Ford Expedition Maintenance and Repair
  • paul9250paul9250 Posts: 2
    I've got a 97 Expedition with the Triton V8 and have had all of these problems. Causes may not be the same but here's what I found: (I'm an experienced mechanic)
    Engine studder/miss: Assuming you don't have the check engine light on and there are not codes showing on the ODBII port read out the missing is likely moisture inside one or more of the coil pack rubber boots or a faulty coil pack. Pull the coil packs and check for moisture inside the spark plug tube or the spark plug boot. A good indicator will be corrosion on the spark plug. Next, if you've never changed the plugs do that next. If it still misses buy a new coil pack and change the coil packs out one at a time with the new one to see if you can eliminate the problem. Try the #3 hole first. That one seems to be a problem area. Its also the most common blow out hole (these engines suffer from spark plug blow outs).
    Transmission leak: Add some flourescent die to the transmission fluid and run the vehicle until the transmission oil temp is up to normal. Shine a black light around the tranny until you can identify where he leak is coming from. Then trace is back to the source.
    Rear end noise: This one stumped two dealers around here. The problem for me ended up being the shock mounting bolts. Over time the holes get oval and the bushing ends develop play that only shows up when the rear end is articulating. The only way I found it was to put the vehicle up an a lift and with a couple of friends shook the rear suspension up and down as hard as we could. (btw - make sure your spare tire is tight in its mount. This also causes a clunking noise if its loose). Replace the lower shock mounting bolts with new ones. If you haven't changed the shocks in a while now would be a good time. Especially, if the lower shock bushing are shot.
    Low gas mileage: This is probably directly related to the missing. The first culprit here would be the mass air sensor. But, if you don't have an engine check light on and no codes showing then this won't be the problem. Check the mileage after you solve the missing problem. Borrow someone's ODBII code reader and get a read out from your ODBII port just to make sure you don't have a problem with a sensor. (i.e. an oxygen sensor could be going bad).
    Hope this helps.
  • jg88jg88 Posts: 59
    Here's one for the books -- can't find a TSB on it either. '04 expy EB with the rear climate control system. When I set the dial in the 1st and 2nd positions for rear ventilation, it makes two different sounds behind the middle seat on the passenger side. In the 1st position, it clicks, 2nd position, it makes a "whump" sound. Position 1 is "click, click, click..."; position 2 is "whump, whump, whump...". When the rear dial is returned to the "off" position (farthest to the left), it goes away.
    Also, if I set the vent system to "floor", it disappears. On the higher level setting, it comes back. Sometimes it goes away, other times it does not. Is there some sort of a vent regulator behind the passenger side middle seat? If so, does anyone know what this is, if there is a TSB or is this just one of those weird items no one else has experienced?
  • alwaysfords2alwaysfords2 Posts: 335
    it is one of the two blend door actuators. Could be the one that takes it from floor to ceiling, or the one that controls the temp mix. I'd guess it is the floor to ceiling one, which is the easier of the two to replace. You need to remove the change/junk tray under the passenger side quarter window. Flex it in the middle, it is just attached by plastic arrow heads molded into the tray itself. Just slightly forward of that there is a beige/white box. That is the actuator. You can check if it is the culprit by unplugging it and seeing if the noise goes away. To remove it is a simple three screw job. It is easier to manipulate it if you take out the cup holder just ahead of it. It also just pops out. Should take $30 and 15 minutes to do, or $200 at the dealer.
  • bronsonbbronsonb Posts: 170
    I had this same problems, and as the other poster mentioned, it was a relatively simple repair. I actually removed the entire cover in the back seat area. It required a special "star socket" to remove the second row passenger side seat belt anchor, and then the rest of the plastic cover on that side popped out with a little prying (might be a screw under the plastic cover above the bumper that needs to be removed too).
    The two units that are the culprits are about 1/2" thick, squarish in design and about the size of a pack of cigarettes (but a bit larger). They are held in by a few screws and a simple plug. As the previous poster noted, unplug one and see if the sound goes away.
    I ordered replacements online, but you could probably get them from your local Ford store too. One of the actuators costs about $18, but the other was almost $40. Overall it was an easy repair considering I'd seen posters who said they paid $400 to get that fixed.
  • jantj5jantj5 Posts: 1
    I have the same problem. Did you find a solution?
