUSE A BRIEF INTERRUPTION IN THE SIGNAL OUTPUT FROM THE SENSOR.
Consequence:
IF THE INTERRUPTION IN THE SIGNAL FROM THE SENSOR IS SO BRIEF THAT THE ELECTRONIC CONTROL MODULE (ECM) LOGIC DOES NOT HAVE TIME TO DIAGNOSE THE CONDITION, THE ENGINE MAY STOP RUNNING WITHOUT WARNING WHILE THE VEHICLE IS DRIVEN AT A LOW SPEED INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL REPROGRAM THE ECM FREE OF CHARGE. THE RECALL BEGAN ON SEPTEMBER 20, 2006. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Potential Units Affected:
294166
Notes:
NISSAN NORTH AMERICA, INC. R0606
the 6 cd changer failed with Err2 with 3 of my CDs. can somebody advice on how to get the CDs out? Also the 6-CD changer keeps whirring every time, I start the car and then stops with Err2.
thnx
jack.
THANKS FOR YOUR HELP
ROBERT JIMENEZ
Nothing to worry about - it was designed that way (probably to save a little production cost). Nissan, as do a number of other automakers, routes power directly from the battery through the radiator's thermostatic switch that activates the radiator fan. Not having the ignition switch involved in the radiator fan circuit allows that fan to merrily drone on for some time subsequent to switching off the ignition. Sorry I wasn't able to help with the A/C prob.
Welcome to the wonderful, wacky world of CD changers - especially the increasingly popular indash versions. Sorry - there's generally only bad news and worse news once a jam has ocurred. If you had affixed paper labels, there's a good chance they're responsible - the working clearances of the mechanicals in indash changers are incredibly small. The thickness of a paper label or sticker can be all it takes to jam a CD in the guts. Even without labels, these machines often become finicky over time. The remote possibility good news? If you car is under your basic warranty time and mileage limit, you may just be entitled to a free head unit exchange. (Some makes, such as Hyundai, have an even shorter time and mileage limit than the basic 5/50 for their audio systems - dunno what Nissan's policy is. Check your warranty supplement booklet.) If your car is over the limit, you will probably have to cough up out of your own pocket unless Nissan is comping these units as a goodwill gesture. (If not, and if you're on nitroglycerin for angina, you may wanna slip a tablet under your tongue before you hear the bad news - the dealer replacement cost of factory head units is obscene...) The only way to retrieve jammed CDs out of an indash changer is to disassemble the head unit to extract the CDs manually. Once jammed due to a malfunction, the captive disc(s) aren't gonna magically eject regardless how many times you attempt it.
Once a year, I check up my car engine to see how healthy it is. Usually after a good half of an hour trip while engine still hot I put on gloves and carefully remove spark plugs and compare them. If they are all similar and dry, engine is doing well. If not, start a basic tune up.
My basic tune up is:
Engine Cleaning: Once a year Flush Engine and put in Engine Restorer, use Synthetic Blend Oil to reduce engine wear.
Electrical: Replace spark plugs (Bosch Platinum +4 $20), Distributor Rotor ($7) & Cap $15), Ignition Wires (OEM from Nissan Dealer $65).
Gas: Replace fuel filter ($10), add Fuel Injection Cleaner ($3) into gas tank.
Air: Replace Air Filter (Frame $5).
You can buy good parts at discount price at website Rockauto.com If you can do a tune up by yourself, you already save $ on labor, do not try to save $ on cheap parts. I have kept a good tune up on my 97 Altima car since the beginning. Now I got 284k and every mechanic drove my car said it could be a 100k more. In term of money, I will save money of buying another car.
i looked at the compressor while AC running & not running. Could not see whether the clutch engaged or not. It looks just the same both times. However I noticed the twin radiator fans started running when AC was on but stopped running while AC was switched off manually. But the belt attached to the clutch was always running. Are there any pictures on the internet where I can see an engaged clutch and a nonengaged clutch?
thnx
Jack.
Good Luck,
E.D. ISF
I have questions reg. the engine in Nissan Altima 2001 GXE 78K miles. The second piston from the left had oil surrounding the rubber-casing when the piston was pulled out of the engine. the other 3 piston rubber-casing was fine. no oil. the tech guy said it could cause a fire hazard as it was right above the spark plugs. Need to know is it true that a fire hazard and how expensive it is to replace the stuff. I had my engine gasket changed about a year ago. I just changed my axles on both front wheels.
thnx,
jack.
