Toyota Corolla Maintenance and Repair
1112113115117118126
  • FOR all of you......I have had the belt tensioner replaced ..did it myself...F-ing pain as the manual is wrong.....(Access hole is OFF). YOUR GRINDING Noise is this OR a BEARING in the the manual transmission(throw -out) if you have a manual corolla or any other CRAP tundra and so on....toyota product...... I have a 2004 corolla .....When it is extremely cold I get this grinding until the car is warmed up... Can happen 1 out of 15 starts random(where ever the bearing stops) on an over night cold soak.... Currently 64k started at 17k while under warranty , CLOWNs could never find it ...over it would never happen.... When you have this problem...PUSH the CLUTCH in about 10 times pumping it...(IT WILL STOP). YOU will find its the throw -out bearing my guess MOVES and STOPS .. or a bearing that stops when the clutch is pushed in.... At some point I will replace it when its time for a clutch unless it completely fails... OR TOYOTA gets hundreds of complaints...The problem is there are not many manuals on the road they built few compared to the auto's(transmission) .. Plus Not easy for people to find or know what to complain about I have had over 5 toyotas ...And I have totally seen them turn to JUNK over the last couple.. I own a Corolla 2004 and SOLARA Conv 2007 ....HAd a scion TC 2005 what trash ...a 1994 tercel and several others... Im done... TOTAL [non-permissible content removed] CARS NOW...I always have to tell the TECHs how to fix my cars or give them the TSB's I look up as there lazy.... get um in get um out....
  • I have a 2004... there are two TSB one is for cold soak rough high idle ....car will run high in the cold......I had this fixed under the fed warranty up to 80k free.... its a re program of the ECm... WIll run alot better after this... The other is a manifold problem crack.. TSB car will run rough or even trigger Light or code.... This one you will have to pay most likely....
    Hope this helps
  • If you have a manual trans like me.......I have the same problem.. I did the tensioner thing...that part is fixed...but I have the same problem... Grinding until warm up... standing from the front of the car.... look down toward the right where the transmission is,,,,,, I have been trying to figure this out for two years....as its so random and does not always happen... What I have found its in the trans... MOst likely the throw -out bearing... AS IF YOU PUMP the clutch alot..10-15 times it will go away.... BAD BEARINGS in throw-out my guess.... Mine started at 17k but only happens in the winter when really cold say below 28 .. THIS IS NOT the starter Dont let people tell you this...... Hoping to wait longer when I replace the clutch to take a look at it... I have 65k now on mine and really dont want to open it (lAZY) or pay someone..... TOYOTA cheap quality parts... AS I have seen them go down in the last 4 years
  • Is your car a manual trans .... I have the same problem.. Did the tensioner(DID it my self)... fixed that part... But I have the grinding... TRY this.. next time you have it.. PUMP the clutch like 10 -15 times... or more..It will go away( LOOKS LIKE THE RELEASE BEARING) ,.... Mine started at 17k and has continued to 64k now...DEALER TECH were clowns and still are!!! They could so call never find it???? Yet it would happen when I picked it up.. I gave up.. the told me it was the timing chain... TOLD them to F&CK OFF......There all PARTS monkeys who can only fix what you TELL them ..Or the Computer points them ..NO SKILLS... GO to a ma and pa shop ... you will have better luck and better serivce (OPEN A Investigation at NTSB https://www-odi.nhtsa.dot.gov/ivoq/Complaint.cfm ) The problem is everyone that sees this grinding noise thinks its the tensioner.....
  • Mr_Shiftright, thank you for your advice. I had my valves adjusted, and had a belt tensioner replaced. The only item remaining is that my mechanic found that my timing chain is a little loose due to the timing chain tensioner being loose. With the other noises now gone, my engine does make a noise for about 10 minutes. Once the engine is at operating temperature, the chain noise diminishes significantly.
    I was told that if the noise goes away when the engine warms up that that the timing chain is not being harmed. My 2001 Corolla only has 75K miles and would like to keep to at least 150K miles. Would you suggest that I have the timing chain tensioner adjusted (or replaced)?
    Thank you very much.
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 50,957
    It seems unlikely that the tensioner would be shot at these low miles---I guess what I'd advise is to keep an ear out for the noise to get worse. As long as the noise almost goes away when warm, I would worry. It's very rare for a timing chain to break---but what CAN happen is that the tensioner or chain guide rail can wear so badly that the chain can jam in the timing case.
    MODERATOR --Need help with anything? Click on my name!
  • Can the tensioner and chain guide rail be replaced without replacing the timing chain? If I do need these replaced, would it make sense to replace the chain as well?
    I think there is a tool to measure chain wear, so you don't have to guess--but yeah, you can replace the guide rail and the tensioner, and yes, that's less work.
  • I have noticed a similar problem - I don't hear the grinding noise, but it kind of does shake when cold.
    However, I disagree with your disappointment in Toyotas - this is a minor thing compared to everything else that Toyota still builds to last forever ... and Corolla prices are not going down with age ... I am still a happy Toyota owner :)
  • terceltomterceltom Posts: 1,017
    Couldn't agree with you more! Being the kind of forum this is and the topics up for discussion, we do have a tendancy to hear more from the dissatisfied Toyota owners then the satisfied or those that have problems then those that don't. But rest assured there are many more of us satisfied Toyota owners then those that aren't satisfied.