  • genoahgenoah Posts: 1
    I have a 97 Ford Expedition 4.6 V8 with a really bad leak, there’s cooling fluid really pouring out of a spot that I cannot exactly see above the starter motor. The hoses and lines seem intact and there’s no water in the oil and it runs ok as long as I keep topping up. Any help or advice would be lovely,
  • woodyewoodye Posts: 7
    There is a spark plug removal problem in the 5.4 Liter engine. The plugs have a long shank below the threads in a tight hole in the head going down to and open to the combustion chamber. Carbon and combustion crud builds up around the shank below the threads and locks the plug in place. Forcing the plugs can strip the thread since they may not be strong enough to break the buildup.
    I called a lot of Ford mechanics and finally may have found the solution. On a Warm Engine, (most Ford Service reps said Cold engine, wrong!) losen the spark plug 1/4 to 1/2 turn.
    Then spray carb cleaner around the plug. It goes around the threads and breaks lose the carbon and crud build-up around the long shank of the plug.
    I replaced my plugs using this procedure and everthing worked OK. You can hear the carb cleaner bubbling/sizzling, and the plugs came out fine. I used a magnet to pull them out of the head recess and had to wiggle a couple of plugs. Still a pain and knuckle busting job; but, didn't break any plugs.
    Champain makes a one piece plug, the stock plugs appear to be a bonded two piece shank. They are expensive and may not be necessary with the above procedure with a stock plug.
    If you have already stripped the threads, I understand Car Quest has a good kit with a hela-coil to replace the threads, if you can get the broken shank out of the head.
  • I have a used 2003 Ford Expedition and for some reason, the check back up aide message comes on each time I go into reverse, however, the back up beeping noise has only come on once. I have no idea where this sensor is located, or how to go about even fixing something like this. The previous owners did tow a camper, so I think it may have been disconnected, if this is possible. Does anyone know how to find and/or fix this problem?
  • txhill4txhill4 Posts: 1
    We have a 2004 expedition that is doing this exact thing. Where did you find the info to fix it. Any help would be great!
  • my gear lever will not go into park and to turn my truck on i have to put it in nuetral
  • iontrapiontrap Posts: 139
    I'm seriously considering buying a used 08 EB EL RWD with 16,800 miles. Are there any problem areas with the new generation of Expeditions?
  • dieselonedieselone Posts: 5,690
    I purchased a used 07 EB 4wd Expedition back in June. The only issue I've run into is poor shifting with the 6speed transmission (slow to downshift to 1st when coming to a brief dead stop, it would stay in 2nd gear, unless stopped for several seconds). I don't know if it affects 2008 models or not. I had the dealer perform a TSB to reprogram the module that controls the transmission and that fixed the problem. So far I really like the Expe.
  • my 03 xlt has recently started to stall upon initial start up, when i first turn the truck on when it's cold or has been sitting for a while, it hesitates to start, but then kicks over after a few seconds, and if i turn the truck off right after the hesitant initial start up, and start it up again, it doesnt hesitate to start, and it starts right up just fine. HELP, Any Ideas????? :confuse:
  • I have a 2003 Expedition, 5.4L V-8 Eddie Bauer. My wife took it in for annual state inspection and while inspecting the tires the service tech told her the front wheel bearings were bad. He told her that he would have to replace the entire hub assemblies because "you can't just replace bearings like you could in the old days on old cars". So he's charging ~$1200 parts & labor to replace both front hub assemblies. Can't the bearings only be replaced as long as there is no damage to the hubs?
  • Please go to : Ford knows they have a problem with this, this site will tell you all about it.
  • I have a 1998 Ford Expedition Eddie Bauer 5.4 4X4 with the air ride suspension system. I have been experiences problems with the rear dropping. My local mechanic told me that the compressor was probably allowing it to leak off. I finally made the decision to replace the compressor. Yet that did not fix my problem. Let me also say that I hear the compressor running often while I am driving. I does not run constantly but often. While travelling with a lot of luggage in the back, the Check Suspension light came on. I also recently went to have the front end aligned and I was told that they couldn't get it perfect since the back end kept dropping. I HAVE had the bags checked for leaks. Meaning that by a mechanic they have been sprayed down with soapy water which showed nothing. WHAT DO I DO NOW? Someone please help me!
  • Well... Most likely it may be the air shocks goin bad. Ive just bought my 99 expidition a few months ago. When i went shopping for one i was advised not to get on after the year 99 if i didnt have the money to have the shocks repaired. The socks on these newer trucks now come equipt with air shocks. These air shocks on these trucks have a common tendency to go out and cause the truck to drop or just lower down more than usual. Either all around the truck or just in the front or back. This is the reason why i opted to purchase the 99. It does not have air shocks.
