DD
The wipers I'm not an expert on either, but there if you remove the cover from the engine compartment you might see something amiss.
Turn the ignition key to accessory, run the wipers on intermittent, then turn the key off when the wipers pause (which should incorrectly be "up" instead of "down"). Open the hood, pop off the plastic wiper motor/crank cover. Then loosen the crank arm on the wiper motor, manually set the wipers "down" where they're supposed to be during the pause (don't let the motor turn when you do this), retighten the crank, then turn the wipers on again. That ought to reset them. Put briefly, the governing circumstance is when the wipers are pausing between strokes while running on intermittent cycle.
I can't complain, the car was very inexpensive to purchase and has been very reliable. I was more than aware of the intake manifold issue and the trans issue when I purchased the car. What a great car for the family.
I think so, but am not sure. Mine were only weird at shutoff if I remember correctly.
New intake manifold gasket
O rings
Thermostat
Spark Plugs
New Wires
New serpentine belt
Cooling system service
Oil Change
Read and clear computer
$898.00 out the door
I didn't buy the extended warranty, I'm miles ahead on the cost of that. The car would be out of extended warranty anyway. Now the van should be good to go for 3 or 4 more years when we will be done with it.
My dad just had the intake manifold gasket replaced on his mid 90's Grand Prix with a V6 (3.1?). It was not covered by warranty and cost $1,000, but they did give him a free loaner car for several days.
If there are any GM engineers out there, please design the important stuff to last or you will lose all your old customers to Honda and Toyota. And could you also design a van that is easy to service.
I like the Silhouette overall and it was the best value when we purchased in 2001, but it is definitely high maintenance. Thankfully, my wife is not.
The Hondas blow transmissions, the Toyotas were blowing engines...All cars require maintenance. (so do wives).
This van has definitely taught me that some vehicles, or types of vehicles, are better than others. Economy cars, like my 1995 Mazda Protege that I bought new, seem to be better engineered and have fewer problems. After 180K miles the car still works great with no leaks or serious problems. Even the original clutch is still fine after pulling a 400 lb. ATV and utility trailer for the last 6 years. I only wish the Silhouette, which cost twice as much, was as reliable as the Protege.
We bought the van off-lease about 3 years ago with 40K miles on it and have only put 30K on it since then. Besides burning oil since the day we bought it (about 2 quarts between oil changes and the mechanic could not find a reason), our van also had the following problems, most of which did not pop up until after 60K: About 6 months after we bought it, ABS brain went out ($800), our power steering pump developed a whine (although noisy and annoying, it never "broke" so I did not fix it, then the electronic door locks went out (did not fix), then the flapper that controlled the heat got "stuck" and would not always release immediately (did not fix), then the liftgate strap broke (did not fix), then the tape player stopped working (did not fix), then the infamous intake manifold went, then the lighting harness on the rear stop lights broke, then a lifter failed ($800). The final straw was when the head gasket blew last month and we had to put $1400 in to it to fix it so we could get $4k out for a trade. There are other things I could list, but I do not remember all the nickels and dimes this van took out of me.
The mechanic said the 99 Venture has just about more TSB's than any other car he works on regularly and his parts supplier tells him that the Venture family gives him more than a fair share of the busines - all of this with no support or ownership of the problem from Chevy.
It is a shame that such a great and flexible van could be destroyed by such poor mechanicals. I would not buy another Venture and, based on what I have read about my problems with reliability not being unusual I would not recommend my friends to. My father-in-law has a Venture and my sister-in-law a Silhouette and I have convinced them to dump them (they both have under 60K) before the problems start.
This is my first time writing on this site,but I found it because I'm service manager at a private garage and deal with these vans on a regular basis. The reason I came to this site was because my mechanic and I wondered how many "I hate Montana sites" were out there.
Pontiac Montana's,& Chevy Ventures are the van of Choice for comfort,performance...for the first 3 years of there warranty,after that they are a joke. At our garage we joke that we will name are kids after these vans since they are going to essentially pay for there way to University. I have a 2001 Montana on a hoist getting a headgasket,I have one outside waiting for a new wheel bearing(which contains the wheel speed sensor for the ABS/Trac light),tommorrow I have one coming in for a new rear wiper motor and another for unexplained coolant loss(likely intake) If any custome asks me what to buy for a used car,I specifically tell them not to buy GM. Don't get me wrong,the more of these vehicles people buy,the more money I make,but after a certain point it gets ridiculous.