  • Love your toyota thats great........but As Im stating The cars have totally gone down hill over the last 7 years ....I have owned over 5 toyota's ....Not going to get into the details of each car...... but my last 3 the quality was really not there......I have watched them get worse over the years... and its all shown now.. and more will come out watch.... Heres one for you guys...... Search the web ... about 3 to 4 months before this whole mess broke out on National TV..There was an article on nationals headlines stating toyota was looking and asking there current suppliers to cut there costs 20 to 30 percent(parts) ..or they said they were going to look for new partners and lower costing parts.... YOU DONT HEAR anything about that now... all quite...now... as the crap hit the fan....There no different then any other company just a different wrapper.. Once you get greedy its all about money!!!! They've endned up like the GM of the early 80's mass make , mass money and it bit them in the @SS just like GM....
    Sorry to hear you had so much bad luck with your last three Toyota purchases. If you have some inside information on further Toyota problems that we owners aren't aware of, for our safety, perhaps you would want to share them with us ? I thought just about all of the proven and alleged Toyota problems were now out in the media.
    "more will come out watch.... "
  • I traded my '94 Corolla for a '10 Corolla in December '09. The seats in my '94 looked great after 15 years. The seating material in my '10 Corolla is terrible. It attracts lint, pet hair, dirt etc. and is impossible to clean. I've been a HUGE Corolla fan until now. I'm very disappointed with the quality of the seating material. It's apparent that Toyota's answer to the growing competition from Korean automakers is to cut quality. I drove an Elantra before buying my Corolla and only bought the Corolla because of my experience with my '94. I made a huge mistake and regret it every day that I drive my car.
    Before you buy a Corolla, look around. You'll find higher quality for less.
    I have an "09" Corolla as well, and as you state, I do find that the seats collect lint, dust, etc. However, Toyota considered this new textured velour material as an upgrade to there previous seating material. Actually "Epinions" gave the "09" Corolla good grades (7 out of 10), for it's seating material. Are you actually judging and regretting your whole Corolla driving experience on the seating material? Considering how well my "09" Corolla operates and handles and has served me, the lint on my seats are the least of my worries. You might find higher cosmetic quality out there, but for less, that might be questionable.
  • My Corolla is a good car. My argument is that I have a new car and I'd like it to look that way. I maintain my vehicles and try to keep them clean. Toyota has made this car for decades and its quality is legendary. I find it frustrating that this seating material made it through testing and into my car. It is not good quality, it doesn't work well and it is one of those problems that is right in your face everytime you drive the car. I'm disappointed.
    Yeah, it is annoying and as you stated it should' ve been caught in testing or manufacturing. Why don't you try one of those sticky round lint rollers to remove the debris?
  • I will...thanks.
  • debjeffdebjeff Posts: 9
    I am driving a 2007 Corolla and I am very dissapointed with the fabric on the seats as well as the roof carpeting (among rattling and other concerns). My son is tall with bushy hair and where the hair touches the top of the inside roof carpeting, the material has begun to look like shag carpeting. The fabric on the seats are wearing in places. Is this suppose to happen? Can anyone suggest how to repair both concerns? Perhaps my next car will not be a Toyota.
  • gpc46gpc46 Posts: 5
    could anyone please tell me labor times for minor/major services plus what items are replaced on each one, I've mislaid my book
    Change the oil and filter and rotate the tires every 5 K miles and you'll be fine. The rest done as needed. My philosophy is anything more than that is a waste of time and money. I always had great service from all of my Toyotas without feeding the dealer. Just sold a Tercel I had for 24 years. Currently have three Corollas, no preventative stuff done.
  • dieuwerdieuwer Posts: 8
    I own a Corolla 2002 with 100,000 miles on the clock.
    Last year, I had to replace the front shocks for $$$. The garage wanted to change the rear ones as well, but I said "forgetaboutit". This year, I needed to replace the entire exhaust otherwise the car would not pass MA inspection. Again $$$.
    I am getting more and more displeased with Toyota. Why all this talk about reliability if you have to spend $$$ each year to keep the car running? Sounds more like hype to me.
    Are you kiddin me? Try to get an American cars shocks and exhaust to last 100K or eight years!
    Not talking about American cars. Those are even worse. Could be that my expectations are too high, but I do not see (anymore) why Toyota should command a premium over other Japanese/Korean brands.
    That's actually pretty good for shocks. Usually 80K most shocks/struts get pretty tired on cars that travel in urban environments. As for exhaust systems, if you live in a state with road salt in winter, then that's also about the lifespan.
    The items you mentioned, while unarguably an expense for you, are considered "expendables"---that is, they are items that, by design, wear out periodically. Other expendables would be brakes, rotors, clutches, spark plugs, etc. Of course, engines, transmissions, paint, trim pieces, major electrical items and vital safety components would not be considered expendables.
    Also, every car is built to a price point and those of us who buy cars in say the under $20K class aren't going to get the build quality of a BMW or a Lexus.
    Now, if your reliability (break downs, frustrating incidents of no-starts, etc) were rapidly degrading at 100K, that would bother me, too. But replacing worn-out but functioning things on a car of this age, speaking for myself, I pretty much expect it.
  • onirudhaonirudha Posts: 3
    I have recently bought a corolla 2001 CE. Everything seems to be fine except I hear a 'chi chi chi ...' sound when I speed up the car from stop position. It does not happen all the times. Probably, when I press the gas pedal deeper during speed up, I get the noise.
    Anybody has any idea, why I'm getting this noise? Is it serious or I can ignore it?
    Thank you all.
    Hard to say from this distance but you might check for a loose drive belt or perhaps the beginnings of a failed bearing in a pulley or idler pulley.
  • trikev19trikev19 Posts: 18
    Does the noise increase with the RPM's of the motor or the speed of the vehicle?
    I get it once when speeding up the car from stop. And it does happen for 4/5 seconds. Rest of the time I don't get it. Sometimes even I don't hear the sound. Thank you for your response.
Toyota Corolla Maintenance and Repair - Page 115 - Car Forums at Edmunds.com
