Mine was done at a Toyota dealership which was running a special at the time-still I think 600 sounds way too much.Try Pep boys see what they would charge you for a water pump
Usually the 2nd one fails right after the first.
So if a tail light burns out, replace the other side at the same time, else you'll be doing it again a week later.
We purchased a 2007 Sienna new in April of 2007. We purchased the prepaid maintenance from the Toyota dealer when we bought the car. It covers scheduled maintenance for the first three years.
We just took the Sienna in for scheduled 15,000 mi. maintenance. This is our fifth visit since we've owned the car. Every time we've been in, without fail, the dealer has tried to get us to agree to pay for items that they "recommend". Today's nut would have been $329 if we had agreed to it. It included draining and refilling the transmission fluid, among other things. The only "extra" I've agreed to, in a moment of weakness, was a new cabin air filter, and I probably didn't even need that.
There isn't a manufacturer in the world, unless you're plowing snow or pulling stumps, that requires a transmission service such as this at 15,000 mi. After a brief and polite discussion we finally were able to make it clear to the service adviser that the only work we wanted them to perform was that which was covered under the prepaid plan. This includes any maintenance required by in the Toyota warranty book, including oil change and tire rotation.
I guess they're just doing their job trying to make a few extra bucks, but it's darn annoying to have to have this discussion every time we go to the dealership. Bottom line: beware of dealer service extras. Don't agree to them unless you think you really need them.
It's better to be safe than sorry, the brakeage of the timmimg belt will ruin your engine. Trust me I fell in the same thinking with a nissan that I owned, but this time they were right. I didn't replace it, when it broke, it ruined the valves permanently. (a very expensive job) I ended up getting rid of the car
Also, I have just turned 100,000 miles on my 2001 Sienna. I know the maintenance manual calls for timing belt replacement at 90,000 miles. My local Toyota dealer is telling me that the timing belt on my 2001 Sienna should last for 300,000 to 400,000 miles or at least 15 years. My van is running perfectly right now. Should I believe what the dealer is telling me, or should I have the timing belt and water pump replaced now at 100,000 miles?
Thanks for any help.
By the way neither of these parts lasts to 300,000 miles.
AZdino ---
I went on-line and found the specs for the BCI Group Numbers, but they list the sizes as "Maximum Overall Dimensions", thus I guess smaller is acceptable.
Thanks for any advice anyone has.
I think you'll be OK as long as nothing works itself loose. Check it each time you check the oil.
Does this make sense to anyone? Anyone else experience this kind of problem with a supposedly super-reliable vehicle such as the Sienna?
Don't tell them about your side job as a minivan rally racer. LOL
I took it back to the dealer who with a smile had the strut replaced under warranty.
Recently, in april 2009 after 80K miles I started hearing a persistent knocking sound in the front left side. I checked the strut and found what looked like a leak. Took it to Toyota who said the strut had leaked and needed to be replaced. They said it will cost "between 355 and 800$" because they may have to change other parts related to the strut.
The problem is they did not have the strut in stock. They had to order it. We have been waiting since then and no replacement strut has shown up yet. They called me this morning to say the part is still backordered and that they dont expect it soon !!! I think I am going to go to a local garage and get an OEM intalled except you have to do both sides when you change for another brand of struts
I guess once it's hot enough the golf ball will melt in the muffler. Per wiki:
They usually consist of a two-, three-, or four-layer design, (named either a two-piece, three-piece, or four-piece ball) consisting of various synthetic materials like surlyn or urethane blends
Not sure if any of those will damage the metal muffler as they melt. Or if the fumes will be toxic? :confuse:
Any chemists around? What happens to surlyn and urethane as it melts?
Most of those repairs are wear and tear- brakes, rotors and belts- that need to be replace at that interval anyway. Spend the $1300 in maintenance costs and the van will treat you well for a lot more miles.
I'm guessing that the $1200 number is a typo, since online sites list a new motor at <$100. If it's not a typo, take your van to another shop because that one is ripping you off. The wiper motor is not a normal wear and tear item and an unfortunate premature failure that we'd rather not have; at the same time these things happen in this less than perfect world. If that is the only expense outside of normal wear and tear, then don't get too worked up about it.
A new car every 5 years is a waste of money with the depreciation as you drive off the lot will setting you back more than $1300.
The all-weather mats followed right after I realized that the carpet mats in the CF package were a lighter grey than my carpet and were backed with an open cell foam.
After mats got wet the foam started to disintegrate and adhered to the carpet. Mats on '05 Highlander and previous vehicles all had a solid rubber/vinyl backing.
I use an old sheet instead of the cargo liner and have just ordered an Intera tarp from Costco.com which will protect the seat backs and sides if a lot of dirty gear has to be carried. Tarp seems easy to fold and store.
If you're reading this, you probably have these codes. Search the internet, and you'll find many similar problems on Toyotas from this era, fixed the same way. If you can't find a stuck valve, or holed hose, or failed gas cap, the canister is a likely culprit. My canister cost $229 on eBay, thru a Toyota dealer in Vandalia, Ohio...
Good luck, Pete
i cannot see anyhing and have to remove the headrest in fear of not seeing traffic.
i even tried putting the low profile middle seat headrest there but it will not fit.
love the car and am a fan of toyota but there are a few things that make me go: huh?
sadly 2 of my kids are taller and i do have some adults in the car as well.... just have to live with it i guess.
i park my 2010 le in a garage and usually leave the power doors and the back hatch open...so far, so good but i do not want to do it if it will drain the battery.
thanks for any feed back.
i think you can also press and hold the small round button on the drivers side dash....it is one of the switches by your knees(2010), but if the tire pressure is still low it will come back on.
and "baba-booey to you all"
I have a 2003 Sienna CE that I bought in January '03. It was about the last '03 they had before the '04 started showing up. It now has 115k miles, and it has been an excellent car overall.
Here is an issue that cropped up at least a couple of years ago:
On cold mornings, when the transmission holds 2nd gear until 35-40 mph, the engine revs to ~ 3000-3500 rpm. At that time, there is a noise from under the hood that sounds like a rattling heat shield or like pinging, depending on who you ask.
I can reproduce the noise with the car parked and the hood raised by grabbing the throttle directly. The noise appears to come from the front cylinder bank. My mechanic suspects the VVT mechanism, and I suspect it'll be spendy to fix. It also doesn't seem to be too big a deal, as it's been going for around 30k miles.
When the car is warmed up, the noise disappears.
Recently I was biking home from work and was passed at close range by another l Sienna with exactly the same noise... except louder.
So I thought I'd ask: Is anybody else experiencing this noise? Has anyone had it fixed, and how? Advice and comments are much appreciated.
Thanks in advance,
-Mathias
Thanks for your input.
