Why shouldn't I buy a 1996 LINCOLN MARK VIII?
I'm thinking about buying a used 1995/1996 Lincoln Mark VIII. What is the common problems with this vehicle and what should I be looking for
(high miles, etc.)???
In 96, the LSC Mark VIII came with HID (high intensity discharge) head lamps and this was a great improvement. In 97 and 98, a higher profile HID headlamp system was standard on ALL Mark VIIIs (including the base model). Another problem on these cars is the imfamous Ford/Lincoln/Mercury tranmission shudder caused by rather smallish clutch surface area that thends to overheat the transmission fluid (this has been going on from 1992 to present on RWD Ford products). Ford's cure is to change the tranny fluid and sent you back on the road. They have updated the tranny fluid over the years and now Ford recommends Mercon V fluid.
My wife's car has had several trannys done under waranty and my brother's 2001 Navagator just had this problem at 40K miles. I put Mobil 1 synentic fluid in my wife's car and so far (knock on wood), it's okay.
If you want Mark VIII, I would try for a 97 or 98 as a little more money now will get you a lot less problems later.
I have a 94 Mark and it's been a very good car.
No one has mentioned the air suspension. That can be
a problem. As the cars age, the rubber bladders on the
air struts dries out and starts to crack. One the struts leak
they must be replaced. The parts are fairly expensive
(about $350 for each front air strut) but it is a simple repair
to have done.
All in all, I definately recommend the Mark 8. The car
is long, so that takes some getting used to, but there
is plenty of room and power.
Good luck,
Barry
Or this:
https://www.arnottindustries.com/Shopping/SelectModel.asp?sManufacturerName=LINCOLN&manufacturer_id=-1350090164
Also i would not say ford has a great reliability record but some people love them.
Anybody who doesn't like Ford's build quality has never owned a Town Car or Ranger. There are turkeys in their line, and they get what they deserve from that. Explorers, Crown Vics, Grand Marquis, you can't find much better on the road, especially for the money, overall.
I wonder why you're on this board? Well, welcome anyway. Maybe we can win you over! (Hint, don't buy an old Continental, ok?)
