Mercedes 300D Suggestions
17810121347
    amonra22amonra22 Member Posts: 11
    One more thing I forgot to add to my posting, the brakes feel spongy and have to push to the floor to stop.I did bleed the brakes but only the front two that I changed. I was told that I probably need to bleed all four lines and that there may be a specific order that I have to do the bleeding in. Was wondering if that may be the cause of the sponginess, and if there is a certain order I have to bleed in. Thanks so much....
    It's possible you might have let in a little air yes. It's a good idea on these old diesels to flush out the brake system completely and have fresh fluid. Usually you bleed from the wheel furthest away from the master cylinder and then the next closer, etc. (this is for old cars, not new ones with ABS).
    Sponginess is usually an air problem. If you can't get the air out, you may have to bleed the fittings in the master cylinder as well. If that doesn't work you may need to have them "power-bled" at a shop.
    Did you put on new rotors? If your rotors are worn (even if they are relatively smooth) you may be pushing your luck. On your car, you don't turn the rotors when they wear to minimum thickness, you replace them (not too expensive).
    isellhondasisellhondas Member Posts: 20,342
    What am I missing? I assume you mean on the back of the pad and not the friction material? I sure hope so!
    Why would you do that anyway? to reduce squeaking?
    And I don't think you need to put grease on a spindle either unless there is something about those cars I don't know?
    thanks for your help. i did put on new rotors with the pads. thinking bout having it power bleed at a shop but it costs almost as much as the new pads and rotors. Also have a transmission question. Shifts into 3rd rough and kind of lurchingly, when it does there is some exhaust. Took it to Aamco, and the mechanic said it was fine that that is how a diesel shifts. Was glad to hear it at first but now not so sure I believe he knew what he was talking about. Had the transmission fluid changed any ideas as to cause or should I take it to get 2nd opinion.
    Oh yeah that ZF transmission is a notoriously rough shifter. I love to watch 300d owner's heads snap back and forth when I'm behind them. On some models (but I don't think yours) you can adjust the vacuum modulator that controls shifting, to soften it, but I believe that's only on mid 80s on up. Sorry I'm not sure about this but there's too much to remember on Benz---they are always changing everything.
    You can try to bleed the brakes yourself using the old brake fluid in a bottle method. That works pretty well. You could even make your own power bleeder. I've done that. I drill a small hole in the plastic top of the master cylinder reservoir and insert very tightly some clear tubing (like for fishtanks) and then hook the other end to a can of compressed air (or you could even use a bicycle pump). The clear hose has to be tight, though. Then, with the brake fluid under pressure, I can do each wheel one at a time. Of course you might have to re-pressurize if you have to add fluid to the reservoir. then when I'm done I just plug the hole I made with silicon or wax or something like that. Be sure not to drill into the plastic cap's little air hole or if you do, be sure to leave that open when you seal the cap back up.
    thank you so much. as this is my "run around car" and not my everyday car i have an 05 toruareg the rough shifting is something normal and I will get used to it. trying to have some fun learning to fix my mercedes. thanks for the help.
    It's better if you shift manually. That helps some.
    sandrastevenssandrastevens Member Posts: 6
    Curious here..... car for car, everything being somewhat equal, would you rather have a used Mercedes, or a used Lexus? And why?
    Well Lexus doesn't make a diesel so the comparison wouldn't be fair---also the 300D was pretty much extinct before Lexus came out in 1990.
    You might wish to ask this question over in the Sedans topic, where they compare gasoline cars.
    76dieselman76dieselman Member Posts: 4
    HI all,
    I think my oil pressure is a bit low. Its above 45 when driving or accelerating or when it is still cold. After it warms and im in traffic or something its right around 30. When i get off the highway after 10-20 miles at about 70mph it is right around 22 or 23 ish. It just seems a little low but i could be wrong. Any feedback would be great. thanks
    normal! Oil pressure at low idle is an irrelevant bit of information as long as it picks up the instant you hit the accelerator pedal.
