1. extended warranty protection: I usually pass on this for other purchases but hope to own the subi far past the 3 year/30K miles warranty. No way to predict the future, but does anyone have any insight whether $875 might be worth it for a 6yr/60K (=three more years/30K miles)coverage? the finance person (lot of profit on this I've heard) mentioned the moving parts, electrical and microcircuits that might mess up. Is subi any more durable than honda/vw which i've owned in the past?
2. the dealer also offered a $345 vinyl/upholstery/exterior application package with five-year followup protection (just phone the dealer and they would take care of any significant problem- hard-to-clean grape juice was example) [http://www.expressprotection.com/care.htm] which won't help with dings from rocks but might help keep the sierra gold/beige interior cleaner. What do you think? they said scotch-guard wouldn't cut it and wore off easily.
3. I asked for a tube of gold touch-up paint (see message 193-96) but the subie sales manager said it wasn't available (!?) I'm going to check with parts on Monday, but anyone know cost/availability? maybe I'll wait until/if I need it.
4. I can stow my (one) bike in the cargo space easily. any reason i should put it on a rack above or behind the car instead? thanks.
The point of my question is has anyone else had success getting SOA to cover the entire cost of bearing replacement after the warranty has ended? Obviously this is an unusually high failure rate which SOA is aware of.
I was considering trading up to a new 2003 in the near future but this issue has somewhat soured my taste for Subaru, not so much for the design/installation flaw with the bearings as much as SOA's unwillingness to fully admit the problem and cover the fix. Thanks.
I'm getting an extended warranty for our Legacy, but a 7/100. 6/60 isn't much more than is standard. Our 626 was rated reliable by every source available but we still ended up spending $2500 in the 6th and 7th year for repairs.
It's funny that bearings are brought up because our 626 had a bearing failure at about 70k, and we paid upwards of $900 to fix it. Mazda offered no help, saying it was wear and tear and well beyond warranty anyway. $225 is only a fraction of that, and FWIW the 2003 went to a new design shared with the new Impreza which is supposed to be more durable.
I'd pass on #2. Scotch guard the inside yourself with a can for $4. The factory does undercoating already, where it's needed.
Touch-up paint costs about $5 or so, maybe more at retail.
Does your bike get dirty? I have a hitch and a bike rack mounted on that, and that leaves the roof for a cargo carrier I have (for max capacity).
-juice
-juice
-Brian
Switched to dealer, had the 4th bearing put in about a month ago using extended warranty and now it is making an all too familiar noise. Taking it back in under dealer parts warranty on Wednesday. This will make 5 bearings in 1 year and 25,000 miles. Obviously, I am concerned and will restate my concerns to the dealer. From what I read here and in other forums, it appears that there is an issue with wheel bearings in the earlier Forester model Subaru vehicles.
Is it just a problem with inferior parts, or is there a deeper design problem?
Joel Evans
That shop may not be in business for too long, given the shoddy work. I bet they overtorqued the bearings during the replacement.
Since you have that warranty, let the dealer do it and ask them to double-check on the installation tips from SoA. Done right, they will last. Mine are all original after 47k miles, and I have towed and been off road at the beach and in the Pine Barrens. Not to mention I have Plus sized wheels and tires, which puts extra stress on the bearings.
Installed properly, they will not fail.
-juice
Also, should the fuel filter be changed at 45,000mi? Thanks.
Joe
You ought to look in your glove compartment where you will probably find your Owner's Manual. It will explain (and provide manufacturer's part numbers for) exactly what type(s) of spark plugs Subaru recommends for your specific model and year vehicle. Just check the Table Of Contents or Index.
Sorry!
Patti
I'm sorry you are having a problem and I'm sure we can do something to make you happier.
Patti
The dealer should be able to help you and explain it in more technical detail than I'm able to.
Patti
It is always the right rear bearing that fails. The 1st failure was covered under warranty, the 2nd failed very quickly and was replaced under warranty again. The 3rd failure was also covered under warranty, but now the deal is that the replacement part warranty I was offered is unacceptable - the dealer wants to give me 10 or 12k miles coverage.
I say that is unacceptable as it is clearly a defect in the design of the vehicle, the part or the installation process.
I also have had continuous problems with my check engine light. It first came on at <1k miles. It has been replaced under warranty and under recall. Every time I have the problem I get a different explanation -- tighten the gas cap being the least expensive.
Three days ago I had the car in for service - this time the check engine light is said to be caused by a bad catalytic converter - they ordered the part and expect me to pay for it.
