tbettett,
Do you have an auto or manual transmision?
If you get 25 city, believe me your lucky. 25 city is well within the normal range of the rated mpg anyway and even a reputable car manufacturer would not see this as a problem.
This is right on the money for a new-gen Corolla with an automatic.
Can't say it often enough: unless your driving is EXACTLY THE SAME AS THE EPA TESTING CYCLE, you cannot expect to match those numbers. Some trips will do better, some will do worse; some drivers will do better, some will do worse. Your numbers are very close to ours.
One thing you can be fairly confident of: the engine won't be completely loose and fully broken in for about 5-7000 miles. Mileage and power will both very gradually get better right up to that odo reading. This has been consistently the case for every new car we've owned [both Japanese and German] for the past 20 years.
Secondly, my gas mileage is not getting the 28 in town. I am only getting 25-26 at time thanks
Though the lowe miliage makes the warped rotor thing suspicious, as its pretty low mileage for breaks to be wearing out. I"m not a mechanic so this is just my 2cents.
MM let us know what you find out
Anyone, please tell me any more info you have on the clearance.
thanks.
My mechanic is actually quite good, my family has been going to him for the past 10 years if we don't go to one of the two local Toyota dealerships. He has never ripped us off, and always uses genuine parts and even shows us how he works on our cars throughout the whole process. The dealership closest to my home - the repair guys crashed my dad's Avalon in their parking lot and wouldn't fess up. My dad dared them to show him the security video in the lot to prove they hadn't done it. Let's just say they fixed his original problem and the dent for free. The second dealership is where I bought my Corolla, and went in there a month after I bought it to try and fix the "rattle in the dashboard near the CD player." Not only did they NOT fix it, there are toolmarks in my dash where they ripped it out and the rattle returned 3 days later. They did say if the foam padding they added didn't work, that there wasn't much else they could do. After that, I did an internet search and found these excellent forums Um, so that's why I'm a bit reluctant to go to the dealership.
By the way, for the folks with the gas mileage question above, I average 28mpg in most horrible, stop-and-go freeway traffic. I think one thing that might give me more mpg is the fact that I don't have anything in my trunk, and rarely carry passengers. Perhaps that lack of extra weight helps? One week for some unknown reason, I dropped down to 20mpg and ran out of gas because I didn't believe the gauge would be on empty that early. I never did figure out why...maybe the switch to summer gasoline?
I just bought a 95 corolla wagon with 5spd transmission.
When speedo shows 70mph, tach is on 3000rpm.
I think this rpm is too high for that speed. Can anyone tell me what kind of rpm/speed values they are getting with their similar corollas?
Anyway, I did turn the key counter-clockwise, but the trunk release lever continues to open the trunk. I'm curious to know if anyone else has experienced this problem. Thanks.
SDE
When I showed him the TSB I had printed out, he said "hmm, this must be new." I didn't point out the May 2004 date. His manager then pulled it up on his computer screen.
Then he said the VIN number on the TSB was not the VIN on my car. I pointed out that the notice said all cars made before the VIN on the TSB are eligible for the fix.
He then asked if my 2 year old car had less than 80,000 miles, a warranty requirement. I told him it had 21,000 miles.
Then he said that he would plug my car up to evaluate my engine. I told him there wasn't much to evaluate...my car stinks and it needs the PCM flashed or replaced, and a new converter as the TSB directs.
I finally ended up with them ordering a new converter that is due in Wednesday and the work will hopefully be done at that time.
It was like pulling teeth, but if I didn't have the TSB printed out I don't think I would have ever gotten to this point at this dealer.
It is installed, and they reflashed my PCM. My car no longer has the smell anymore. I recommend this fix to any other Corolla owner who has been smelling sulfur.
It belongs to a friend whom once had a second hand car sales lot, and this vehicle was a re-possession. Therefore no keys are available, I don't want to go out and replace all the locks as that would be very costly.
Due to this vehicle standing for such a long time, does it mean that I'll have to remove the head an all ? The engine has 112000k on it, and I'm not sure what size the engine is, all I know is it's a straight inline 4 cylinder, front wheel drive.
Eric
You could try Auto RX http://www.auto-rx.com/
People have had success with this product. It works gently over time.
My point is there are good and bad dealers. If the one you purchased from doesn't satisfy you try another. Glob on a dot of paint indeed, good grief.
It's amazing what they will try and get away with!
As a point of reference, in the highest gear a 2003 Honda Civic SI tachs at 3600 rpm when traveling at 70 mph and 4200 at 80 mph. The explanation you would likely receive from a car maker is that a higher rpm allows for better highway passing acceleration. Unfortunately, it does come at the expense of some fuel economy.
I can just see the dealer attempting to avoid responsibility claiming that the tire is covered under a different warranty and (most likely erroneously) blaming your driving habits for causing the alignment problem. Conversely, the tire outlet will probably try to avoid responsibility or pay a graduated amount towards replacement tires. If your mileage is low enough (say under 10,000 miles), I would try to lean on the dealer to fix the alignment problem under warranty stating that it was likely an existing condition and not caused by you.