    Your oil pressure should "peg" when starting up cold. If you started cold and only got 22 psi, that would be worrisome. But warm? No problem.
    willum0330willum0330 Member Posts: 2
    My dad has given me his old mercedes, it's a 1982 300TD with 300 000 km...
    all seems to be in working order, but it won't shut off, so after reading this forum, I am pretty sure the problem is a broken/leaking vacuum line, but has anyone ever had the vacuum pump itself fail?
    Also... is this car worth my time and money with all of the mileage on it? It is in awsome shape, in and out, but it has been off the road for 7 years... so i'm not really sure about it.
    Any help would be greatly appreciated!
    Sure the vacuum pump can fail. Do the door locks work at all? Those are also vacuum operated. You can rebuild the vacuum pump.
    Well if you've been off the road for 7 years you're going to have to clean out the fuel tank I think, change all the filters, get new tires, and certainly flush the brake system, radiator coolant, and replace the belts and hoses. So you might have to spend a couple hundred dollars to see if this car has any life left in it. 300km isn't too bad if the car was well taken care of, but 7 years of inaction are going to take their toll of course.
    dyates773dyates773 Member Posts: 24
    Update!! It's alive! The turbo is now operational. Here's what was done:
    1) Waste gate was stuck.
    2) 3 vacuum lines at the turbo were cracked, broken, or missing
    3) The intake mainfold pressure line to the vacuum control switch was missing.
    4) The Over-Boost Switch was totally plugged with carbon and the electrical contacts were badly corroded.
    5) All rubber vacuum line connectors were cracked and deteriorated.
    6) The air cleaner filter element was plugged badly.
    The test drive was incredible. It does not seem like the same car. The boost really kicks in at 2400 RPM and feels steady from that point on.
    Driving upgrade it was like a different engine, good steady power.
    It took a couple days but was worth it, on to the A/C problems!!!
    Well i have an update... i put a new battery in my mentioned car, and with the turn of the key it fired up, a little smoke at first, but then it ran fine!
    Dad was telling me that when he first started having problems with the car shutting off, he couldn't find the problem, so he switched the hose for the locks, to the shutoff hose, and that worked fine for a while, but then that stopped working to... so...no the power locks do not work. I am still thinking that it is probably the hoses. Would you by chance have any access to some type of vacuum line diagram, so I can see what needs to go where, and which hoses to check?
    I am going to just use some additives for the fuel tank for now, change the filters after some of that has went through, and I have to change the engine oil, tranny oil, and i will flush the coolant system. If the brakes work... do I have to flush them?
    It will need new brakes, and tires... for sure... but other then that... all seems to be well... ha ha... "other then that" :P
    Thanks for your help!
    djocksdjocks Member Posts: 124
    Board, I know this is for the 300 D but I am looking for some help.
    I have the opportunity to get into a family owned 1989 300 SE with 71K miles on it and in very good condition for very little money. I was looking at leasing TL's and Bimmers but this sounds interesting.
    The help I am looking for is, Am I getting myself into a money pit? What type of MPG can I expect? how is the ride, how is the stereo? and how satisfied are present owners?
    Thanks, for the help...
    djocks
    Just some general observations about owning any Mercedes. From a mechanical standpoint they are extremely well built. Most ordinary parts like starters, alternators, radiators, etc. are readily available at decent prices.
    In my opinion, having owned a total of 5 Mercedes is they can be a money pit when they get old. My daughter's '86 190E had a fuel injection problem that cost more to repair than the car was worth. All of the M/B's I've owned have all had A/C control system failures both electronic and vacuum. That's over and above the typical leaks associated with all cars. My '87 30SDL is in the shop today.
    I own them because they have a classic look, I enjoy restoring older vehicles, and my first car was a rusty beatup 240D that lasted forever.
    Oh I forgot, the sound systems sucked but I've never owned a 1993 or newer.
    Yes, you MUST flush the brake fluid. You'll be sorry if you don't.
    Vacuum line diagram:
    You might try over at www.mercedesshop.com; otherwise, if he can't help you (he knows a lot) you'll have to buy the factory shop manuals (set of 3) which are well worth the money if you really like these cars and like working on them. They aren't cheap but after your first home repair you've paid for them easily.
    RE; BENZES in general. Old rule of thumb: "whatever got you into that used Benz cheap will eat you for breakfast sooner or later".
