Paint and Body Maintenance & Repair
Wondering what wax is best? Can I really fix tiny scratches myself? Post your exterior questions and answers here!
kirstie_h
Roving Host
Edmunds.com
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Here's a question for ya - I have a choice of the lot, or along the loop road that goes around the condo complex. In the parking lot, the car could get dinged. On the loop road, someone could sideswipe it. Where would you park, given the choice?
Good Luck though !
Truckdude1
I followed the procedure from one of the articles on this website, and it works out real good.
-acd
http://www.langka.com/index.htm#top
TIA
--'rocco
The deal is that the touch up paint is different from the type of paint applied at the factory, and the Langka is a creamy solvent for the touch up paint. So you put a dab of the touch up paint in the nick (using a toothpick works well), then let that dry for anywhere from a half-hour to a day or two, then use the Langka on a soft cloth to wipe it gradually down to the level of the original paint. The kit comes with a flexible plastic holder for the soft cotton cloth, and I have found that it is much better than any other method I have used to touch up nicks in the front of my car.
Sometimes, however, I will take too much of the touch up paint off, and so I have to start over again, so sometimes you have to be patient and do it all over again, but when you get it right it gives a great result.
I have used it on my new black Lexus SC430, and several dings I picked up on the front of the hood from highway stones are now undetectible.
I'd say buy some and try it out. It will not make anything worse, and I have found that it helps make the touch up job easier and with a very good result.
--'rocco
Thanks in advance,
Land Yacht
Lots of other good stuff at this site as well!
Thank you,
Alex
Any help is greatly appreciated!
Thanks!!
Does anyone else have experience with this process? Is there a downside I don't know about?
I think if your repair is going to deteriorate at all, you'll first notice dullness setting in to that particular spot. Maybe it'll be okay, who knows?
for the related questions, I don't believe there is an option unless you are driving an ugly pig and don't care. if you carry collision insurance and the insurance company will reimburse factory parts, I'd rather park on the street than in the apartment lot as the lesser of the evils, except in snow and ice weather.
repairs of a keyed panel don't work out of a bottle of touch-up paint, I tried it. you have to fill the damaged area, level it to the paint, and repaint the panel to have a quality repair. that generally means a professional.
I had this car for only 200 miles and was unlucky enough to have a small rock bounced right onto the front to create a small and deep scratch point (0.2 x 0.1 inches). The paint color is midlight blue metallic (almost black) and the scratch point reveals white/silver color underneath.
I have taken the advice and tried to remove it with alcohol but it failed. I am guessing now the white/silver is metal. The question now is how to protect it from further damage such as rust.
I am kind of guy who like to learn stuff and do most of the thing myself. But I am total newbie and this is my first car. I have read about touch up paint but it is really unclear how to do this. Could anyone please help me out with detailed how-to (hopefully, there is some webpage about it)?
just for grins, I would start with a Q-tip and pure alcohol of the isopropyl or ethyl variety, and work it gently around in the hole with a spin to be sure there is no wax there and that it is dehumidified. use both ends of the Q-tip, and when it's dry, use another one to be sure there is no wax in there.
next, get a 3M "rust remover pen" at the CSK, AutoZone, or whatever... also get a Dupli-Color primer brush-in-cap bottle, and one of clear topcoat, and one of the color code of your body paint. on the door label of the car, where the cryptic codes from Hell are all listed, is one probably near the middle-bottom that says BODY COLOR or something similar. it will have some nutty code number like 4XC. that in the Dupli-Color catalog for the right year and model of car will usually yield a stock number for the right color of paint.
if the corner parts store doesn't have yours yet, go to the dealer's parts department and get the primer, clear, and color brush-in-cap bottles there to be sure, S U R E, that the chemistry is the same and this won't pop out in a day.
if you can't find the 3M rust remover pen, shame on that store... but you can use the (formerly duco) Loctite rust binder and a toothpick instead. the 3M variant has the equivalent of a toothpick fractional-drop dispenser built into the tip (and yes, they are locally based and help pay friends, thanks.)
put enough of either anti-rust product in the chip to color the metal and let it dry real well, several minutes. if there was any rust starting, it will turn to black polymer and stick, and the surrounding product will probably remain a brown or beige color.
now put a little drop of well-shaken primer in the chip the same way. you want a nice, smooth, even grey but don't try to fill the whole chip. you will just want primer to bond the paint to the polymer anti-rust.
slowly build the chip up near level with repeated small applications of extremely-well shaken (actually, tipped end-over-end is better to avoid bubbles) color paint coat. there are probably 6 layers of paint and clear coat in a factory finish, all extremely thin except for the top clear coat. which should tip you to what's coming.
when it's time for the clear coat, if the chip is really large, you could try the brush... if you gob or glop the stuff all over, quickly take a good lint-free cloth like a well-washed T-shirt rag that has been pre-soaked in the alcohol and wipe the whole gob off. if you take up the paint in the chip, do that over... if it has really set, you won't.
once the chip is filled in with the clear coat (it will tend to be high at the edges and thin in the center, or vice versa, depending on how you applied it), let it set without washing or waxing for a week or so.
