Subaru Crew Problems & Solutions
1165166168170171385
  • locke2clocke2c Member Posts: 5,038
    just don't let it overheat. ever. see that needle climbing and you can't get it down with airflow through the radiator and the heat on full blast... SHUT IT DOWN.
    they don't seem to be fixable after the engine cooks real nice, even just one time.
    -Colin
  • outback_97outback_97 Member Posts: 130
    Steve:
    Sorry to hear that. FWIW, I called a dealer in town here, and they indicated they had 3 sets of the revised HG p/n 11044AA610 in stock. Let me know if you want the phone number, maybe they could UPS or FedEx it?
    Colin:
    Since I have this engine, the issue is on my mind as well. I had a good conversation w/ a Subaru service guy recently and here's a summary:
    1) In his opinion, overheating causes the HG problems, not the other way around. OTOH, many folks have not seen the temp gauge indicate anything out of the ordinary until it was too late.
    2) I asked him if there were any pre-emptive measures to take to avoid problems. He suggested coolant system maintenance, replacing t-stat, and replacing radiator cap to insure all are working properly. Also, make sure the H2O pump is working properly. As you said, do not let things overheat.
    utahsteve
  • fibber2fibber2 Member Posts: 3,786
    Thanks for the offer. I have passed everything on to John. Thanks again for everything!!! Needless to say he is not a happy camper... He went away early for the Holiday weekend so I won't see him until mid next week. Maybe by then George will have the gasket set in and can start working on his car.
    Steve
  • kenskens Member Posts: 5,869
    Loosh -- Aw, boo. So you didn't decide to go to larger rotors.
    Colin -- I thought you were pretty happy with stock pads, no?
    Well, my Phase I is at 86K now and so far so good...
    Ken
  • dcm61dcm61 Member Posts: 1,567
    I suspect that my Phase I ('96 Outback A/T) apparently was developing a head gasket leak at 120k miles as I was getting oil in the coolant. Last August, I traded it in at 128k miles for $4500 on an '03 Outback. I got the '03 at invoice (VIP). If it was indeed the head gasket, then in reality I guess I got closer to $6000 - $6500 for trade in. It also had the center differential binding which probably would have cost $800 to $1000 to fix.
    DaveM
    Ken,
    the stock BMW pads perform extremely well, but they dust very heavily. I hate that
    On my friend's car we're trying EBC greenstuff to see how they do. I'll probably try Hawk HPS on my M3 --needs pads soon by the sound of the squealers.
    -Colin
    Before you compress the pistons back into the calipers, remove some of the fluid from the master cylinder using a clean turkey baster, or similar tool. Otherwise you will suffer the fate that I did about 20+ years ago - the displaced fluid will overflow the MC and you will have a major mess to clean up!
    Steve
  • babaorileybabaoriley Member Posts: 74
    http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline- /search_results_product_detail.d2w/report?prrfnbr=15610742&pr- menbr=5806&usrcommgrpid=
    For one-man brake bleeding operations. Fits most bleeder screws. One way valve allows fluid out but stops fluid and air from returning.
    Works great. You do have to go in the car to pump the brakes and make sure your master cylinder level is maintained. I also keep the valve below the fluid level in the overflow jar because I'm not too sure of the quality of valve not allowing any return air.
    It should be easy enough to make. Just use the typical brake bleeding tubing and a one-way valve (I don't know where to get these).
    -Brett
  • wrxcowboywrxcowboy Member Posts: 4
    Thanks for the advice junkher. I'll check it out tomorrow.
    Thanks again Matt
    I'm actually gonna get the speed-bleeders for my cars seems like a worthwile option.
    As for pads, i've experienced good things with the Hawk HP+ pads, the impreza guys run them at the track and love em.
    Carbotech are great but big $ compared to the others.
    -mike
  • forestergumpforestergump Member Posts: 119
    I just replaced the OEM Yokohama tires with two pair of the orginals at 53K and they seem great. I didn't have any problems with the stock tires, and the new ones seem fine.