The previous time the light went on it was the emissions canister - or something like that that cost about $80 plus labor to replace. Long story short - I didn't pay and they replaced it as a goodwill gesture.
I also have had to have the tires replaced several times due to excessive wear. Seems the alignment had problems - although I paid to have a 4 wheel alignment done when I replaced the tires the first time.
My car was built in July of 99 (so is it really a 2000?) and so the alignment specs for the 2000 version were wrong for my car. The dealer did a free alignment when the most recent tires went on. We will see....
I had hoped to get 130k miles out of this vehicle but I am not sure if I'll make 80k.
Does any one have any ideas to share?
Regarding the parts warranty - it is 12 months/unlimited miles no matter what the dealer says if it is our part. The Rep. can review that with the dealership.
Please give us a call.
Patti
My question is this - how can one reasonably feel safe that this problem won't keep recurring as it seems to for so many? I simply can't afford these type of repairs and have lost a great deal of confidence in driving my beloved Forester. It appears that installation is an issue but also the wrong type of bearings specified/installed in the first place. I'm very disappointed in the way Subaru is dealing with this problem - forcing the customers to go to extreme lengths to plead their case when they know this is a problem that is not the customer's fault in the least. I traded my Ford Explorer in for this Forester because of the problems associated with tires and safety. I had always heard Subaru stood behind their products but I'm doubting this given their approach at solving the wheel bearing problems(at least Ford owned up to their problems and reimbursed owners for a new set of tires.)
I'm seeking advice on whether to trade the Forester in at this point and cut my losses or take my chances that these problems won't keep recurring and have several more years of happily driving my Forester.
Ken
However, at 30k miles the dealer said I didn't need a plug change until 60k because I have platinum plugs. (A dealer bypassing a chance to pad the bill?!)
The engine is the same as 2001 which I believe has platinum plugs. When I finally change the plugs, I'll let you know what's OE.
BTW - Owner's manual recommends fuel filter changes every 30k, with the usual disclaimers.
Jim
Does anyone have any plastic pieces on the sides of this area to stop airflow?
The area is about 3" long and 4 1/4" high, or about 13 sq inches. The filters are about 50 sq. inches together. So about 21% of the air duct's area is unfiltered. And of course the air would rather flow through an unobstructed path.
Sten
I believe some shops out there have misinformation. All Subarus with the 2.5L SOHC Phase II engine use regular spark-plugs (non Platinum) that require 30K change intervals. The 2000+ Legacys all come with this engine.
Platinum plugs were used in the previous 2.5L DOHC Phase I engine because the layout of this model made it difficult to remove the plugs. The 60K change interval associated with platinum plugs helped to reduce the amount of maintenance labor.
You can use platinum plugs in your SOHC engine without any problems. In fact, many performance-oriented Impreza 2.5RS owners with the Phase II engine have found a marginal increase in engine performance by making the switch.
Ken
Some time ago I told the story of my VW GTI. Factory specified Bosch silver plugs. Paid a fortune for 4 plugs and when I changed then, the OE was plain ol' Champions. 8~O
Jim
I believe that starting in '01, with the advent of the new H-6 engines, the platinum plugs were OEM on the H-6s since they will be incredibly hard to replace (very little space between the fender well and the heads.
Now about the cabin air filters:
I have 01 Bean. When I first replaced the filters (which come stock on this model) I was very annoyed to find one of the filters' media was pulled aside where it had 'snagged' as it was being installed. I was even more annoyed when I saw that there was a huge gap behind the smaller (or lower) of the two filters. This is a horrendous design based on what these filters are supposed to accomplish. First of all, if 90% filtration is what they are trying to accomplish, then both the filter media and the filters should be sealed all the way around (no way for air to bypass). Unfortunately, due to poor design, there is lots of bypass around both the filter housing on the lower side and between the filter media and its housing. Done correctly, the filters would slide into a custom rack that has foam or rubber gasketing all around it and the filter media would be glued all the way around to the frame it sits in. As it is designed, the filtration is better than nothing, but as compared to what it should be, it is pathetic and not worth the premium they charge for these filters.
Sorry but I had to vent (again....I vented just after replacing the filters the first time!)