    So buy the best used Benz you can afford. Don't buy a project car, you can't win...if you're in it for fun, then great, it's not such a problem and you're doing a lot yourself, but sometimes it is much much easier to spend more money up front and get a really well cared for Benz. Only the very skillful and clever and patient should buy a "fixer upper".
    Stay away from 190Es, that was not a great model.
    have an 82 300D turbo, was driving to work this am and felt some surging at normal frwy speeds when I was driving. My car then began to loose speed on hills and then on normal flat roads. All the fluids and filters have been changed and was wondering if anyone might have suggestions as to the cause. My top speed was around 45-50 mph after the surging started. No smoke or loss of oil pressure or busted hoses, and other than the surging and loss of power no other symptoms I can list. Any help would be great. Thanks.
    Sounds like bad injectors maybe? You should also put in a strong additive to try and clean them. Also check your turbo tubing for any loose connections or leakage, and finally, check for a sticking or malfunctioning turbo wastegate. If your wastegate is dumping boost randomly, this could account for your symptoms, as could a very irregular spray pattern on the injectors. I'd really have to drive it to tell you the differet feel of these two deficiences.
    Have used a fuel additive in my last 2 tanks of diesel. Changed the fuel filter and lines could some of my problem be waste from the fuel tank clogging the fuel lines, and I should replace my fuel filters again? How often do you recommend fuel filter replacement? If my wastegate is malfunctioning or sticking how can I tell? The surge in power is very slight not like the turbo is kicking in like you are pushing the gas peddle and then letting up on it quickly. Could you recommend an injector cleaner? Thanks.
    Yes, BGK44 is a good injector cleaner. A bit expensive but it works.
    Other possibilities? Maybe your cruise control is kicking in and out by itself? Perhaps you can disable it by pulling the fuse temporarily? Usually Mercedes cruise control on these cars conveniently disables itself, or runs amok, and often---it's quite unreliable. I'm just trying to think of different things it might be. Just pray your injection pump is okay. It's VERY rare for that to go out. I believe it is also adjustable (the pump) but this would require an expert who knows EXACTLY what he is doing.
    zero3kzero3k Member Posts: 6
    Okay, here's something new for all of you.. I only hope someone has an answer.
    I bought this car about 7 months ago, it's a 1984 300D European (Yes, it's gray market.. most things are written in german, it has a top-front filling radiator, and the three-dial system for the A/C. The car was apparently non-turbo when produced in Germany, but a turbocharger (and transmission) were later added. I checked, and sure enough, there was the old turbo.
    Now, the problems. I've owned an American 300D prior to this one, which had more problems than I ever wanted to deal with, so I ditched it for this one. The car isn't the fastest thing in the world, but I have to wonder if the turbo is even working at all. On the american one, it sounded fine.. the car would rev, shift, and the turbo would go *Pfsst*. Pretty fast little thing, too.. for a diesel. Fast forward to now, and instead of hissing when shifting, the turbo sounds like it's constantly purging. During acceleration, there is a constant hiss. It's probably the wastegate valve, like I've read on many topics.. but where is this valve located, and how do I unstick it?
    The only other major problems I have, is the A/C system. I turn the dials to cold (For the right and left sides of the car), close the middle vent slider, and turn the upper dial to 100 (for 100% through the compressor). As soon as I turn it off 0, I hear a relay under the dash click, but the engine won't even bother engaging the compressor. My guess, is that the system simply has no R-12 in it, and it just needs to be recharged. Probably leaks, too.. but that's for a later time. Also, there is a small rainwater leak in the rear right floorboard.. my guess, is that it comes in from the sunroof (This one has a manual sunroof with a tommy-lock.. which I personally like better than the clunky auto one I had). My question is.. how do I clean the sunroof drains?
    Thanks in advance for the help.. oh! And one more thing.. is there a way I can determine the engine model? Since this car differs so much from the American model (even has cloth seats), I want to make sure it's not just a 240D in disguise.. so where on the engine would the OM617 designation be? Thanks guys!
    It can't be a 240D as those are 4 cylinder cars.
    First thing you need to determine is your chassis type...is this car a W123, W116 or W126? Then you'll know if it had a turbo from the factory or not.