  • mrbo3mrbo3 Member Posts: 1
    I have a 2001 Outback LTD Sedan with 20K. The car has been in the shop more than out and the dealership has blamed me for all it's problems, so I'm sorry to say that I'm glad to read these posts and see that others have had the same problems and it's not me. I purchased the car new and at 10K had front rotors replaced at 17K rear rotors replaced as well as all brake pads. Tires have all been checked out and are balanced and rotated. Now the steering shakes starting at 30 mph and continues. Any suggestions before I go back to the dealership and they tell me it's something I'm doing wrong or it's the roads that I'm driving on?
  • subearusubearu Member Posts: 3,613
    If it's shaking without applying the brakes, then you likely need to have the wheels balanced. Possible that one of the existing wheel weights fell off causing the vibration now.
    Try to find a service place with Hunter equipment - it's probably the best balancing equipment out there. http://www.gsp9700.com/ - the site has a locator for finding a place near you that has one.
    Also, don't let the dealer bully you around like that. Take your business elsewhere (hopefully another Subie dealer is nearby).
    -Brian
  • fsvfsv Member Posts: 196
    sometimes you think that all these quality evaluations are B@, but when it time comes and you are looking for a deal - head spinns.. What would you guys say to '02 brand new Impreza RS with 50 miles for $15G's? At the moment I am trying to talk dealer into 14G's - can hear their teeth chirp - but they are talking to me - every day works against them, as I understand... I am afraid to have clutch problems on 02 car - I understand, that 04 car clutch was changed to the better.
  • unhappysubaruunhappysubaru Member Posts: 3
    I am wondering if anyone has experienced a complete failure of vehicle while driving???? Three(3) times, my 2003 Outback LLBEAN has completely shutdown while driving, including 1x on a major highway!!!
    When I brought my car in to the dealer for service, I was told that they were astonished and had never heard of the problem previously. Then, the service manager called to tell me he was in touch with Subaru USA and "you are 1 of 4 cases nationally." My car spent thirteen day in service. The Fuel pump relay was replaced. This is the most serious problem I have ever had with a car. I have become afraid to drive the car, not knowing when it is going to shutdown. This is one of several problems with this car. I am getting no more than 15 MPG and the service department answer is my mileage is unacceptable."
    Do I have a lemon? Has anyone else heard of OR experienced similar problems?
  • jimbob17jimbob17 Member Posts: 77
    I never had complete failure but my 87 GL would stall going to or from work. It would be out of commission for five to twenty minutes then it would start up again. The dealer couldn't find the problem by scanning the computer. My local mechanic didnt have a diagnostic computer but found the problem with luck and I guess vulcan mind meld. I think it was a oxygen sensor. After it was replaced no problems till I put her out to pasture.
    I've seen on these boards a couple of instances of something like this happening - but in those cases the owner had an aftermarket security alarm installed by the dealer.
    It's possible in that case that the aftermarket alarm is interfering with the system electronics. If you happen to have an aftermarket alarm (not the OEM Subaru Security Upgrade), then perhaps this will help point them in the right direction.
    If it is not aftermarket, then give Subaru a call (1-800-SUBARU3) and start a case with Customer Service.
    Regarding the mileage, are you doing a lot of city mileage (stop/go, short trips)? Do you drive with the vehicle in 'D' or '3'? How does the engine run otherwise (smooth reving, smell of rich burning exhaust)?
    -Brian
  • mws1672002mws1672002 Member Posts: 19
    My wife purchased a 2003 Outback Sedan with the H-6 engine. It quit on her six times in three months. No warning just the engine shut off, and all the lights on the dash came on. Subaru tried to fix the vehicle but could never find the cause. In April they gave her a new Outback, the identical car with the H-6 motor. After 1000 miles the car exhibited the same problem. It shuts off for no apparent reason. I believe there must be something wrong with this engine. Does your L.L. Bean also have the H-6 engine?