Also in case your Oldsmobile didn't come with an owners manual, look for Helm, Inc on the web to order one, or register with mygmlink.com and you can get online access to one.
The side rear stoplights stopped working on my Venture last week, but the center high light is fine, this sounds like the same problem. Does anyone know if this is an easy fix? I'm inclined to do it myself.
Power Sliding Door (PSD) Re-Initialization
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated, the power sliding door system(s) must be re-initialized.
Re-initialize the right or left power sliding door systems using the following steps:
1.Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
2.Manually open the power sliding door completely.
3.Manually close and latch the power sliding door.
4.Turn the power sliding door ON/OFF switch to the ON position.
5.Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
6.Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
Just a response to this - I am sure being in the business you know there is always break downs on every vehicle. This gm story has to be looked at yes , but remember they out sell everyone by twice as much. Which means you see more of them- I do own 2002 venture - And have seens this before- but now a days you have to protect yourself and take extra warranty. And also remember if your had a bad experience with GM does not mean everyone has-
My experience is vast thru out all manufactures. AND trust me they all break down. They all can be a joke when you think of it.
Thanks for listening
Ventman
With only 35,000 (gentle) miles, my transmission has started slipping. I took it into the shop last week and was told that a rebuild was necessary ($2,500.00). I called the local Pontiac dealer and was told that since my warranty had expired (out of time), I was out of luck. I guess it goes to show that if you plan on buying a GM, you'd better invest in an extended warranty.
We went deep into debt to buy this van, hoping that it would offer reliable transportation for our family for years to come. I'd expect a small repair here and there, but loosing the transmission at 35,000 miles wasn't something we were expecting.
Hopefully, GM will cave to the competition’s push for better warranties and either improve their quality, or extend their warranties.
Any advice or help would be appreciated.
Jeff
Jeff
I think the place you reconnect this is 1/2 way up the tank on the rear washer motor. Mine also fell off - suggest a small zip-tie or thin wire that can be "bread bag twisted" around the hose on the connector.
I know the washing fluid tank has two motors on my '98, one about 1/2 way up and the other at the base. The one 1/2 way up is the rear, so you won't jepordize your critical front windscreen viewing my over-using the rear - so keep it full.
DD
I asked about Honda, Chrysler, Ford, he laughed. He said "I see 'em ALL" - "eventually, they will all fail".
GM has quite a good reputation for building a great transmission, so the early problems you are having are quite abnormal.
Things to check -
* fluid level, engine running in park, warm, level
* if level is low, look for leaks
* change filter and fluid as suggested, see if that helps. Use correct fluid.
Good luck, let us know how it turns out.
DD
To little fluid (at least 1/2" below add mark} will cause slippage or no car movement (racing engine). Too much fluid (more than 1/4" above full mark) will cause air bubbles or foam in the trans fluid which will cause your trans to slip or shift erratically.
If fluid level is correct, then I also suggest getting a trans fluid flush/change.
If the previous steps don't resolve your problem, then take your Montana in for a second opinion.
I had recent bad experience's with my once trusted neighborhood mechanic;
Last year I had many engine misfires in cylinder 4 on my 97 Buick Lesabre. After doing diagnostics my mechanic said that I needed a new engine at about $2500. Hoping that something else was causing the misfire diagnostic code, I did a lot of research on the internet and decided that there was a good chance that #4 fuel injector was clogged. Had it replaced at Pep Boys, they where the cheapest at $180, and problem was fixed.
This year I noticed that the starter was skipping/pausing when starting my Olds Silhouette. Mechanic said that I needed starter to be replace for about $350, so I decided to try and do it myself. First step is to disconnect battery cable which I found to be a little loose, so I tightened it and problem is now fixed.
On the way home last night, the transmission went out. There was a bit of shuddering, then slight grinding noise, then nothing. Luckily, I was able to coast into a parking space. GM wants $2,500.00 for a new one. (Sigh) With such low miles, I wonder if Pontiac is willing to help out a loyal owner?
I would put pressure on GM though. I have read stories where they have paid for 1/2 or all out of good will. I would keep trying and write some letter / call anyone in Detroit you can.