  • I have a 2006 Expedition with an in dash 6 cd player. It's broke. It is loaded with 6 discs and when I hit the eject button it says "no cd". If I try to load it, it asks for the position then says "load error". I've tried resetting the fuse, holding the eject button for some time, and simultaneously holding the load and eject buttons together all to no avail. It sounds like it is trying to do something but mostly is just a bunch of whining. One last thing, I had to jumpstart the vehicle this morning. Could that have something to do with it?
  • steverstever Viva Las CrucesPosts: 51,278
    It sounds like you've done all the tricks for getting the changer to work. There's one more but I can't really recommend it (or maybe you've done this already and that's why your Explorer wouldn't start this morning?):
    "6. Against my better judgment, I pulled the same fuse again while it was powered on."
    rbronosky, "Axiom 6-CD Changer" #8, 15 Aug 2008 6:18 pm
    Moderator - Buying questions? Please include city or zip code and trim you are shopping, FWD or AWD, etc.
  • I had the key turned to the on position and pulled fuse 22. the radio went dead and I waited a few seconds (actually fumbled around with the fuse, dropped it etc) and put it back in. According to the manual, it is actually a fuse to the relay which operates the radio. I assume you meant with power to the radio and not the engine running right?
    Right - probably with the ignition on to auxiliary or whatever.
    Mind you, I haven't tried this myself, it's just what someone has posted about around here.
  • Tried it too. Nothing. Probably got a piece of Hubba Bubba in there or something!!!! Who knows. Looks like the dealership is going to get a little money from me (or my kid's piggy bank)!!!
    Thanks for the help though
    If you have a local stereo shop, they may be cheaper than the dealer. It may be cheaper just to put an aftermarket unit in.
  • 97299729 Posts: 2
    I have the same problem after being rear ended. I have found out the module for the system is under the rear bumper. Ford has replaced 3 modules and 3 sensors and when they test the system the modules or sensors fail. Their Tech's are stumped. They have ordered new test equipment for the vehicle. The Ford engineers are stumped too. I have noticed that before the system failed that I could go to the message center inputs and turn the system on and off but since it has failed I can't access this part of the message center. When the vehicle is placed in reverse, the message center states "check back-up aid. When ford fixes mine, I will let you know what they did. I think though that the dealer can turn on the system with their computers but it will cost you. I had my vehicle jump started and battery replaced and they charged me 50.00 to reset the climate controlled seats about 3 weeks later.
  • Thank you for this information, all good to know stuff. Please let me know how you make out with all this so I can try to fix mine. Mine is also doing the same thing, and there are no options in the message center to reset anything either, I've looked at that too. Frustrating!
  • 97299729 Posts: 2
    When I was talking to the service tech. I asked him if Ford was having this same problem with other Expeditions and I was told no. The strange thing about that is he also said that there is a TSB from Ford to replace the module with a modified one. Maybe since there is a TSB. on this system, maybe Ford would replace the module in your vehicle for free. My vehicle only has 2 sensors installed in the rear bumper and the technician told me that my vehicle was an early model 2003 and that later 2003's and 2004's have 4 sensors..
  • I have a Ford Expedition 2006 4x4 and I'll explain something!
    I had a part time whistle when I was driving at a minimum of 10Kmh... After a while I saw the mechanics and he said it was a vacuum problem. Ok up to know there is no link with your topics but there we are! I wanted to select the 4x4high and 4x4low and I was not able. I read your topic and from this one I check my fuses (2 fuses to check) So the mechanic saw the actuator on the right side.
    So $143.00 Canadian for the piece and about 1Hour of labour.
    Finally Thank you my friend and for the others look for it
  • Help! ...I had the exact same thing happen to my cd changer as you described after my Expedition wouldn't start and had to be jump started. Have tried disconnecting the battery for several minutes in hopes that it would somehow reset the computer and fix the problem. Just wanted to know what finally happened with your radio-did you get the problem fixed? Any solutions would be greatly appreciated!
  • Hi There!
    Looking for quidance to replacing a crankshaft sensor on my 2005 Expedition, recent light service at dealer indicated i have a "wet" sensor and it should be replaced. Figure it should be a slam dunk job (a little oil on the o-ring and replace), but don't have a manual or any guide for replacement, any assistance/guidance is appreciated in advance.
Ford Expedition Maintenance and Repair - Page 58 — Car Forums at
