I can't really throw any ideas out there, could be lots of things and since it's brand new likely just has a bad sensor, or fuel issue. A dealer that knows the diesel cars won't have a problem figuring it out.
Thank you for your input.
Charles in Indiana
Glowplugs are easy-peasy to check with an ohmmeter after pulling the connectors off. (Any that are an electrical "open" is bad) To replace, they screw out just like a sparkplug.
Also, the most common reason for starting issues is that the injection timing is incorrect. You need to connect your car to a computer to check this. You may find somone near you with a VAG-COM that would be willing to check it for you. (Edmunds rules forbid me from posting the link here ... Search the internet for "VAGCOM list")
Update on my problem: I have replaced both power Supply relay and Glow Plug relay.There is fuel going to injectors but still no start and no power to Glow Plugs.I tried VAG COM with just ignition on and all I get is "No response from Controller" Any ideas? Is my ECU shot?
I am having a problem with a 2000 TDI I bought about 3 months ago. It is low mileage....55,000. The car runs great, very peppy, no smoke, good mpg. About once a week it will start immediately & smoothly, then stall, as if I shut the key off. It will do this 6-8 times, then start as if there was no problem. No hesitation, no burbing, nothing. It DOES NOT matter if it's cold out side, or if the engine is cold from sitting overnight or hot from just being turned off. I've done some reading....there are a ton of differant things from improper injection timing, to glow plugs to just something loose or needing attention, like a seloniod. The other day it really acted up...took 30 minutes to start (I walked away) then returned & drove off like nothing happened. Any ideas...suggestions? Many thanks...
How much are you paying?
For example-- an Oxygen sensor may flag a fault if there is too much fuel is injected.... this DOES NOT mean that the O2 sensor is "bad". (somthing else caused the extra fuel to be injected) A diagnostic tool is just that-- a TOOL that must be used with some skill and knowledge about what is being diagnosed.
You really need to get a diagnostic tool DESIGNED for Volkswagen. I use VAGCOM myself. Please read past appends on how to locate a VAGCOM owner near you. Most folks with a VAGCOM are happy to help out a fellow TDI owner.
Yes, I am sure. I specifically asked about oil change only.
I also checked service schedule, it's only oil change, filter and drain water separator for 5000 miles.
That's quite a difference compared to $80.
I called second dealer nearby in Mount Prospect, IL and price is $75.
Do they have some kind of MSRP for the service? If yes, then what is invoice? Did anybody manage to negotiate lower price?
On my 5000 mile service I am looking at the bill. It was $50.63 including tax. Oil was $22, filter $6.89, labor $17.50, waste disposal $2. I think that was a fair price.
I also bought the oil removal tool that is recommended and would have done my own except I am selling this car and wanted dealer service records.
Basically, there is a sensor at the oil-filter (beginning of oil-system) and there is a sensor at the end of the engine (end of the oil-system). (also senses for too LOW and too HIGH pressure)
Depending on the "status" of these sensors, the oil light may be on/flashing and may/maynot be accompined by an audible alert.
There was a 'run' of whimpy oil-pumps... but for now, lets assume your problem lies elsewhere.
The #1 cause of the problem you describe is due to using the WRONG viscosity of oil.
Also, I have personally seen cases where the hydrolic lifters get cruddy and the pump cannot maintain oil-pressure. In theses cases, I have found that adding STP OIL TREATMENT has fixed the problem.
I have also seen cases wheras the oil-pressure sendor(s) were inaccurate. (It is easy to uncrew them to replace them)
Of course it is best if you get the oil-pressure checked using a calibrated meter. (just to make sure the oil-pressure is OK)
I used it in my snowmobile and promptly burned it up. Never again will I use Amzoil trash.
Good luck!
The MOST COMMON reason for glowplug problems on the TDI engine is the WIRING HARNESS that feeds power to them. It is highly recommended that some kind of conductive grease be applied to connections to help reduce corrosion.
Next, the check engine light comes on and the dealer indicates that it is due to sulphur build up as a result of reformulated gas here in S.E. Wisconsin. He recommends using Diesel No. 1 fuel in an attempt to burn it off. Then go back to Diesel 2.
The car has 41,000 miles. Anybody experience these types of problems or can suggets solutions?
gordy
Since this is a KNOWN problem that some TDIs have seen, a good dealership would just REPLACE THE "watercooled EGR" under warantee. (just to eliminate that as the issue)
I am somewhat surprised that your dealership has not better researched this "mysterious losing coolant" problem... the VW technical support system should have immedeately pointed them to the "watercooled EGR".
DEFINITION: The EGR (Exhaust Gas Recirculation) system pulls some of the hot exhaust gas from the exhaust system. This is routed thru a heat-exchanger (surrounded by flowing antifreze) to cool it off. The cooled exhaust gas is then fed into the intake system to be consumed by the engine again.
As far as I am aware #1Diesel and #2 have the very same specifications for sulpher-content. (until the ELSD specifications come into effect)
The downside to using #1Diesel is that it is NOT APPROVED by Volkswagen for use in the TDI engine. It is closer to kerosene in the way it is refined thus has reduced lubrication-qualities. The lack of lubrication can SERIOUSLY damage your fuelpump and injectors.
Perhaps if you tell us the actual code that the CEL is giving -- we may be able to point you in a better direction.
gordy
Thank in advanced.
Ballina
So I drove home. I took city streets instead of the freeway. Turned off the radio and drove without the heater on. The light stayed on the entire trip. I parked the car and left the problem for Monday.
I was not going anywhere over the weekend so I left the car sit.
This morning I went to start the vehicle and it would not start. The starter seemed to crank the engine once or twice, then nothing. I attempted to start the engine a second time, and nothing, not even the sound of the start cranking. I waited a minute and tried a third time. This time, I heard a rapid-fire crackling/snapping/popping noise that sounded like a toy machine gun. The instrument lights blinked on-off in time with the noise.
Thinking the battery had died, I tried to jump start the car, but to no avail. After 10 minutes of getting power, I tried starting the Golf with the exact same results as above.
I've got 50,233 miles on my Golf. The warranty is 4/50,000 and while I believe I have a few more months on the warranty, I am over the mileage limit.
Any ideas on what is going on here? Any ideas how to fix it?
From a cost of ownership standpoint/reliability standpoint, which one of these is the keeper? The TDi may not loom as large as for some of you since we're only driving 7-10K a year.
thanks for whatever insights y'all can provide.
Leave the TDI's to folks that drive a lot!
Is it better to buy TDI engine if travelling up to 15000km per year or better get FSI engine?
Is it faster to damage the TDI engine if travel around 25 mins per trip?
If I am getting TDI engine and travel less, I need to change the oil every one year instead of waiting for the service due that is probably two years or 1.5 years, is this true?
Thank you for your opinion and help.
Iwn
25 mins per trip is plenty to warm up the TDI - so no worry there.
after the initial oil change or two, the oil change interval is 16000 km, so one oil change per year would work fine for you, after the first year.
