Honda Odyssey: Problems & Solutions:(1995-2004 Models)
My 99 Odyssey has always lost coolant from day one and it now has 30K on it. When we picked it up the coolant was a little low so when I did the first oil change at about 5K I had to go and buy some Honda coolant and add some. About every other oil change 6K the level is about 2" low in recover tank. Want to pressure test but my tester only fits older large neck radiators. I know with 20psi on a hot system the gauge would have to start dropping. While for now I will check the base of EGR valve. Hope these Eng. are not know for Head gasket problems?..
Your welcome hope all works out for you.Good luck
yewlock
These service bulletins are for known problems with cetain vehicles but do not mean all will be bad. So if you aren't experiancing a problem then you most likely don't need anything.The bulletin is for a noisy ac rattle that gets pretty loud..
http://www.handa-accessories.com/odyssey/drift.pdf
2004 Honda Accord EX-L Graphite Pearl
2007 Honda Civic EX - Atomic Blue
2013 Honda Civic LX - Crimson Pearl
good luck
rockycow
mschafer: let me know re the timing belt; would like a "ball park" figure to save for!
great van
macody
Mileage:
Our '99 was fairly consistant, delivering mileage 18 to 24 in mixed suburban driving to 29 mpg on straight highway. The 2001 gets as low as 14 to 21 in mixed suburban driving. I had it on the highway today for 127 miles and topped it off, getting about 32 mpg for the trip. This can't be right and I should check to see if I really filled the tank. The gauge is pegged at full though.
I'm trying to decide why the mileage isn't as consistent as with the '99. My one thought is the AC is constantly on since the climate control is set to full auto all the time, causing the lower "city" numbers. Also, I seem to nurse higher mileage numbers from it but then I use it on more highway trips while my spouse is "garage saleing" on local streets.
Noise:
Last week, after starting the van, a loud gear grinding noise came from the right front of the van. This happened about two times. The only consistent thing about each time was the van was sitting in outside in 85plus degree heat and seem to coincide with the AC kicking in. I drove the van about 350 miles this weekend in 90 degree heat and did not hear the noise. The AC worked normally. I made an appointment with the dealer but if I can't recreate it, I'm not sure what they can do. Is this related to the idler pully or a compressor on its way out?
Otherwise, the van runs well and we've had no problems with the power doors, pulling to the right or transmission thunks. And more often than not, people will stop us to look at the magic seat and ask questions about the van.
1. Fill your tank. Do not "top off" after the pump stops.
2. Reset the trip odometer.
3. Drive it until you get the "low fuel" light on your dash. This should be at least 300 miles on the highway.
4. Stop at the nearest station and refill the tank again. Do not over fill.
This will give you better indication of your true highway mileage, plus you will know how much is left in your tank when the low fuel light comes on. Just subtract the number of gallons you pumped at the end of your trip from 20 (the tank capacity).
Hope this helps. As for me, I've had my '01 EX for 2 1/2 months and have taken a few long trips (6200 miles). I saw 14-15 MPG city and 20-22 MPG highway in the first 2000 miles. I now get about 15-16 city and 22-24 highway (I have a bit of a lead foot), and would expect another 1-2 MPG improvement over the next 10,000 miles.
As for the sound, my wife and I heard it for the first time yesterday. The same situation you described. You didn't say, but we also had the rear A/C on, and I wonder if the sound might be from the rear A/C compressor. Maybe some of our more technically savvy subscribers can comment on this.
I don't like "Packages" (Read PACK the price up), so I guess I'll check out some others. DUTCH
1) If we stop at a light on a step incline and take our foot off the brake, the van will roll backwards. Our dealer tells us this is normal (for all cars) but I can't recall any of our other vehicles ever doing this.
2) Our gas gauge reads empty and the light comes on with 6-7 gallons left in the tank. Is this typical?
Of course both our doors stick.
Thanks for your help.
Thanks in advance.
1. No, the Odyssey's transmission will not hold the van on a steep hill - or any hill for that matter. It really has to do with torque in first gear at idle RPM. Remember, this van is well over 4000 pounds, so the tranny will not completely hold the car when the majority of that weight is pulling against it.
