Chevy S10 - GMC S15 and Sonoma Accessories & Modifications
on the dash. where do I get the inward pulse to the tach.
some one told me that the wire is by the coil. then another
person told me no that would burn my tach up----he said it is on the ECM. I just need a real anwser I dont want to burn up a $150 tach or the ECM .........HELP!!!
Damo
Damo
Performance isn't cheap, especially when you are starting with the engine you have.
My preference would be to swap in a sb Chevy V8. Not inexpensive but probably the most bang for your buck.
Damurf
Check out SLP Engineering. They have wheels & wheel/tire combos that will fit. I was thinking of getting a set of the 5 spokes like those from the Camaro SS, which were used on the Corvette. SLP has a set similar to these for the S10/Sonomas. The Corvette/Camaro wheel may work, but not sure of the backspacing as well as the center opening for the wheel bearing (front). Check them out, also Discount Tire. The bolt pattern diameter should be the same, like 4-3/4".
As for having to have truck tires since you have a truck, as mentioned in the other response, that's BS. I have a 99 S10 with ZQ8 suspension. The wheels are the same as those used on the 3rd Gen Z28s (5 spoke, the center cap is slightly different, it's flat with the bow-tie emblem) and the tires are 235/55TR16 Eagle GAs, from the factory. And no tgun275, "T" doesn't mean "Truck". These were also used on the Sonomas with the ZQ8 option. When it was time for replacement I picked up a set of 245/50 Yokohamas, keeping the overall height pretty much the same as with the 235/55. Hell, one winter I switched off the tires on my 66 SS and put on the truck (those GAs wouldn't have gotten me through as they were wearing in the rear) and they bolted right up (15 x 7 wheel, 245/60 T/A tire). Your main concerns are backspacing, width, bolt pattern, overall height of the tire/wheel package, and $$$. I believe you can go up to as much as an 18 without too much trouble except the sidewall will be really thin, like a 40-series profile.
Me and a few buddies came up with this crazy idea of painting it with Rhino liner insted of paint, all black with chrome grill, bumpers, black 5 spoke rims low pro's with chrome dishes. I personally think it would look pretty crazy, what does everyone think?
kcram - Pickups Host
i typically get only 15-17 MPG. knowing that the Blazer equivalent can get as high as 22 MPG, my questions is: has anyone switched the gearing on a ZR2 with a Blazer? Both vehicles have the 4.3 liter V6, yet one does considerably better on mileage...leads me to believe it's a gearing issue.
I'm not sure how similar the interiors are, but the Izuzu pickup is almost identical to the S10 (they were both made by Izuzu).
So having said that it is no surprise that the truck is having problems like the trannie and the tires. I know you like your look, but unless you really like paying for tires, than you might do well to raise the truck back up. I'm not surprised that you can't find anyone to align it for you, but at the same time since the suspension has been modified, it will be very difficult to keep it aligned properly.
Basically - when you lowered your truck you screwed yourself as it was never designed to to do that it the first place. Sure you might think it looks cool and might be good for trucks that are only in shows, but it's definatley not practical for everyday driving and everyday use...
