There's no chance of a fire hazard with oil. It just makes for a dirty engine and the need to check the oil level on a regular basis between oil changes.
As far as cost, don't have a figure I could give you, except it won't be cheap. If it were me, I'd see how much oil I'm losing on the dipstick, and if it's not much, I'd just add some between oil changes.
Last fall, I bought a 2004 Altima with approx. 32000 miles on it. About 12 days after the 90 day limited warranty expired, my service engine soon light came on, the car started bucking wildly. I took it to a mechanic and the first spark plug on the left was coated in carbon and the gap completely closed. This has happened 5 or 6 more times since then and it's also happened to other spark plugs. In addition to that, I just had a mechanic do a code search and it says that I have a crank shaft sensor error and something to do with the rpm's being off. Are these issues all related? Have any of you heard anything like this happening before? Is this a fixable problem?
Thanks!!!
Black - rich fuel mixture
Blue - oil
White (briefly) - condensation in the exhaust system evaporating off and recondensing in the cool air after exiting the tail pipe until the engine warms up - harmless
White (continually) - very bad; high liklihood of a warped/cracked head and/or blown head gasket; if coolant is making its way into the crankcase and contaminating the motor oil, the engine is or could soon be on life support without prompt attention. Because of its inability to lubricate under high load situations, antifreeze is very erosive to the soft bearing metals encountered in crankshaft main and connecting rod bearings.
All problems are "fixable". The question really comes down to whether fixing your car's problem will cost more than the car is worth. I'm not qualified to answer that, but hopefully not. You do need to find out why your engine's spitting diagnostic codes, though, regardless whose nickel it'll be on. Best of luck.
(By the way, the following parts are covered for free replacement including labor charges under your car's Federal vehicle emissions warranty for 8 yrs./80,000 miles from the orginal new car date of sale:
the catalytic converter
the engine control module {computer}
the onboard diagnostic device)
The fouling can come from too much oil in the combustion chambers, or it can come from a faulty ignition system.
I seem to remember reading that some of the Altimas in some years had a problem with bad piston rings from the factory. I would look into that further, maybe Nissan would take care of it, but I am not sure how many years or miles they cover. They may be able to tell if you had the problem by your VIN number. Do some Google reasearch on it, and you should uncover something on it, like this:
Nissan Altima Recall # 06V223000- ENGINE AND ENGINE COOLING
Component:
Summary:
CERTAIN PASSENGER VEHICLES EQUIPPED WITH 2.5L ENGINES MAY EXPERIENCE EXCESSIVE ENGINE OIL CONSUMPTION AS A RESULT OF IMPROPER PERFORMANCE OF THE PISTON RINGS.
Consequences:
IF THE OIL IS NOT MAINTAINED AT LEAST AT THE MINIMUM LEVEL, ENGINE DAMAGE CAN OCCUR AND IN EXTREME CASES RESULT IN AN ENGINE FIRE.
Remedy:
NISSAN HAS NOT YET PROVIDED A REMEDY FOR THIS CAMPAIGN. ON JUNE 9, 2006, NISSAN NOTIFIED OWNERS OF THE POSSIBILITY OF EXCESSIVE OIL CONSUMPTION AND THE IMPORTANCE OF MAINTAINING THE OIL AT A PROPER LEVEL. FOLLOW-UP LETTER TO OWNERS ADVISING THEM OF THE STATUS OF THE RECALL WAS SENT DURING AUGUST 2006. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
BOTTOM LINE IS: A good mechanic will know how to read and interpret the codes, and know how to troubleshoot and repair the problem. If the mechanic doesn't know how to fix the problem, find another mechanic.
Good Luck,
E.D. ISF
The codes I'm not sure about:
P0420 is Catalyst System Efficiency below Threshold, which is likely caused by oil contamination caused by the engine in the catalytic converter.
P0735 is something about an incorrect gear ratio, not sure about that one.
You big problem is OIL CONTROL in your engine. You should have the mechanic do a cylinder compression test on each clyinder of your engine, and report the compression of each clyinder here. They should all be within 20% of each other and not very low overall. If you have low compression in one or more clyinders, it could be Rings, or valves, or head gaskets or the valve timing or cam timing could be messed up.
