Has anyone else experienced this and do you have solution for me?
Are there any issues with using premium gasoline for a long time in a Corolla? I guess I'll just have to switch.
Last weekend I talked with a relative who is a Toyota salesman and he indicated that Honda gets their catalytic converters from Toyota.
JEPROX - could you provide more info on the aftermarket alarm you installed (ref. your post #370 on this board)? I'm in US. Will provide my email If you want.
FWIW, calsage.com/tundra2003.htm shows how to install the RS-3200 in an 03 Tundra, and that probably applies to the Corolla except for the cosmetic stuff, but does anyone know of a site showing how to install & pgm the 3200 in an 03 Corolla? (I gathered that the dealer's kit provides no instructions.)
RE: 4 speed auto trans shifting - how's the 1-2 shift in YOUR tranny? In mine, the 1st gear clutch releases, the engine kind-of 'floats' in a slight race for a moment (computer probably keeps engine from really revving) and finally the 2nd gear clutch slides in and takes hold. IS THIS NORMAL?? The dealer let me try a new one on lot - I didn't hear the same actions. The dealer's car (also made in Can.) had a much crisper 1-2 shift. Naturally, service dep't says they can't do anything about it, so I ask you, dear reader, how does your 4 speed auto tranny shift? (Ya gotta turn the sound system and A/C off, close all the windows, then listen to the engine as you take off from a dead stop with medium-light throttle. You're listening for the tranny to do its first shift.) FWIW, the 2-3 & 3-4 shifts on mine are reasonably crisp, though I can hear a LITTLE slip, probably due to the fluid modifiers.
Wife's car was delivered with a bunch (over 20) of scratches in the clearcoat. (Night delivery - never again.) Had to look carefully for these, because the sun bouncing off the metallic paint will mask them. Dealer didn't want to correct at first, but later broke down and ate costs, then added a band of scratches to the RR fender CC on the last go round. Now we're waiting to get those repaired.
Haven't sent in the new owner's survey yet. If someone hasn't beat me to it, I will be the #4 complainer about rotten eggs (see an earlier post).
Long winded. Sorry. This is my first crack at it.
I also have a couple of scratches on the body. What do I need to get to cover up the scratches? I could not find the color code for the Sand Drift Corolla from the label on the front door panel.
I inspected the brakes and 2 of the 4 front disk brake sliding pins were frozen. Loosened, cleaned, and relubed w/high temp grease and still have the squeak. CV boots are intact. CV joints and wheel bearings are original. Tried to determine if my vehicle has an grease fittings by checking my Haynes manual but no luck. Any info would be much appreciated.
P.S. I did wait until 120,000 to change all belts including the timing belt. The belt was in excellent condition, although the engine timing may have been off just a bit as I experienced some pinging/hesitation between 55-60 mph.
The repair cost for the three shops I contacted is $15, $20, and $25 respectively.
Also, we're getting wetness on the floor in the rear right hand side of the car. This seems to occur even in dry weather. The floor is warmer there after a short drive. I'm thinking I'm getting condensation on longer trips. If Toyota is consistent on telling me how to resolve this issue --- it'll be 'don't let the car heat up'.
You might sense that I'm becoming less than a happy camper.
I'd say generally that the equipment/options on most in-stock units will vary geographically. Most Corollas, especially LEs, will have automatic transmissions; side airbags and ABS tend to be a bit hard to find. At least half the 'S' models will have the sport package (rear spoiler and alloy wheels, IIRC). Good luck.
thank you
i know this might be a little stupid, but i can't seem to hook up the cargo net to my 04 corolla le. the instructions say that i need to use a plug removal tool but it didn't come in the cargo net package. so, what should i do??!
thanks!
I've had my XR for about a month. Recently the latch on the seatback of the backseat (passenger side) has started to rattle. It only rattles when I hit a sharp bump. Anyone deal w/ this before? Is there a fix? Thanks in advance.
The brakes were checked as a possibility for the squeeking problem. They were ok and the problem still exists.
I really don't know what's wrong with Toyota with this sulphur issue. Corporate Toyota doesn't seem to care a bit for customer satisfaction on this issue -- with exception of Laurelmarie. In New York the regional service manager has indicated that they've tested and sulphur levels are higher than some standard (standards for which they probably have in Canada). I called Toyota's customer service and indicated to them that Toyota was selling cars in New York that can't handle the gasoline in the state and the consumers have no prior warning about this. She indicated it was the dealers responsibility to advise the customers. If I were a dealer I would be very upset to have to sell cars that have a sulphur problem in the first place (or try to sell them after mentioning the sulphur possibilities).
I have a couple of loose ends to clean up and will try Laurelmaire's procedure of writing to the dealership owner and Toyota presidents. I have enough written information from corporate Toyota to request assistance from the Consumer Protection Agency and the State Attorney General's Office. I'll decide on that action after I've consulted a lawyer about doing a private lawsuit. (Toyota customer service offered an immediate appointment for arbitration. Having no additional information about how that whole process works... I don't trust Toyota.
On another front, wife suspected a defect in the upholstery of her 03 LE. Sure enough, when it is viewed in an angled (late afternoon) sunlight, I can see that every 1-5/16" there is a missing thread. This is seen as a horizontal line (left to right) in some seat (cushions and backs) panels. The vertical fabric panel of the rear seat cushion (which touches the back side of a rear passenger's leg calf) has the missing thread oriented vertically. This missing thread is visible on some of the seat panels, while other panels apparently were cut from another bolt of cloth - the 'missing thread' lines are absent. FWIW, the problem can also be seen - from a distance - at night when the interior lights are on, but close up it seems to disappear. The car was mfg'd in Canada, 11/02. Anybody else see this problem?