    I can't imagine anyone would go through the hassle of adding a turbo to a non-turbo W123 but they could have installed an SD or SDL engine I suppose.
    I think you are correct about your diagnosis regarding the turbo and the AC problems.
    The chassis type is definately a W123.. I fell in love with that design ages ago, and haven't turned back, since. Like I said, the car is gray-market, so I honestly am not sure what they come with over there in Germany.
    Totally forgot that the 240 was only 4CYL.. whoops. The engine type is an OM617 (Engine says R-O617.9..something), so I'm pretty sure it's a 300D engine. Found it printed on the side of the engine, near the injection ports. Anybody else have one of these Euro models? A good deal of stuff on it, is pretty foriegn to me, compared to my old US model. For example, I can't find the upper valve for the A/C system (to charge / discharge). The lower valve seems to be on the compressor itself, and the upper? Who knows.
    Now, if I only knew what the wastegate valve looked like, where to find it, and how to fix it.. I'd be set! :)
    617 isn't necessarily just a 300D engine. It could be a turbo engine from another model. I'd have to look it up. They are all 617s but might have different numbers after the decimal. It would be better if it wasn't a stock 300D engine, they really weren't built for turbos, but probably would be okay with low boost. Most turbo engines are strengthened internally.
    Have a 300D turbo, the fuel gauge reds full when u fill the tank. However when it starts to to read
    1/2 a tank and below it begins to jump wildly, 1/2..1/4...R. I was told to check the fuel level sensor it may need to be replaced. Its easy to find under the first aid kit but how do I tell if its bad and how do u remove it? Also the reserve light on the fuel gauge stays on all the time.
    It does sound like the float or float switch, yes.
    I don't know any easy way to test it although I'm sure the answer is buried in the factory manuals, using an ohmeter or something. Since the symptoms are correct for a bad float level switch and since you've hauled the old one out of there, might as well take a chance and replace it.
    Recently had the "reserve light always on" problem. Swapped the fuel level sending unit out with a used one (a working used one), and the problem went away. Of course, using a used one wasn't a fix that'd last forever.. and my gauge started jumping around lately, too. Replaced with a brand new one (You can get it cheap from www.thebenzbin.com), and haven't had a problem, since.
    fusefuse Member Posts: 3
    Those cars are great! I've got a 1976 300D that I run on 80% free waste oil I get from restaurants. The car is in awesome shape, but I've got the same problem: it won't shut off.
    I patched up the leaky exhaust system wwhen I bought it last year, and it shut off then. But I banged it up last month and now it won't shut off again. I presume it's a problem with inadequate back pressure due to a leaky exhaust, but I won't rule out an electrical problem (the curse of the 300D).
    Kenji
    As I said in a previous post, I've got the same problem of my '76 300D not shutting off.
    I'm getting tired of opening the hood and pushing the emergency shut off every time, so any help from any of you out there would be greatly appreciated!
    It's a vacuum problem. Exhaust shouldn't have anything to do with it. Or the vacuum - operated device that shuts off the fuel is defective. This is also why the door locks don't work. You have a vacuum leak somewhere.
    RE: Restaurant Oils: --Can you tell us briefly how you solved the filtering and heating of your waste oil? Did you buy a kit from Greasel or some such?
    the 300d turbo is having the same pulsating problems i was having a few weeks ago. I bought and used the bg k44 injector cleaner but it had no noticeable effect. you said in an earlier posting that i should check the waste gate and the hoses to the turbo. also how can i tell if the pulsating while at highway speed (and only at highway speed) could be the fuel injector or the fuel pump. and if so why would the loss of power only happen while on the freeway? if it was the injector or the pump wouldn't it happen all the time? thanks for your help and advice in advance.
    changed the fuel level sending unit, (new) reserve light went out, and fuel level on dash is fine. thanks for your info.
    The injection pump is constructed to provide different fuel deliveries under different conditions of load and speed, so it's very possible for it to behave sometimes and not others.
    I really don't know the answer to your question. I'm not even sure what you mean by pulsating exactly. If you have (and keep) even pressure on the pedal, does the engine slow down/speed up/slow down/speed up ....or ....???