    Brian-
    Thank you for your input. Unfortunately, the problem is not so simple. The dealer says that Subaru USA is aware of the problem. I have no OEM security system, except for the one that came with the car as standard equipment. The mileage problem is frustrating because I am getting nowhere near the average mileage listed on sticker. Anyway, the car is back in the shop. Thanks again.
    Wow-
    That problem seems similar to mine except the entire electrical also shutdown. I had to put the car in Neutral while driving and restart the car. I believe that it is an H-6 engine. How many times did you have to send the car in for service? I wonder if you were one of the four problems nationally? Do you know of anyone else? What did they tell you?
    I think it sounds like the exact same problem we had to stop the car and put it in park in order to start the car. If you want to email me at halfpass44@hotmail.com I will fill you in on what we have experienced.
  • huzunhuzun Member Posts: 1
    Hi all
    First, thanks for all the messages in this and other forums. Very useful information.
    I am planning to buy a Forester, but I have a big decision to make. I am thinking of a 2003 XS Premium (manual). These days, one can buy it for a reasonable price. The only problem is that I will be out of country for 6 weeks around October. I am just wondering if parking the car for 6 weeks, 4 months after buying it, would cause any problems for the car. My other option is to wait until I am back and then buy a 2004 model. Any ideas?
    (Of course, I am still thinking if I should get an XT instead. That's another cause of a headache for me...)
    Still, it doesn't hurt to open up a case with Subaru Customer Service using that 800#. Sometimes the dealer try to figure out a solution on their own and not enlist the help of SOA. It's a free call too! ;-)
    Regarding the mileage, with the electrical problems you've had, I'd fix that before looking into the MPG. Easier to investigate that way.
    Also, please join us in the Subaru Crew discussions http://townhall.edmunds.com/cgi-bin/townhall.subaru or through the Owner's Club topics.
    -Brian
    Sounds like a bad ECU. I think they reprogrammed some of the early ones, not a lot though. Has it happened again since the dealer looked at it?
    huzun: I'd change the oil right before I left, and then again when I got back. It should be OK. You might need to charge the battery when you get back, or maybe disconnect the negative battery terminal before you leave.
    Now is a good time to buy if you want a good price. The 2004s are coming and incentives are up on the 2003s. I helped my sister buy one this weekend for invoice minus the regional incentive, plus 6 free oil changes.
    -juice
  • georgeinmdgeorgeinmd Member Posts: 27
    There was a discussion on clutch shudder in Foresters on the NASIOC board a few days ago
    ( http://forums.nasioc.com/forums/forumdisplay.php?s=&forumid=3- 6 ), though I can't find the thread now. Someone posted a scanned copy of a TSB, # 03-51-02, dated 1/15/03, which prescribed replacent of flywheel, disc and pressure plate with updated parts on all '99 - '03 vehicles with a shudder problem. I saved the scanned copy, if anyone would like to see it; obviously, I can't vouch for its authenticity. With my '99 out of warrenty, would I have a ghost of a chance of free replacement?
    Thanx! -- George
  • junkherjunkher Member Posts: 27
    I think JD gave Subaru a break!
    My wife and I have had more wrong with our 2002 Outback than right. Back in the shop again!
    (NUMBER 5) Car has less than 20000 miles. Worst most unreliable vehicle we have ever owned.
    The shutting off thing . I would prefer that to what our crappy car does.
    Ours shutters first, bucks like a damn bronco then accelerates by itself rapidly forward. Be quick on the brake or you'll smash into someone....... Scares the bajeebers out of you. Ours sits parked a lot 'cause my wife is afraid of it. I prefer our gas sucking p-up truck.
    P.S. For those of you who love Subs..
    I am happy for you ..
    If you're not driving it, trade it in soon. There's a bad apple in every batch, and if you're the one that got it, cut your losses.
