For example, the manual lists inspect brakes, inspect x, inspect y, etc. at early miles, but I would not bother. Just do the oil changes, and other CHANGES and REPLACEMENTS, when it says to do so in the manual.
My brother is having a problem with his car where it makes a squealing noise when he turns. One of his friends says that it may be a CV joint, but he thinks that it could be something to do with the brakes. I was wondering if there was somebody out there who could give me a link to the schematics of the brakes so he can try and repair that himself? Another person says that it may be the bearings. Are those easy enough to repack by someone who is knowledgeable in that sort of thing.
Any responses would be greatly appreciated.
Thank you for your time.
I posted a question similar to this before, but my brother's car squeals as if his brakes were going bad, but only when he's turning. Could that still be the brakes or could it be something else?
Again the squeal is the high pitched "your brakes are dying" sort of warning signal so you know when to replace the pads. His car does not make a grinding sound, as when metal is rubbing on the rotor, as far as I could hear.
Thanks anybody for responses.
MrShiftright
Visiting Host
If he does replace the 02 sensor, get a factory one, not an aftermarket one. Buy it from Toyota.
Problems in the brake system would be a little unusual in a 2 yr old vehicle, but not out of the realm of possibility. This is probably why the dealership is suspecting you are the problem. Could be a sticking caliper, perhaps a blockage/crimp in the brake line, defective master cylinder, etc.
If you let go of the steering wheel while driving, does the vehicle drift to the right or left and the steering wheel turn by itself? If it does, this could be an indication of a sticking caliper on the side it drifts to.
So you'd need to ask them to break down your estimate and see what they are selling you here aside from gold-plated struts. Are they including other front end work?
I thought that with some reasinably food maintenance I could drive it for at least another 50 K miles, is is reasonable to expect a Toyota Corolla to last to 200,000 miles? It really runs well now (143,000 miles).
Of course, if you want to spend thousands upon thousands, you can keep any car running for a million miles if you want...the point of which is...I don't know...
Here is the background info. I added some gumout fuel injector cleaner to my gasoline, but put in twice the amount needed by accident. Immediately after, when i pressed the gas pedal, the rpms would hit somewhere between 2 and 3k before first gear would catch... Above first gear, there has not been any catching or rough shifting at all. I drove until the tank was empty. After refueling, the car ran a little better. I then disconnected my battery to reset my computer and changed my spark plugs which has helped but did not fix the problem. The first gear is still catching slighty it seems when I am driving at low speeds or starting... I do know that I need a new catalytic converter, but have put off the $400 repair. I am skeptical that it is the transmission because the problem seems to be going away gradually. Next on my list is changing the air filter, and maybe some seafoam... Any ideas, hints or similar experiences??? Any help is appreciated.
I have looked but couldn't find any info, but has anyone experienced this & knows how to not wreck your front lens just for a bulb that you really need? I appreciate it very much--TY! :confuse
dont take the heat guard off to get to it i no thers only 7 bolts holding it in but they will be week due to the heat and if u snap one it will start ratteling
in my corolla 05 when i, lets say in the highway and it happens everywhere, change the gear from 3 to 4 or 4 to 5 and press gas pedal, the RPM just goes up like to 2800 or 2900 and then jumps back down to 2000 or 2200 or wherever it was supposed to be. and then starts inclining as it is supposed to. What do you think the cause is? is it the transmission fluid that i have to change according to the maintanace plan or it might be the clutch?
After explaining that it would take umteen-hundreds of dollars to buy or replace myself, I decided to check the Internet for a resolution. After a few minutes searching I found that there is a common problem with the MAF Sensor in many Toyota's. I say problem, but it really just has a knack for getting dirty. All I did was take it out, clean with a Q-tip and facial astringent (isopropyl alcohol would work also), and set it back in place. After a day or so, the light went off and I've been good ever since.
I lost the page that gave me pictures and descriptions on where to find it. I'll have to look after work for a better description, but I know it is located inside the hose that runs from the air filter. You have to unscrew 1 or 2 screws and pull it from the side of the hose, then disconnect the wiring, before taking in the house/garage for closer cleaning and inspection. Be very careful when cleaning with the Q-tip. There is a small circuit tucked down in the plastic unit that can break. Give it a good wipe down and allow to dry thoroughly before putting back in.
You should obviously not drive your car while this is still out. Check on-line for "cleaning MAF sensor" and there is a ton of info that pops up. I'll see if I can still find the site. Saved me a ton of money and wasn't even what Autozone said was the problem. As a side note, you could also try one of those fuel system cleaners by Gumout or STP and see if that clears out any gunk elsewhere. Let me know if you have any other questions. Maybe another Autozone will have no problems hooking up their machine also? Hope this helps. Cheers!