then gently wash with water and a soft cloth, see where it is too high, and if you are really fussy, and feeling well in control of fine strokes, make another trip to the parts store for some fine grade polishing compound. NOT polish, "polishing compound." there is a coarser stuff called "rubbing compound" that will leave big gouges when you buff the repaired area unless you are really, really good. if you're asking > ME < about how to do this, you ain't. and I ain't.
on a very nicely soaked cloth, pick up a wee little bit of polishing compound, say the size of a pea, flick off half of it, and gently, ever so gently, rub the repaired area and the area around it occasionally with the compound. try this first on a piece of scrap plastic of some sort to get a feel for how to lightly smooth a surface without having it look like it was levelled with swings of an axe. clear is best, because you ARE working with a thin piece of clear plastic in the car's clear coat.
and that's how it's done. will it match excellently? alas, no. will it look like it was smoothed with a sledge? hopefully if you're careful and play with a piece of scrap plastic first, it shouldn't. there's a craft in the work that you will have to develop... pity the first hack in the car wasn't down by the rear fender, so your training wouldn't be noticeable... but doing the job first on junk hard plastic should get you cautious enough.
good luck!
As I tried to sand away the areas with loose paint, the damaged areas got bigger because the outer edge continued to crumble away. What should I do? I have had my bumper repainted and baked before. After a while, I got tired and just sprayed the bumper (paint surface unmatched).
Later, I got myself a putty. Can I use this product on a plastic (rubber?) bumper? Its instruction says to wet sand it to match the paint depth. Your suggestions would be very much appreciated.
anything that goes onto that bumper cover will have to have a flexible base, which can either be met by special chemistry with a long MSDS, or a flexible plasticizer additive that is similarly too ugly on the regulatory front to be sold in the baby-food aisle at the supermarket.
I personally don't think this can be fixed outside a properly equipped body shop... and they won't try to fix the cover if it has any damage, they will order a replacement and repaint to match with a diddled paint.
another triumph for longevity and value, these plastic bumpers that won't take bumping.
good artist, though, on the "artists' conceptions." almost as good as the guy who drew the hammers, lightning bolts, and winces for the 1960s Anacin commercials. if I had hammers, lightning bolts, and winces in my head instead of clogs in my arteries, I would visit museums and pay any price for a 1960s bottle of Anacin.
a bottle of good liquid wax is under $10. you can buy a roll of flannel polish towels for $4. Use them as directed. that works as advertised.
Here's the deal: The dent is large, but there are no sharp edges to the dent (if that makes sense)and all of the paint is intact. It seems as if it could be popped out pretty easily.
So should I try it myself? If so, how would I go about doing it?
The car is a very simply built toyota tacoma with manual everything, so there shouldn't be much between the door and the sheet metal.
Should I just leave this to the pros (in other words, live with the dent since I'm broke)?
Scroll down to the KD2761 ($18.61) device.
I would think you could go to a large tool warehouse near you, buy a similar sized suction cup, try it and return if it doesn't work. I don't believe you can make the dent worse by trying this.
Good luck!
notice the copy next to the picture says it will pull almost any dent that didn't crease the metal. that's a big gotcha in pulling dents, because once there is a hard crease in the bottom, you have expansion, paint damage, and the crease reinforces the new shape of the metal and strengthens its new path. at that point, you pull what you can, and putty over the rest and refinish.
matched bumpers that show every scratch and chip and since I live in a large city I've been hit enough times for me to consider having the rear bumper repainted. My car wash place fixes this type of problem and will completely redo the bumper for a nominal fee. However I don't want to make this a repeat situation and was wondering if anyone out there knows of a company that makes attractive color-matched vinyl protection strips to solve this problem?
Any advice would be most helpful. This is making me sick!
Dishwashing soap, especially the high alkaline kind like the unscented "blue" Dawn works well. Maybe even give it a couple of washes.
If the finish is still hazed, try using a polish/glaze and a good orbital buffer with a foam pad. These are not waxes but mildly abrasive compounds designed to remove a very thin amount of finish and surface oxidation. There are professionals that will do this for you if you want.
Or go to a good auto paint shop and see what they think.
However, I think that chances are good you are seeing some oxidation of the paint. Depending on how deep the oxidation goes the fix could be easy or realy difficult. A little polishing to remove surface oxidation, or as you suggested, repainting. A good paint shop could help sort that out.
I do wonder if it is paint failure from the manufacturer if after 4 years and 41,000 miles if Mitusishi would provide any compensation if repainting is needed?
~Spyderturbo
The other day, my 02 Sienna CE was rear-ended. I was stationary with my foot on the brake, waiting to turn a corner, when a 97 Rav 4 bumped my rear. The impact was quite strong, but not enough to do a big damage on my bumper. It held up well and there was only a slight dent on it. I already had the repair done on it by the dealer who informed me that they did not note any serious structural damage on it or the chassis/body, so there was no need to replace it.
I am curious to know if the rear ender might have caused any damage to my tranny, brakes, steering, wheel alignment (my front wheels were positioned to turn) or others.