-r
Your question should probably go under the Maintenance and Repair topic, but check this link out:
http://www.scoobymods.com/forums/showthread.php?s=527c2ed90533a76bcc44b178d5301a6c&threadid=166
Ken
bit
This week the check engine light came on again. The car is hesitating/stalling. The dealer insists that it is a fuel problem. The dealer called Subaru tech support who said to replace the oxygen a/f sensor again. This is my third a/f sensor and the car is still not right. Who do I contact at Subaru to get this problem resolved. As stated earlier, this problem has almost caused me to be in several accidents. I am quite frustrated that the dealer has such a indifferent attitude about my safety. They almost seem like they do not want to take care of the issue because the vehicle is still under factory warranty. Please help.
Carl: check out i-Club.com and read about the SPG mod (single-point ground). It's someething even a novice can do and it tends to resolve problems like yours. Good luck.
-juice
If I understand correctly the things people have said, I need the following for the 30K checkup:
replace spark plugs, bleed and replace brake fluid, check brakes, replace fuel filters, drain and replace antifreeze, replace air filter, and replace PCV (I have no idea what this is) thing.
Are there any more procedures I need to take into account.
TIA
Don
Don: The list you mention sounds about right but check your owner's manual -- that will give you a minimum list of things to check at 30K for your particular vehicle. Most dealers will often add on top of that for extra business. You should be able to negotiate what you want.
Ken
Don: change the wiper blades while you're at it, and lube the sway bar bushings (the rubber things that hold them in place). I'll assume you already did a tire rotation and an oil/filter change.
-juice
The EGR valve was good, but the hose to actuate it was clogged, so it was gerring no vacuum to open up and do it's job. After replacing the hose, NOx levels went from 4000 to less than 400.
What was the hose clogged with? A 1/4" ball bearing intentionally put there by someone. Weird. Presumably they hoped to increase power by doing this, or maybe they just wanted more smog in the air. Or, a dishonest mechanic put it there to get some repair business? I'm just glad we figured it out and now it passes w/ flying colors.
dude: your call, then. You could go to an outside shop, but then you'd pay even if it was the motor. Maybe they'd agree to do an assessment for a pre-determined amount.
-juice
I just talked to another subaru dealer they said that they'd diagnose it for no more than $75 bucks, so I'll probably do that.
EGR when equipped wasn't even used at wide-open throttle, so I'm not sure what someone was thinking.
-Colin
I took it to Kimmel, who said he would put in platinum plugs for $60. But after he had the car, he called to say that it would be $90, because the subaru motor I had was "more complicated" than the one his estimate was based on. I sighed and said to go ahead.
But he called back an hour later saying that the spark plug wire had to be replaced ($125)because he couldn't get to the plugs without breaking the wires(the wire cap was frozen onto the plug).
This was too much and I told him to forget it. I took it to my regular mechanic (felt bad for not going to him in the first place). He had no trouble replacing the plugs, and charged me $65. He also replaced the fuel filter for $45, which seemed very reasonable.
My Kimmel experience fits with dealings I've had with other chain tire and brake shops. They tease you with cheap deals, but then manage to add on extra charges. This is not to say that "you always get what you pay for," because my experience with dealer service shops is almost uniformly terrible.
Joe
Dealer experiences: mostly bad. If you show mine exactly what needs to be done, ok. When it comes to diagnosis, forget it. Couldn't diagnose a flat tire. Why do I tolerate it? Service contract hasn't expired yet, and unless I want to pay for stuff that's covered, I must rely on them. 30k / 60k / etc. service: overpriced at dealer, in my opinion. Another dealer quoted me $58 (part only!) for the little hose going to the EGR, from the solenoid, that was blocked on the aforementioned GL. Laughed so hard I dropped the phone. They also wanted $80 to "diagnose" it. No air moving thru a hose = pretty obvious problem. Subaru makes good cars, but has some poor dealers, in my opinion.
BTW I saw on your profile you're shopping for a FIAT? In a past life I had a '71 124 Spider modified to the European version with dual IDF Weber carbs. A really fun car.
Jim
Joe: how'd you drive it with a broken spark plug wire? Firing on 3 cylinders?
-juice
I'd inferred that he didn't drive on 3 cylinders because the servicer was actually lying and there was nothing wrong with the car. They were shamelessly attempting to bilk him out of money.
-Colin
-juice
On the other hand the plugs were cheap since pulling those wires is a b...tch and you need some special tools (swiwel and long attachements) to reach it.
-mike
-juice
Sounds like your dealer was up to something. I thought it was fishy that they couldn't correctly identify your engine to begin with. Glad you had your plugs replaced for a good deal.
Ken
(um, WebX blows today BTW.)