    I still think you should also disable your cruise control for the moment while testing.
    Your injectors could just be worn out---they do wear you know. Maybe if all else fails you can have them pulled and tested--but you need special equipment for that.
    If your 300D has an EGR valve it's worth checking. EGR valves are two way acting. They open by vacuum control or by high exhaust pressure. If the spring mechanism is weak, broken, etc., at highway speeds the valve can leak by causing surging or loss of power. Its not legal but most people block the vacuum line or remove or blank off the valve itself.
    Messing with the EGR valve on a gasoline car is difficult because it can make the car ping (spark knock) dangerously.
    I'm not sure these old diesels even have EGR valves, do they? But anyway I don't think this would cause a pulsation in a diesel engine because a diesel engine doesn't use a throttle for air intake so it is regulated solely by the amount of fuel you put in. Vary the fuel amount, engine goes faster or slower. Therefore, vacuum leaks or more air in the system shouldn't affect it like it would a gas engine, that relies on both fuel and air to regulate engine speed through a throttle plate.
    So what I'm driving at here is that if your engine is running fast and slow, fast and slow, the fuel supply is being tampered with, and varied, by something.
    at highway speeds i keep constant pressure on the gas pedal. The cruse control is inop and does not work as far as I can tell. I will remove the fuse for the cruse control to make sure. The pulsating at speeds is faint, and Im not sure you could feel it if you were not holding the steering wheel. The loss in power happens only on an incline (a hill). So a worn out injector is your best guess, as you cant see the car? Is that a fix at home thing or should I take it to a mechanic? Could you recommend a good diesel mechanic on the east bay? The power locks don't work, I have read that is a vacuum problem,does that have any bearing on my problem?
    Well a loss of power on a hill is pretty much what any 300D will do, but I guess you are noticing more than usual?
    I'm still not sure what this pulsating is as you haven't explained if the vehicle gains and loses speed or if you are just feeling a vibration of some sort.
    ANYWAY, you should have a compression test done, and the valves adjusted (when was the last time?)...at least then you know that you have a basically sound engine and won't be throwing money in the wrong direction. European Auto Repair on Mill St. in San Rafael is a good diesel place.
    Many owners neglect to adjust the valves on these cars and between that and clean fuel, it can make a world of difference in how they run.
    83300sd183300sd1 Member Posts: 1
    Dyates773,
    I just bought a 83 300 SD and I am having exactly the same problems as you are with the A/C. The fan does not stay on and if I change it to constant air, it just blows warm air. I know the compressor is working because it is removing the humidity from the air and dripping water below the car. Did you get any further in your investigation of this problem? Any advice you can give me will be GREATLY appreciated!!
    Tyler
    Okay, since everybody else is posting about related issues.. I figured I'd throw my small problem in here, too.
    Recently got my A/C working again (After finding a bad ground wire behind the compressor relay on my 78 300D Euro). Blows nice cold air (I love R-12 Freon).. The only thing is, at highway speeds, this car tends to run hot. Hot being, at about the 100-110C mark. The aux fan does not kick on while driving, as far as I can tell. However, I've noticed strange things relating to the Aux fan..
    First, and what appears to be randomly, it will kick on at temperatures above 85C.. usually while sitting still for a while. Here's the strange part... if I turn the car off, the fan will stay on! It usually stops after a minute or two.. but still, my last 300D (A 1984 American model) never did this. I suspect it may be the fan relay, so I bought a new one.. however, it has not arrived yet. Any help as to what the problem could possibly be, would be greatly appreciated!
    OK, here's how I run my 300D on waste restaurant oil:
    [1] Get the cleanest used grease you can. I get mine from my favourite Japanese restaurant (Asian restaurants generally really do have the cleanest oil)
    [2] Try to let the oil settle as long as possible [optional]
    [3] I use a Transdapt #1028 (I'm pretty sure that's the model) Remote Oil Filter Mount which fits a regular PH 8A engine oil filter. They are the cheapest and most readily available (under $4; good for about ten fill-ups before it starts clogging, but it really lasts for over 20 fill-ups).