Is the steering on an 03 Overly sensitive? I have to keep tweeking the steering wheel to get the car running down the center of the lane on a straight stretch, and just about the time I get it, a curve comes along and then I have to start all over again. I've never noticed this 'hairtrigger' sensitivity on other cars I've driven. Has anyone else noticed this problem?
JEPROX - Tried to find the ULTRAGUARD alarm via the likes of GOOGLE, but going through the results gets me things like CO alarms, an alarm installation co. in Van Nuys, CA, dead-end auto products listings, car covers, card access (door lock control) security systems, home/commercial alarm systems, an edmunds listing that took me to your post, and on and on. Would you provide a pointer or req my email addr? Thanks.
CG
Quick question: I have had my Matrix for 2 weeks now and noticed that the left rear seat has the plastic part a bit separated from the seat itself. It's still on strong enough, but there is a small gap. Has anyone had this problem? If so, how can it be fixed? I figure I should take it back to the dealer, but that can be a pain in the neck.
DO NOT MIX THIS UP WITH THE TOP MOST HOSE THAT GOES FROM THE TOP OF THE RADIATOR TO THE TOP OF THE SIDE OF THE ENGINE BLOCK (IT'S NOT THERE!). IF YOU REMOVE THIS YOU HAVE TO RE-SEAL IT WITH SILICONE SEALANT.
Back to the themostat replacement: If you unscrew the metal housing connected to the driver's side of the engine block, that the hose located under the distr. cap is connected to, you will not have remove the hose from the housing. There are only two screws. I had to remove my battery first, then my distributor cap and things flew after that.
My recommendations for a rookie like myself are:
1. remove the battery
2. remove the distr cap and rotor
3. unscrew two screws that mount this connection to driver's side of the engine block as mentioned above. it's a good idea to place a catch basin under your car as it will leak a lot of anti-freeze. you can just put it back in when you're done and you WILL NEED more anti-freeze.
4. remove theromstat and replace with new one AND new gasket that goes around thermostat.
5. put everything back tight.
I really like these cars but the levers feel like they will break. I saw a mention of the trunk release issue, but not the fact that both levers are connected feel so light.
Does anybody know if this is an easy fix? Does something just need tightening? I have this scary image of buying a nice Toyota and then damaging it when I need a screwdriver to pry the door open the first time I buy gas! The trunk I am willing to use a key, but if the release for the fuel door doesn't work, that's that.
The replacement part that I am getting is a circular clamp, which will require the existing assembly to be removed.
As per the Toyota dealer the original strap was part of the muffler, and I will need to buy the whole muffler!
Any place where I will be able to get this part?
Has anybody had this happen to them? Is this normal, or should I be worried? I'll send the car to the dealer to have it checked, but I wanted to check your feedback here first.
It is normal for this car, but I do wish it were programmed to shift a bit sooner under normal gas pedal thrust, and not to shift to second at 100 km/h unless completely floored (and maybe not even then?)
Clark also suggested that I make the same complaint to www.autosafety.org which has no character limit, near as I can tell.
Well, the second one paid off. At least they were nice enough to respond, and here's what they had to say.
"The engine in the Corolla is running too rich. There's not enough oxygen in the fuel mixture. The sulfur in the gasoline is being reduced to H2S rather than being oxidized to SOx. Call Toyota at 800-331-4331. To get EPA's assistance in the matter, call Sheena Dupree at 202-564-9414 who works on warranty issues for them. Or you can write the head of the office at the below address.
" Margo T. Oge, Director
" U.S. Environmental Protection Agency
" Office of Transportation and Air Quality (6401A)
" 1200 Pennsylvania Avenue, NW
" Washington, DC 20460
"Tell Toyota you are contacting EPA. That will get their attention."
He signed his name, which I'll not repeat here.
So later today I'll get the ball rolling. And now you too have something to work with, but please, Please, PLEASE be sure to report YOUR problems to those two (now three with www.epa.gov ) organizations, too. Only if enough of us bellyache - and to the right people - will we get Toyota to fix a problem that never should be happening. FWIW, my neighbor bought an '02 Honda Civic just before I got the Corolla. Neighbor uses the cheapest unleaded gas he can find, and has ABSOLUTELY NO PROBLEM with rotten eggs smell from his exhaust. I bought the Corolla because I felt it was mechanically superior to the Honda. It doesn't need a timing belt replaced every xxx miles - Toyota went to a chain drive for the overhead cams, in '03, and the rest of the engine dates back several years, so the design is pretty much "proven".
At any rate, thanks for the info. I'll try to take easy with my technoligical marvel from now on..
The thing I really hate about "intelligence" is that if you are most of the time a light-foot like me, to save some gas, it will not shift aggressively at other times when you actually want some rapid acceleration. It assumes that once lazy is always lazy as far as shifting. I find myself shifting the gears on this thing almost as often as I used to shift my manual, and I can't understand how 90% of the drivers in the U.S. want one of these slushboxes (very aptly named, IMO).
___A heads up for anyone that may have to change a tire after a flat on the road I was attempting to rotate the tires on my 03 Corolla LE and I could not get any of the rims off the vehicle. The dealer ripped me for $40.00 on this and I am pissed. They were rusted to the hubs and had to be hammered off from behind. This was at the 42,500 mark but a year and the rims are rusted to the hubs? I have never experienced that before with any other vehicle ever and I hope you don’t either!
___Good Luck
___Wayne R. Gerdes
___Hunt Club Farms Landscaping Ltd.
___Waynegerdes@earthlink.net
It is a good point - don't wait too long to get all four wheels off the car, and the hubs scraped clean of rust - fiddling with this on a dark road in the middle of the night is not fun.