    I'm tempted to ask for a free new clutch, though mine is OK. ;-)
    -juice
  • p0926p0926 Member Posts: 4,423
    Or as a last resort... if you can't get any satisfaction from the dealer or Subaru, check out your state's "Lemon" law. No one should be saddled with an unreliable car.
    -Frank P.
    P.S. Sorry your Subaru experience has been so bad. Hope you have better luck with whatever you replace it with.
    Here is a summary by state:
    http://autopedia.com/html/HotLinks_Lemon2.html
    Though the word "lemon" is overused, often it has to be less than a year old to qualify for that term (legally).
    -juice
    Although the car has about 20,000 miles on it, it is only 7 months old.
    The mistuned AM radio noise the transmission makes is present on all the the Subaru Outback cars I have been in. When you get over ~60mph the car tranny sounds like the radio is between AM stations. The shop does not know WHY they do it. They even tried replacing the transmission...... They cant fix it. Some are worse than others. The rest of the stuff the car is doing is plain dangerous, not JUST annoying.
    I wonder if the tires have a bit more noise than the past ones. You have an '02 with the Bridgestones, correct? How are the tires wearing - evenly? How much tread is left?
    FWIW, no mistuned AM noise from the tranny here in my '00 Outback. :)
    -Brian
    I wish the noise was only from the tires ( which ARE noisy by the way). They are wearing evenly and frankly seem to be lasting very well. I have looked carefully at all four, none of which show anything out of the ordinary such as camber/caster mal-adjust. The noise is a high pitch at the same frequency an AM radio as carried on. I originally thought it was a noisy alternator because it varies with speed. The Subaru shop took the car out and traced it to the transmission ( they said anyway).
    It truly sounds JUST like a radio is on and squealing quietly in the background ALL of the time. If you like to ride in the quiet (i.e., no tunes ) it drives ya nuts.
  • jlawton2jlawton2 Member Posts: 25
    I was going to write in about a deal I just got (got snookered for?)that has my wife an I kind of upset but I'm wasn't sure if it's appropriate on this board to do that. Is it ok to post about a sales experience if I don't mention any actual names? I would kind of like to know what any Subarau representatives thought so far as the kind of standards and practices exhibited. (my own lack of car-buying savvy will be only too apparent). If only you didn't have to wait to learn the lesson after you have the car, expensive lesson.
    JL
    be one for the smart shopper board, not M&R, right?
    Is it possible to take your vehicle to another Subaru dealer? Not saying they are incorrect with the diagnosis, but in this case it wouldn't be a bad idea to get another set of ears to key in on the noise.
    Also, have you tried rotating the tires? Normal rotation is front->back, but perhaps a X rotation may help?
    Lastly, do call the Subaru 800# and start a casefile if you haven't already. It could help get the right SOA technician into the communication loop with the dealer (whichever one you end up with).
    -Brian
    I just read some of the posts on noises. What a coincidence.
    I was little dismayed to note the noise in the car I just purchased which I didn't notice before because of a.the sales person talking continually during the test drive, or b. the noises are just now starting at (car has about 80 miles on it now.
    I do not have super-sensitive hearing as someone was saying of another earlier poster. But these noises do get irritating (hair-pulling after the first few minutes) and I'm trying to imagine being accompanied by them on long drives. I really do want to like this car, I even bought it some rubber mats and mudflaps...
    Noise list:
    Stero:
    -Crackling sound coming from right speaker with CD  or radio no matter what volume.
    -Buzzing in right speaker when volume is over 7. -Forget turning the volume over 7 or 8 or  significant distortion occurs,(I'm not looking  for  the latest sound in a trick stero just not  Blaaaat!!! when the sightest bass shows up in a  song that you've turnd up high enough to  actually hear.)
    -Woofing sound/sensation, for want of a better word, with stero at any volume that is audible, actually makes my ears ache, like being bassed without sound.