Good Luck
E.D.
Eventually it will always shift, but I need to get the car inspected so this needs to be fixed (as inexpensively as possible as the car isn't worth putting too much $ into).
What might be causing this to happen? (Bushings/transmission oil/clutch/other?)
They measure and rate batteries in 'AMP-HOURS' The battery should produce a certain amount of amps output at a certain voltage over a certain period of time.
So bottom line, always charge the battery fully before you test it, or it will test bad.
In your case, I think someone is coming by and sipping your glass at night.
Good Luck,
E.D. ISF
I own an 03 Altima 2.5S, auto trans, w/ 70K miles on it. Lately, when I drive my car to work, the first time the speed hits 75 mi/hr, the car will lose power, or at least feels like losing power for one or two sec, yesterday, it got more severe, the speed was oscillating back and forth from 60 mile to 80 mile no matter how hard I hit the gas. I was scared a lot.
I would appreciate any headsup, something must be wrong, I just don't know it's w/ transmission or w/ engine.
Thank you very much!
http://www.obd-codes.com/trouble_codes/index.php
Other things could also cause this, but these are some of the most likely places to look first.
Good Luck,
E.D. ISF
My second guess would be the ignition.
It's unlikely to me that it would be the trans.
Let us know how you make out.
PARASITIC CURRENT DRAW TEST:
Start with a fully charged Battery. Turn everything in the car OFF, close the door, remove the light bulb from under the hood so that NOTHING you know of is on. Remove the negative cable. Place a 5 amp fuse & a 1 ohm/10watt resistor in series with the negative cable and the negative battery terminal, then wait a few minutes to allow the modules to settle down, then proceed. Connect a Digital Volt/Ohm Meter across the resistor and do a simple voltage drop test. Results = for example, a .022v draw = a 22mA draw. When you have minimal computers/radios/etc a maximum of 25mA is optimal. If you have multiple computers/cell phones/alarms/etc expect a higher number to be normal, though the cell phones/alarms should be OFF for this test. Over 30ma should be investigated and over 50ma should be corrected. Check manufacturers specs to be sure of what it should be for your particular vehicle.
Good Luck,
E.D. ISF
The fuse and resistor form a series cirucit that is in series with the battery and the load, so whatever current flows out of the battery goes through the fuse and the resistor.
You COULD use a multimeter to read the current flow, but it could be very dangerous, or you would keep blowing the fuse in the mutimeter, because most times you are having larger currents flowing in the test until you find the problem. Most multimeters measure current in small ranges, usually no more than 10 amps, and smaller range scales. Larger currents cause them to blow a fuse inside the meter case. During the process of testing, it is easy to create a short when dealing with poking around in the wiring. The method I outlined is easy, safe and works well.
The fuse is for overcuurent protection, which is very important during testing. Keep extra fuses handy. Without the fuse, if you should happen to short out a wire while testing the wiring or poking around in the wiring, a heavy current could be drawn through the resistor and burn it up or start a fire. One Ohms Law formula is Amps = Volts divided by Resistance, therefore a direct short will cause 12 Volts/1 Ohm = 12 Amps to flow through the resistor. This 12 amps will overheat the resistor very, fast. Another Ohms Law formula for Power is Power = Volts times Amps, therefore 12 Volts X 12 Amps = 144 Watts of power would flow through the above circuit. Since the resistor is only rated at 10 watts, it would overheat very, very fast. The 10 ohm resistor is a common resistor avaiable at most electronic stores. You could use a 150 watt or larger resistor and not use the fuse, but the large resistors are expensive and hard to find.
The reason for the resistor is to create voltage drop while the load current flows through it. You read the voltage drop across the resistor and use Ohms Law to convert it to Amps. As an example, if you measured .5 Volts across the resistor on the meter, .5 Volts divided by 1 Ohm = .5 Amps or 500 Ma, way too heavy of a current with everything turned off. You usually want to read .025 Volts or less on the voltmeter, the .025 Volt number converts directly to .025 Amps because of using the 1 ohm resistor. Using the 1 ohm resistor makes the math much easier. .020 Volts would convert to .020 Amps or 20 Ma, 10 Volts would convert to 10 amps, etc. The resistor being rated at 10 Watts would mean that the most current that it would be rated to pass at 12 Volts is 10 Watts divided by 12 Volts = .83 Amps or 830 Ma.