2. Yes/No. The most common point is with about 5-6 gallons remaining. If you have 7 or more gallons remaining, you may want to have that looked at.
johnnyrf:
I just had my 30K service done. It costs about $350. Is it necessary? Yes and No. The van was running fine, so from the standpoint of was anything urgently required, then the answer is No. However, I've always made it a point to get the scheduled maintenance at the dealer for the duration of the warranty period. That way I always have solid ground to stand on if anything goes wrong. In some cases a warranty claim for certain components can be disputed if you can't prove that you've performed routine maintenance on the car.
My gas light goes on with 4 gallons left. Varies form vehicle to vehicle. The flat design of the gas tank that makes room for the fold down third seat has been speculated as the reason behind inconsistant readings.
Everybodys Ody rolls backwards on inclines, just have to get used to it.
Welcome aboard, these things are minor in scope, your doors will be fixed eventually. Its a great machine, wise choice.
either up a steep hill or down a steep hill, the
Fuel Emmissions light comes on.
Honda dealer keeps on telling me this is "normal",
and it will fix itself.
They first suggested it was due to me not clicking "at least 3 times" the gas cap everytime I fueled. Of course, I do this and I still see this light..
Has anyone experienced this...and, most important does anyone know of a fix????
mac
1) Defective Winshield Moulding (required replacement of windshield 3 TIMES!)
2) Leaking Rear Shock Absorber
3) Numerous recalls include:
Gas recirculation Valve
Front Brake Pads
Sliding Door Mechanism
4) Sliding Door repairs
5) Rear AC Control defective
6) Door Lock Repair on passenger sliding Door
7) Out of Round front alloy wheel
8) CHRMSTL rear light burned out after 14 months
9) Shimmy at 75mph +
In addition, these complaints:
Horrible Original equipment tires (Firestone Affinity)
Truly Inferior Stereo System
Paint Finish on par with Hyundai
Sheet Metal aluminum Foil thin
Mushy Brake Pedal Feel
No Compass or outside temperature display
I currently have about 33,000 mileson my Ody and it definitely needs new front brake pads. despite all the above, I would consider getting another, because I enjoy the way the vehicle drives and handles.....when it's not in the shop!
I was just wondering why Honda. pulled the tab's off. I have a 2000 Odd. I have had some problems with it but they have all been minor.
In addition,I own a number of vehicles. Just because I don't list all of them in my profile, doesn't mean I don't own them. Also, why would I own another Honda product (Aura) if I am a I/I advocate?
My complaint about the compass and outside temperature unit, is one of lack of availability in the Honda. No, I choose not to have to spend $2000 extra to get that feature in an Odd!
By the way Matt, Navigator is spelled this way...........
Did you realize your risk in buying the '99 Odyssey at the time? NEVER, ever, buy a first year model regardless of whether it is import or domestic. They always have problems. However, I am confident that Honda is on the stick about this, unlike DC. Heck, they had a 10 year head start and still can't get it right! Of course this probably is no consolation to you. So, are you going to stop buying Honda's? just curious.
Regarding the compass and temp display, did you consider aftermarket? Several Ody owners have installed the Donnelly (sp?) mirror for about $200 and are satisfied with it. E-mail me and I'll give you the website to the owner's club (not Edmunds'). Good luck.
Matt or is it dmathews/at least don't call me late for dinner.
P.S. 28K-35K miles for brake pads on a 4500 pound car/truck is pretty normal. I had mine replaced at 28K.
P.S.S. How did you find out that Matt is Dave's long lost evil twin?...
Regarding the other feature or lack thereof, on the Ody: If Honda wants to compete head to head with D/C, then they should try to match feature for feature. Quality levels on the paint & the sheet metal is superior on the D/C vans. Panel fit & finish on the Ody. is superior. Any stereo on the D/C vans is far superior to the EX stereo on the Ody. Brake Pedal Feel? D/C superior. Ride Quality? D/C superior. Interior Noise Level? D/C superior. Handling? Ody superior.
Rear seat configuration? Ody superior. Overall Fit & Finish? Ody superior by a hair.Original Equipment tires? D/C superior. Remote Key Fob operation? D/C superior.
Lastly re: recalls: Not all the Ody recalls were minor. Some of them could pose a fire danger, or risk to my kids, such as falling out the vehicle thru the sliding doors............
Again, all of these issues would probably still not prevent me from considering another, especially since newer Ody owners seem to have less problems.
