Can I just change grades of gasoline?
I am NOT a mechanic by any means, so please stay with me.
Since day 1, I have been feeding my Toyota Corolla (in the year of 1999, and I bought the brand new one.) with super gasoline (93), and I didn't realize that the car only needed regular gasoline (89) to run until last week. To save money on the gasoline, can I just switch the gasoline from 93 to 89? Or is it ok to switch it to regular gasoline? If ok, what do I have to do particularly to avoid any problems? Please let me know... Thank you.
James
James
But sure, just put in what the manufacturer says, no problem, and save yourself some money, too.
now if i maybe had a sports car, then i guess i may see a difference.
No matter how you slice it, you are better off using 87.
Best Regards,
Shipo
Weird question - I have an '88 Suzuki GSX-R 750 with a Keihin Flatside carb conversion, Yoshimura Carbon Fiber Duplex Exhaust, etc. Am I right by running the highest octane I can get? It's not injected and has no ECM, so wouldn't better fuel make a difference, quite contrary to injected and emissions controlled cars?
I suspect that it is high compression engine and using higher octane fuel gives you better milage.
Krzys
PS Manufacturers often say that engine requires regular gas but HP numbers are obtained using higher grade. Of course ECM (the computer, which controls engine) must be able to utilize higher grade.
PS2 Yes you can use the lowest suggested octane any time you want and if it is not available you can use higher or lower (I would suggest higher ;-). ECMs are quite clever nowadays.
A high compression engine benefits from high octane, normal engines will have no benefit from it. I have always noticed worse gas mileage when using high octane in normal comp-ratio engines.
Very low octane gas can cause knocking in an engine and a modern ECM will adjust spark timing to compensate for it, you would want the cheapest gas that does not knock (your ECM can only make so much timing change..)
If your book calls for 89 then try to find 89 and if you can't find it use the 87 , only use the 93 if the knocking is constant. Typically the ECM will keep the timing advanced as much as possible and you will hear a slight knock every now and then which is ok, constant knock will happen if the gas is just way too low on octane rating.
The lower octane gives less carbon buildup like several folks have already stated,,,,save yourself some money, and help clean up deposits while you're doing it,,,,gas isn't getting any cheaper at the moment...
It will trash the spark plugs that are in the engine now, so get a fresh set for after the cleaning process. Also, have a buddy or significant other manipulate the throttle - your engine doesn't like burning trans fluid and it'll smoke like crazy and try to die.
Revenge tip #1 - aim your car's exhaust towards the neighbor you don't like.