Good Luck,
E.D. ISF
Good Luck,
E.D. ISF
The SE package has the Audio and Cruise controls on the steering wheel, the issue I have is that whenever I drive the car, something under the steering wheel controls rattle. It wasn't a big deal in the beginning, but you can't listen to the music as you always here that rattle. It doesn't matter if I drive 10 mph or 70 mph it still rattles. Whenever it’s cold outside (below 30 degrees ) it stops the rattling noise. I didn't care at first, but I drive 100 miles a day and it`s really startng to get on my nervous as well as I'm starting to get headaches from it. It`s gotten to the point where I would much rather take my other car to work and just let the Altima stay in the driveway and not drive it at all!
I took the car to the dealer twice for that issue. The first time they tightened something up, but problem wasn't resolved. This time they said that they noticed the same problem in other Altimas and that no matter what they are going to do is not going to resolve the problem. They also said that IT`S NOT A DEFECT AND THAT THERE IS NOTHIGN TO FIX. The way I look at it, I bought this car so I could drive it and lately I’ve been taking my other car to and from work simply because I can't stand this rattling noise I spend approximately 3 – 3.5 hours a day driving and it`s really very annoying. I told the dealer that if they can't fix it, they will wind up buying the car back... I heard some commercials on the radio for one of the law firms in Chicago. According to commercials, dealer has 3 attempts to resolve the issue within the first year of ownership of the car and if dealer can’t resolve the issue within 3 attempts by law in the state of Illinois they might have to buy the car back under the Lemon Law. Anybody has the same issue or has anybody had to deal with the lemon law lately? :lemon:
That's just the camshaft drive timing chain rattling around its plastic retaining guides on initial startup until the chain's autotensioner pumps up with full oil pressure - very common in chain equipped engines in cold weather since thick, cold oil takes longer to put into circulation. If you're using 10W-30 motor oil, consider 5W-30 to help with cold starting and its associated noises.
Nissan, because they got slammed with the 2002 Altima launch squeaks and rattles issues, recently installed a new test track at both US assembly tracks to check cars/trucks prior to shipment. I heard they spent 7 figures on both tracks because they know it matters to customers. I think The Clarion in Canton Mississippi done a right up on the project at the Canton plant.
Try the dealer or another one since you are travelling so far you are bound to run into another dealer along the way.
How long have others gotten out of these tires? I started watching them around 30,000 and always rotated them as recommended. The tread still looks good.
*The parking brake in my '03 Sonata was sufficiently slack when I took delivery four years ago that it wouldn't hold the car against my inclined driveway. I readjusted the individual rear wheel parking brake cables at the equalizing yoke after I removed the center console.
Computer read is out, it is a bad crankshaft position sensor.
Will have it replaced at dealership tomorrow, quote is $195.
They have calculator for tire size conversion.
Ok now let's understand New Car with lot's of redesign so this post is not to slam Nissan because I think they have a good car here. But let's get these issues on the table so Nissan can address them.
Our first sign of trouble was a rattle with the rear speakers.
Our second is a nasty valve rattle when the vehicle first starts up.
Our third is that we can't seem to get better than 29 MPG. (Our 05 and 06 got 30 on the HW) This one is rated for 34
Today's problem occurred at 1730 miles. Check engine soon warning. Now this may be a simple gas cap issue. But I checked it as the manual suggested and we will try for another day. Before going to the dealer.
The transmission takes some getting use too. Seems the tranny down shifts a bit too quickly on down hills. Puts unusual drag on the vehicle.
But overall We like this car. It handles well, much more comfortable. A little sportier, but the woman is not happy with the shortage of storage over the 06.
I like the fact that steering pull has been eliminated.
Well that brings everyone up to date. Let me know your feelings. Ill let you know what the dealer does to fix these small issues.....
There are 2 probs with setting it to "best run". First, you may not pass your next emision test, as your car will difinitely be producing more HC and CO. The second is you will probably notice a drop in gas mileage.
Other possible probs include, knocking or pinging under hard accel, and loss of power at certain RPM ranges.
I was wondering if anyone has had this problem with their Altima.
