I have a 2004 Corolla (which the dealership wrecked while test driving it) that makes the high pitch sound in the lower left hand corner of the windshield around 70 mph. They've yet to find a cure :mad: .
I have a 2000 Toyota corolla. I went on a 500 mile drive and on my way back home the check engine light turned on. I took it to the dealer and he ran the computer diagnostics ($90 already just for diagnosis). He said the code P0171 System Too Lean and gave me 2 options:
> Clean the Air Flow Sensor ( 2 hour labor, no garuntee of how long it will work)
> Replace the Air Flow Sensor (2 hour labor + new part($180))
Can anyone advice, what needs to be done? I have searched a few forums and found that for a few even though the part was replaced the engine light came back on after a few months.
What happens if I leave it as is? They have reset the engine light and it is gone for now (drove only 15 miles after the reset). If I want to go for the repair, is it better to get it cleaned ( the first option) or replace it altogher?
Any advice will be of great help.
Sri
If you want to change it sooner, no one is going to discourage you, but it's not necessary, first change or not.
1) The starting problem: after 30 min of driving, it's very difficult to start. I have to crank the engine 5-6 times. The dealer said that they started the car about 30 times without a prob.
2) The AC smells strange, like the inside has mold and the air is humid all the time, even when the weather is dry & the AC hasn't been used for a while.
3) The car hesitates for a second when accelerating from a stop.
Can anyone help?
This is my first aim at buying a something that's not from the Big Three (GM, Ford, and Dodge). I hope this car will back up Toyotas reputation for reliability.
2). See if with the AC on, the vehicle is sending water out and down the evaporator drain line to the road surface. With the car in Park with emergency brake on, and the motor running, turn the AC on. Go around to the passenger side front. Look underneath. Do you have water dripping at a good rate to the ground? Do you have water / damp mats in the passenger floor wheel well? Remove all the mats and look for any moisture under them.
3). I think there has been a TSB issued for improving drivability characteristics of the Drive By Wire system by re-flashing the ECU (Engine Control Unit). Some people claim it takes the vehicle some time to learn your driving habits and adjust its control parameters.
clogged with debris -or-
kinked / collapsed -or-
disconnected or not exiting properly though the firewall
if your car has 20K - i see no reason why it wouldn't be a warranty repair. should be superfast for them to diagnose. even if it isn't because of the evap drain - it should be warranty...for example it could be a leaky seal on a window, or body weld or missing body plug, or clogged sunroof drain (the possibilities are pretty numerous).
i have know knowlege of a TSB on starting issue, only the hesitation issue as a result of it being discussed in the Engine Hesitation (All makes all models) discussion forum.
you have an '05 with less than the mileage limit on warranty coverage. see your dealer and think positive.
Thank you very much for the explanation and suggestion. I will definitely bring the car to the dealer and to have a checkup.
Gang
My gas mileage has dropped from 36 on the highway to 33 in the last few weeks. No check engine lights are on and there are no codes when checked by the machine at Auto Zone.
Any suggestions?
Ronald Davis: What happened with your problem? Did you get another radio with your next oil change?
Was the problem confined to your radio, or was there a related electrical problem?
Has anyone experienced this?.
People have been posting the same question on the Honda Civic boards - same reason, same answer....emissions equipment.
Most of the gearing for fifth gear is in a separate additional housing attached to the main transmission. He disassembled things and was able to replace just two gears and the shift fork mechanism. He also put synthetic oil in the transmission. All told it cost me about $500 with his labour.
Thanks for following up!
Most of us are interested in our problems until they're resolved, then nobody knows how things ended up. (I'm guilty of this myself.)
We read a lot of bad news here, so it's nice to get some good news!
Does anyone notice the volume of the engine noise during city driving mostly in the lower gears? I mean, the engine runs smoothly, but I definitely hear it working. On the highway it's very low.
Also, I've only put about 500 miles on the car, but it seems to be getting low gas mileage. I've estimated about 24-26 mpg mixed city/highway. Does that get better after the first oil change or after I've driven it a little longer?
