Chevy Silverado
Do you use the tow/haul switch when towing your popup? I would think that would help alot when pulling your popup. I have the same truck except with an open 3.73 axle. I've yet to tow anything (sold our Jayco popup before I bought the truck). I've toyed with the idea of buying a small travel trailer or a small Trail-Lite travel trailer and was wondering how the V-6 would perform. The V-6 is adequate for the flat country where we live but I've been extremely disappointed with the rattling also. In hindsight, I wish I had bought a Tundra.
BTW, I had a Cherokee before this truck and it performed excellent when towing the popup. I gave it to my Dad and it is still running strong with 190,000 miles on the 4.0 straight six.
-David
Thanks for your reply. I also have three kids, Do they fit okay in the cab? So far I have been using my Toyota Sienna mini Van to tow my pop up. It does fine but I try to keep the trailor light and I have not taken it up to the mountians yet. Also do you tow your trailor with the ball mounted on the bumper or did you get a towing package with the tow hitch?
Just joined and want to jump right into a question. I have been looking at the Pro-Tec box option on a new Silverado but have heard now from two salesman that it is no longer available to order. I can find some still in existing inventory but then I can't customize the other items I want.
Has anyone heard about the discontinuation of the Pro-Tec?
Does anyone have it and what do you think of it?
Has anyone just did a spray in liner? What was the ball park cost? Any advice on doing this?
Thanks all.
Over-the-rail cost me $495, and that's about average for here in the Seattle area.
No problems with it, and I'd do it again in a minute.
My drop in liner with a rubber mat works great. All I haul is dead deer, geese, ducks, lumber and firewood.
We noticed a significant increase in power after about 10K miles. Before that, it needed a downshift on some hills that it will now pull.
Enjoy your truck!
Mike L
You say you're not towing, so I would go with the 6.0 with 3.73 gears if available. It will be plenty of truck!
I have a 6.0, auto, 3.42 gears. Plenty of power and reasonable mileage. 14 city/16 hwy
Are you sure about that?
tow a 29 ft. camper, and a 32 ft. wellcraft
boat on a BIG hydralic trailer (Just to get it
from storage to the water for the summer. Cops
don't bother ya in the 1000 islands about over-
width--length BS.) I just push the tow haul
button and let that bad boy do its thing.
Well its snowing cats and dogs here for days in
Syracuse NY area...Time to plow some more snow !
Make some $$$$$$.................geo
Should have known you or obyone would. The 3.42 was on my '99 Sierra SLT EXT SB, with 5.3, auto.
Knew as soon as I posted that didn't look right, but was on my way out the door to work....(my excuse anyway)
My '02 Sierra 1500 HD CC SLT SB has the 6.0, auto, 3.42 w/locking rear diff - and plenty of power pulling a 26' Trail-Lite across the hills of central Texas. :-)
wheel when you are turning it .. its sounds like
rubber on rubber squeaking noise ?
Thanks in advance!
Ryan - as to #546 - I have 3.42 on the brain. I have 3.73 gears, not 3.42 with the 6.0.
I am currently getting 10-12 city and 12-15 highway. My highest milage is 19.5 this past summer through the mountains in NC. THis is on a 5.3 with the 3.73 Z71. Also if you are going to go with larger tires get the 4.10 to compensate.
It takes the same amount of power to move the truck with either gear; the same amount of power takes the same amount of fuel; the cpu will control the fuel injection to optimize the mixture.
The 4.10 may deliver slightly (0.1mpg) lower economy due to higher friction losses from higher engine speeds. Of course, the 4.10 may deliver slightly better economy (0.1mpg) due operating closer to the torque peak. All in all, it is a wash and the mileage varies more from identical truck to identical truck than it varies from final drive ratio.
Mike L
Mike .T.
Mike L
My brother installed the K&N factory replacement ($45.00) in his '02 1500 HD 'Rado and is impressed with the improvement over OEM. OEM filter from dealer is appr $32.00. K&N is worth the extra $.
The local dealer has replaced the power steering pump once. Their answer as to why this has happened 3 times since is that "the line is contaiminated."
Has anyone ever had something like this to happen? Any ideas?
Central Office
Chevrolet Motor Division
General Motors Corporation
100 Renaissance Center, P.O. Box 100, Detroit, Ml 48265-1000
C99066E
February, 2003
Dear Chevrolet Customer:
As the owner of a 1996, 1997, 1998, 1999, 2000 or 2001 model year S-10,
Blazer, Astro, C/K Pickup, Tahoe, Suburban, Chevy Van/Express, 'P' or 'W4'
truck that is registered in California, equipped with a 4.3L V6, 5.0L V8 or
5.7L V8 engine, and California emissions, your satisfaction with our product
is very important to us. Your vehicle was provided with a new vehicle
warranty, which covers certain parts of your vehicle for a specified period.
These warranties are of considerable value to you if you should experience
problems with your vehicle.
This letter is intended to make you aware that some 1996, 1997, 1998,
1999, 2000 and 2001 model year S-10, Blazer, Astro, C/K Pickup, Tahoe,
Suburban, Chevy Van/Express, 'P' or 'W4' trucks that are registered in
California, equipped with a 4.3L V6, 5.0L V8 or 5.7L V8 engine, and
California emissions, may experience a "Service Engine Soon" light, misfire,
rough idle or hard start due to a deposit build-up on the Sequential Central
Port Fuel Injector (SCPI) poppet valve(s). The deposit build-up may cause
injector poppets to stick closed. Certain fuels have been found to interact
with the SCPI system to cause the deposits.