    Car:
    -Buzzing from right edge of dash, hit a slight  bump in the highway, buzzzz for several minutes  after. Hwy a little less than smooth, bzzzzzz.
    -Buzzy rattly noise from right side, mid to  rear,door window, frame, I can't tell.
    Warbling- This may sound weird but I swear there is some kind of high pitched hummy, warbly chuffing sound when I am going at higher speeds, 50-60 or so. It's like a dull ringing, I'll have to try the am radio station thing because maybe that describes what I'm hearing. I swear I am not making this up.
    Vibration-
    -This is the worst discovery. When in any gear but Park or Neutral I feel like I'm holding onto a pad sander. There is a fine high speed vibration that travels from the lower frame into the seat and steering wheel. It makes your teeth buzz. I got the automatic because of the problmes with the manual clutch. Do all automatics do this? This could get old on a long drive and unfortunately I do a lot of long haul driving.
    The last vehicle I had for any length of time was a Mazda B2600 2.6 pickup so it's not like I'm comparing my Forester's amenities to the latest Lexus. I'm beginning to think that I didn't fully appreciate the Mazda its rough charm though I do appreciate it maintaining the cabin when last year I was hit broadside and flipped by a car traveling at 60 mph. Not what I expected from a little pick-up, thank some guardian angel.
    Next car purchase will be from somewhere that lets me take a demonstrator model home for a day. Forget upgrading the speakers , I think I'll need earplugs to travel across country.
    nippononly,
    thank you, I was looking at the "subaru Problems" title and forgot I was in M&R.
    I wish I had found the edmunds discussions groups and other info sooner! oh wel,l next time.
    JL
    I'm searching about for a discussion on how NOT to buy a car, trying various keywords, but finding nothing. Before I start a new discussion on the shopping board if anyone has any knowledge of where else here I might find a discussion of this kind of thing or where the Subaru customer service ears hang out, let me know. thanks,
    JL
    A Subaru rep (Patti aka Subaru_Team) use to hang out in the Subaru Crew Owner's Club topics. She has been on hiatus for a while now (reassignment?), but we are trying to get her or someone like her back participating. She was always trying to go the extra mile to get a resolution for a customer with a problem.
    Until then, you should still consider posting over in the Subaru Crew - Meet the Members topic, as many of the regulars hang out there and could possibly offer more advice on the problems you guys are having. Seems like this topic doesn't have a direct link from within the Subaru Crew Owners Club, so it's possible that some don't even know this M&R topic exists! Here's a direct link to the Subaru Crew home page: http://townhall.edmunds.com/cgi-bin/townhall.subaru
    -Brian
    I know your question was more along the lines of what is good for the car vs cost but I just wanted to say good luck getting a deal on a 2003 Forester, and I really don't mean that sarcastically in any way.
    Be careful, I visited 2 dealers this week and experienced something of a shell game from both along with pressure to sign before it was time. One had responded via internet with a quote and assured me by phone that they could meet my price but things changed after I drove an hour to the dealership.
    I would print out the invoices on the various pricing sites where many of these dealers are listed to have on hand if need be. I got an email form a 3rd dealer with a price quote in B&W but unfortunately afer I had already paid alot more at another dealer. Patience is fortitude!
    I'm not an expert but I just read where the prices on the 04 models are only going up $50 bucks, (Subaru press release site I think) and interest in Subarus is down some, so there may be deals to be had with many of the 04 models, maybe not the turbo thing, but given depreciation it might be worth it to wait for the 04's. I think I'd do that if I had it to do over.
    Hey Jim......
    Wait 'till the shop manager sais
    " MAN, that would drive me nuts" when he is speaking about YOUR new car and all of the noises they dont know how to fix!
    My wife and I dream of the day when we can pawn off our nasty new Outback and get something quieter like a diesel train.
  • newcar4newfamnewcar4newfam Member Posts: 20
    Junkher,
    You've done your venting and we get your point that your unhappy with your Subaru.