These questions may seem a little stupid, but it's my first new car and I want to make sure I don't ruin it!
Your MPG is fine, and will improve after the engine is broken in. Make sure you do actual MPG calculations, not "estimates." Just follow the break-in procedure in the manual and enjoy your new car!
Here's the reason for my question: My '05 (20K Miles) is having the "INTERMITTENT NO START CONDITION ON VEHICLES EQUIPPED WITH 1ZZ-FE ENGINE" (TSB# 01805). If I take my car in to fix the prob and they (Toyota Dealer) reprogram the computer to '06 specs, will my car lose those 4hp?
Also, has anyone had any problem with slippage from 1-2 on the automatics? Thanks
In every case, there is nothing really new - the engines produce the same power they did last year, but this is a lower number under the new testing guidelines. The '06s haven't "lost" anything - it just wasn't there in the first place.
Having the TSB applied to your car will change nothing in regard to its power output.
I have a 2003 Corolla which I bought new that has been great up until about 1 month ago when it started using a lot more fuel for no apparent reason.
My dealer service department checked it out and have no idea why the car is using so much more fuel than previously.
I thought it might be water in the fuel tank so I ran a tank of gas with methal hydrate and no luck. It is also not the O2 sensor.
Also sometimes when I start the engine cold in the morning there is a very loud rattle and clanking sound coming from the engine. This is intermittent but is freaking me out because is sounds like metal on metal. The dealership could not find the cause of this either.
Has anyone experienced either of these problems with their Corolla?
Thanks for any info.
DominicCCC
I have a 05 Corolla.
I was involved in a car accident 2 days ago. I was coming off an exit, turning right on an uphill ramp, and the sunshine was in my eyes. I couldn't see for a second or two. I hit the pickup in front of me. No one was hurt although the front part of my car was badly damaged: the hook was bent, the fluid was leaking and it has to be towed away. But my airbag did not inflat!
I did some research and found that airbags should work in front-end collisions occurring at more than 10 mph. I am sure I was driving in a speed more than 10mph in order to have such damage. One of my friends told me that his father was involved in a similar accident as I had, and the airbag did not inflate neither. And, he was driving a Corolla too!
I wonder if anyone out there has similar experience.
It sounds like you're pretty desperate, so let me give this a shot.
It's always best to tackle a job like this with a repair manual specific for your car. You may be able to get one at the public library, but if not, sometimes you can get away with unwrapping one copy at the parts store and just reading over the pages you need.
If you can't do any of the above, a starter isn't *too* hard to figure out ( :confuse: ). It is usually mounted to the transmission housing with 3 or 4 bolts, and has a starter solenoid bolted to it, which has electrical wires going to it.
Assuming your advisors are correct, the problem is with the starter and not the solenoid. Therefore, you will need to mount your existing solenoid to the new starter. Be sure and note how the wires are connected and then disconnect them (some solenoids are color-coded for this purpose, if not, you may be able to mark them with colored tape or nail polish).
Another thought: remove the starter/solenoid assembly and take it to a place like AutoZone that does free testing. This way you can be sure you're replacing the right part.
Also, this job will require going under the car. If you don't have access to a pair of ramps or jack stands, you can try parking the car with the front wheels up on a curbstone. If you do use jackstands, you'll want to position them as close as possible to the point where the front suspension mounts to the chassis, as this is the strongest point. Either way, be sure to chock the rear wheels to prevent any possibility of rolling. :shades:
I suggest you enroll in an adult school night or day
class in auto repair, and join the Toyota owner's
club. Being a single mother, you may not have much time
for this, but since it sounds like you can't afford
to really maintain this car anyway, maybe you can meet
people in a car club who can help you with repairs, and
you can learn how to do some things yourself. Most women
don't want to be bothered with car repairs, but if you
decide to try, you might like it if you really focus on it.
Since women in general have smaller hands then men, you
will have the advantage in one respect, accessing hard
to reach areas in the engine compartment.