This is not a recall. Do not take your vehicle to your Chevrolet dealer as a
result of this letter unless you believe that your vehicle has the condition as
described above.
What We To address the above-mentioned condition, General
Have Done: Motors is providing special warranty coverage to owners
of applicable vehicles registered in California. If the SCPI
system failure condition occurs on your 1996, 1997, 1998,
1999, 2000 or 2001 model year S-10, Blazer, Astro, C/K
truck within ten (10) years of the date your vehicle was
originally placed in service or 200,000 miles, whichever
occurs first, the condition will be repaired for you at no
charge. Other conditions that may cause similar or
different driveability complaints, or cause a Malfunction
Indicator Light illumination, that are not a result of SCPI
system failures are not covered by this special policy.
However, you will not be charged for performing a system
check when determining that the SCPI system is not the
cause. Any repairs that would be necessary due to other
conditions would be your responsibility, if you elect to
have your dealer provide the service.
What You Repairs and adjustments qualifying under this special
Should Do: coverage must be performed by a General Motors dealer.
You may want to call the service department at your
dealer to find out how long they will need to have your
vehicle so that you may schedule the appointment at a
time that is convenient for you. This will also allow your
dealer to order parts if they are not already in stock.
Keep this letter with your other important glovebox
literature for future reference.
Reimbursement: If you have already paid for some or all of the cost to have
the SCPI fuel system repaired or replaced, and you have
not received reimbursement under a Vehicle Service
Contract, and the in-service time and mileage was less
than 10 years and 200,000 miles, you should write to
Chevrolet Motor Division, P.O. Box 33170, Detroit,
Michigan, 48232-5170 to seek reimbursement. Please
provide your original paid receipts or invoices verifying the
repair, the amount charged, proof of payment, the date of
payment of those charges and proof of ownership of the
vehicle at the time of the repair. This information must be
provided within two (2) years after the date on which you
paid for the repair or within two (2) years of the date of
this Special Policy Bulletin, whichever is greater.
If the work was done by someone other than a GM
dealership, the amount of reimbursement will generally be
limited to the amount that the repair would have cost GM
to have it completed by a GM dealership.
If you have any questions or need any assistance, just contact your dealer
or please contact the Chevrolet Customer Assistance Center at 1-800-222-
1020. The deaf, hearing impaired, or speech impaired should call 1-800-
833-2438 (Utilizes Telecommunication Devices for the Deaf/Text
Telephones, TDD/TTY).
We are sorry for any inconvenience you may experience; however we have
taken this action in the interest of your continued satisfaction with our
products.
-David
kip
-David
In checking the Bosch site it appears they don't even offer the +4 for any vehicle newer than,.... 2000!!?
Descriptions of the two trucks:
2001 Silverado 2WD 1500 LT, 5.3L, 3.73 locking rear.
2003 Silverado 2WD 2500HD LT, DuraMax/Allison, 3.73 locking rear.
First, the obvious --- the new truck is a towing horse! The DuraMax just rocks pulling my 8000# RV with effortless ease, and the Allison tranny is pure magic, especially in mountain-style driving. Blows away the Power-Stroke and Cummins competitors. This could be the subject of a whole message thread.
Fuel mileage is WAY better than expected, 20-22MPG empty, and 13MPG towing 5th-wheel RV.
Here, I want to compare the changes from 2001 to 2003 in the rest of the truck.
1) The redesigned front end is simply ugly, REALLY UGLY! What a shame.
2) Both trucks are LT trim level, but there are a lot of changes, some good, some bad.
GOOD: Dual zone climate control. Bose speaker system. XM-Radio option. Driver info center. Two-driver personalization. Power-fold mirrors (great entering car-washes).
BAD: Overhead console trimmed back to almost nothing. Cheap plastic (vs chrome) trim on outside mirrors. Body side moldings shortened to just the doors, instead of extending back to rear wheel well. Tail-light assemblies not as nice as 2001 -- cheap looking.
But hey, for towing it simply is perfect.
Hans
Hans
1) What makes a 2500 different from a 1500HD?
2) What makes a 2500HD different from a 2500?
3) Is a 3500 just a 2500HD with duals?
Hans
BTW to follow up on #571; Yes, AutoZone did accept the return. Miguel Prada (God bless his patient soul) spent half an hour trying to find the right plug, finally concluding that the one's I had bought were indeed correct, but allowed the return based on my dissatisfaction. Next day, I'm talking to another salesman and happen to mention the +4s and how they didn't work. He says the misfiring is common when their first installed; He's seen it a lot and that I should give them a couple of hundred miles trial run. Excessive carbon build-up around the spark plug hole is the reputed cause, which makes a lot of sense; The main reason I'm junking the originals is because of a crusty deposit on the electrodes. Sooo, I go back to Miguel........Tomorrow they go back in.
Sigh,...life is trial and error. Sometimes it seems mostly error.
Also, FYI: Chevron mid-grade (89 octane, California blend). Last fill-up, $2.139 per.
-David
And yes I do have what GM is calling "Piston Tip".
Any input would be welcome.