    Now lets return to these discussion boards being places for solutions and problem solving. Your venting and frustration is getting old.
    Barkley
  • K9LeaderK9Leader Member Posts: 112
    JLawton2:
    Do you have a sun roof? Many sun roofs when fully open will cause a "chuffing" or "whump-whump-whump" sound over certain speeds. That is why many sun roofs have an intermediate stopping point about 2/3 to 4/5 of the way back. On my Lincoln Mark VIII, the sun roof can be open all the way up to about 35mph, but above that you have to use the 4/5 stop. On my Subaru OB wagon, the sunroof has a stop point at about 2/3 for the same reason.
    The stereo sounds like a bad right speaker. You should get the dealer to replace it under the warranty.
    As to the other noises, I will have to let those more knowledgeable than I weigh in.
    Good luck!
    --K9Leader
  • lark6lark6 Member Posts: 2,565
    I can't say I have the solution to all your problems, but I can offer some suggestions. I have an '00 Forester and, while it's not the same car as yours, it does make noises that I was unaccustomed to coming from a less square car.
    The Forester generates a lot of wind noise simply because of its shape and the fact that it has roof crossbars. The side mirrors also hum a good bit at certain speeds, but that goes away above or below those speeds. Physics wasn't my strong suit so I won't get into vibrational frequencies and such.
    Your radio problems may be the result of a damaged right speaker - maybe the speaker cone material is torn. The dealer should be able to easily remove the panel over the speaker, examine it for damage and replace if necessary.
    Window area noise could just require track adjustments, again can be performed by the dealer.
    The other little buzzes can be a pain in the rear to isolate. I've had that happen with many other cars in my lifetime; sometimes it's just a matter of letting someone else drive the car while you listen and isolate, then tighten down an offending bolt or screw.
    Not sure what to tell you about the transmission vibration. I also have an automatic (and a pad sander) but haven't experienced the sensations you describe.
    Good luck,
    Ed
    At least it's effective therapy, if you feel better.
    But yes, please, let's try to keep this discussion constructive. :-)
    Yes, I am lobbying to get official SoA presence on these boards. I have about 15 letters I'll be submitting tonight to one of their VPs.
    -juice
    Sorry I got a little carried away with my thoughts and criticisms about my park it Outback...
    I will keep it lighter.
    I actually have found a few things here that have helped ( other than just venting from frustration ).
    My apology to those I have bored to tears.
    For those of whom have helped me find answers,
    THANK YOU sincerely.....
    Lance
    Lance Armstrong? How much are they paying you to do their ads? LOL
    (just kidding)
    -juice
    Thanks everyone, I'm almost certain I have a bad speaker and I assume the dealer will fix that. The other squeaking/buzzing stuff, I'm hoping maybe if I wait a bit and see if it'll settle some, like a house perhaps?
    I don't have a moonroof, I should have one! given what I paid but that's another story. The tires are inflated to 29 in front 30 in the rear. Maybe the vibration is from the tires being so new or am I reaching here? I thought perhaps with a few more miles on me and the car and maybe there would be less hum and jitter.
    I'm trying to be optimistic.
    JL
    Inflation of 29/30 actually sounds a little low, JL. If you search in the Forester topic you'll find that many of us run with higher pressures, but not too high. Typical for me is 32/32, 34/32 or 34/34 F/R. Vibration in the tires would be something you could feel in the steering wheel. Causes could also include wheels/tires that aren't properly balanced (e.g., one wheel could have thrown a weight) or are out of round.
    JL and junkher: Not boring at all. Buying a new car is a big investment and if it's not right in your mind, then you want the problems rectified. I can tell you my Forester hasn't been perfect, but with the help of people on this board - including past SoA presence - and a calm, rational approach to Edmund's participants, the Subaru dealer service departments and SoA, I've been able to have those problems addressed to my satisfaction. In many of those cases the problems were addressed much more quickly than I expected, which has made me a pretty satisfied customer.
    Ed