One additional note about time and energy in fixing these problems. Check with your dealer to see if they provide loaner cars. My dealer has a set of loaners that if I ask when I make the appointment, I simply drop off the Odyssey and use the loaner until I pick the Ody up that afternoon. The only catch is that if it's not for a warranty issue I would have to pay a $19 rental fee. But so far mine have all been free.
Mild door stick problem first week of ownership; fixed @ dealer; no other problems since. Van runs great, stereo is "bearable"; replaced firestone tires with Michelins in December. Have done all our own scheduled maintenance; van runs great and has met all our expectations.
Previously had a 95 Windstar (don't EVEN get me started) and 90 Caravan (also don't get me started). Nice to have a van that I don't have to pray over each morning .
mac
Honda is a COMPANY that makes products...they are far from perfect. I am amazed at the remarkable ability by some of you readers to run to the defense of Honda, even when they make errors!
To the respondent who said my kids should be buckled in, so they don't fall out when the defective power sliding doors open without warning. Did you have the same response when 20/20 did a scathing report on Chrysler, regarding the rear hatchback that would break open when rear-ended and some children were ejected? After all, if they had been belted in, they would be alive today. Let's see 20/20 or 60 minutes do a story on the power door problems on the Odd that WILL inevitably lead to a disaster. How about right this minute, I can't open the sliding door on the drivers side, manually or otherwise. What would happen if G-D forbid, I was in an accident this weekend, and I had to get my kids out, and the other doors are jammed..........
Yea, keep defending Japanese companies, as though they do no wrong. Yep, it's only those greedy American car manufacturers who do everything wrong........NOT!
No one here is defending Japanese companies, and for goodness sakes no one believes they can do no wrong. ( It's really those Canadians - they built this thing ;-) ) Read the title - this is the Odyssey PROBLEMS forum. We've all had problems. And we come here to talk about it - hopefully to help others or get help in addressing the problems we have. But it is people who start with the "Odyssey Sucks" banter that gets the rest of us riled up. Nobody makes a perfect car - nobody. I'm sorry you've had problems, but believing Honda is a horrible company because they have recalls doesn't make sense. And I just don't see the comparison between a sliding door that opens and a vehicle that self destructs on impact. I drove a Jeep for years without doors (hey, they made it that way!) and didn't fall out - because I was buckled in. And yes, as a matter of fact I DID say during the 20/20 report "were the kids buckled up?" As i said previously, the reason you see reports on the D/C and Ford recalls is because it took many people's deaths to get those recalls enacted.
Now I'm also curious. After 15 years of problem free D/C vans (10 of them no less), why the switch?
-respondent
Honda seems to be on the right track, again-Finally! The Oddy, the current generation Accord, the upcoming Honda version MDX, and the total revamping of the Acura line-up is proof that Honda is awakening. They will be moving on up in the US market in the next few years, leaving quite a few competitors behind- as long as they keep revamping their product line to reflect the tastes of the American market-their biggest.
In answer to your query Re: why the switch to Honda after owning D/C vans for so long? I saw the Honda Oddy prototype at the Detroit Auto Show in early 98, then I saw an actual production model at the NY Auto Show in April 98. I was impressed with all the features, the look and the overall SIZE. I also had been finding that the resale value on my D/C vans had been falling pretty steadily in the late 90's. Additionally, I no longer was driving a minivan myself, but my wife was, and she said she would like a change, after driving so many D/C vans for 15 yrs. I figured the Oddy would be a hit, and it would probably command a higher resale value, and I turned out to be right. I put a deposit on one in May 98 and took delivery of the first one that arrived at the dealership, luckily it was a color I wanted.
Lastly, the 20/20 reports never showed a D/C van "self-destructing" as you put it. The rear tailgate opened up on impact, how does that constitute "self-destruction"?
>> about Honda in the last 6-8 yrs
>> is that they often misjudge the
>> American market, and as
>> a result release vehicles that
>> are just not competitive
What?? I don't know where you live, but if I had a dime for every Accord, Passport and CRV I see around here I'd be rich. Granted, the Prelude missed the mark, but I think the track record is pretty good. Now with that said, I'm not a "Honda" person. Hondas are always utilitarian - very basic interiors, cheap sheet metal, etc. - but very functional. Personally, I like Mazda (as a complete line) better - but the MPV is too small and underpowered. If it were the size of the Odyssey, it would be perfect. But the Odyssey is a very nice vehicle. I wouldn't trade it for any other van on the market today.