    [4] I pump it through the filter with a cheapo drill pump, but I'm going to get a Fill-Rite Rotary Hand Pump, which should make things much easier, as well as getting me off the electrical grid when I'm on extended trips in my Ford F250 diesel/camper, which I run the same way (although it's a [non-permissible content removed] to start, but it does have two fuel tanks - one for starting on diesel, and the other one for the bulk of the trip on veggie). My deep-cycle batteries aren't in the best shape so they would discharge about half-way through a fill-up during my last big trip (10,000miles).
    Priming has been the worst part, but the Fill-Rite hand pump is self-priming, so I'm hoping that makes this a bit easier.
    The 300D smokes a bit more with 80% veggie oil, but it starts up fine every time.
    So you don't heat the oil while pumping it?
    I know that starting below say 40F can be tough with veggie oil. I remember trucks used to have a little ether injector handle right on the dashboard. That would be great for cold starts.
    dawettedawette Member Posts: 1
    Don't forget about the strainer in the fuel tank. It's a pain to get at, but it can clog. Best to clean or change it when the tank is near empty. You can check the flow of fuel by disconnecting the tank fuel hose where it clamps to the steel fuel line near the rear of the car. With the fuel hose gently clamped you can disconnect the hose open the clamp and the fuel should "rush" out of the line, if it dribbles, the strainer may be clogged, or the fuel level is low.
    koolfrogkoolfrog Member Posts: 4
    My ,newly acquired 1983 300D has non operational door locks and cruise control ; everything else works perfectly . Could the vacuum pump be bad ? Where is the little devil located , and is it expensive to replace ?
    No if the vacuum pump were bad you couldn't shut the car off. I'd pop off a door panel and you'll see the little vacuum motors at the bottom of the door that operate the locks. With the car running see if you get any 'suck" on the vacuum lines.
    I think you have a broken vacuum line somewhere, probably under the hood but it could be the doors.
    I doubt your cruise control has anything to do with this. They are always broken on these cars and it's the amplifier 99% of the time.
    burdawgburdawg Member Posts: 1,524
    The master element (an MB term) is in the drivers door, it controls the rest of the locking system. The drivers door is manual, in other words when you turn the key in the door it locks and unlocks the door, ditto for inside door lock operation. It also operates the master element in the door, which sends vacuum signals to the other doors, trunk, etc to lock/unlock. Other systems components are the resivoir tank, which holds a vacuum to allow several lock/unlock operations without the engine running, vacuum elements in the other doors, trunk, and perhaps the fuel fill door (don't remember if this model had that or not). The tank has a check valve in the vacuum hose leading to it to allow air to flow in one way only, so the vacuum charge will not leak out when the engine is off.
    If it's not been maintained, any of these components could be faulty. I found that a small handheld vacuum pump was very helpful in finding these problems. I could disconnect a line at one point and test a component somewhere else. The factory body service manual was almost a necessity for this.
    I agree with Shifty on the cruise control, the amplifier is almost always the culprit, but there's a possibility it's something else. Other components should be tested before making the decision to replace it.
    ratpawsratpaws Member Posts: 1
    I am considering the purchase of a 1980 300D with 200k miles. The body and interior are very good so the car seems like it might not be a bad deal for $1200 canadian.
    The 2 main problems are failure to shut off when turned off ( apparently a vacuum leak issue )and the air cleaner housing is getting oil into it somehow. The levels are quite substantial (there was about 1/16 of an inch of liquid everywhere in the housing.
    The car started easily when cold and ran smoothly so I suspect that the engine clearances must not be terrible but I don't know why this oil is being forced into the air cleaner.
    Any ideas?
    VTM
    It's blow-by from worn piston rings. Diesels require tremendous compression ratios so any internal wear will show itself. Probably a tired engine with those high miles but it may run like that for a long time. It all depends on how much oil it uses. These engines can stagger along in sub-standard condition for quite a while, which is part of their charm. Just keep adding oil.
    If you have decent WARM oil pressure and you aren't belching blue smoke, you might be okay. Look for cans of oil in the trunk, or ask the owner what the oil consumption is, then double it :P
    jerrygarciajerrygarcia Member Posts: 1
    My Chiltons manual does not cover R and R of rear wheel bearings. How do I do this... today?
