I live in Wisconsin and get a fair amount of snow. But I only drive less than 10 miles each way to work, on a nicely paved suburban road or free way... so I don't know if Nokian WRs would be an overkill or not.
Driving down the road, windows fully UP, there is a light to medium vibration in the door or window. Pressing on the top of the door panel (the black part of my two tone doors) stops the rattle. Lower the window not even an inch, noise is gone. Its a vibrating noise, sometimes a rattle. Had the dealer take off the door panels, add some insulation and grease, behind the spot that you press to make the noise stop. Didn't work. Its both front doors. It is not the typical wind noise from the mirror gussets.
What could this be? To me, since it only happens with windows all the way up, it makes me wonder if the windows go up too high or something? Seriously, the noise stops if you lower the window just a smidge. Almost just enough to the point where air and or water still wouldn't get in past the rubber seals on the body of the car.
Dealer is annoyed with me, I am annoyed with the car, and on my last legs here. Anyone have the same experience? Get it fixed successfully? I have tried posting on a Legacy specific site, but no one has the problem, or they do any they don't care about it. I will admit, I like my cars not to rattle when they only have 2000 miles on them. I know others expect rattles in cars with framless windows...but I really don't think I am asking too much for them to be quiet for at least awhile....:)
Thanks for any advice/feedback you could give! I can't believe I am the only one out there with this problem, but I guess its possible.
I can't recommend something specific however, since I haven't been a Subaru owner for some years now.
~Colin
I just wanted to confirm your issue - not that this will be a huge help. I have an '06 Legacy Limited Sedan - but pretty much the same car. I have no problems with my windows rattling, so this is definitely out of the ordinary (or mine is, but I doubt it). I think the dealer was pretty good about trying to help, but it seems like the weather stripping may not be installed correctly. I only say this because if you crack the windows and it goes away, the windows themselves are probably fine. It's just the way the window seats to the top of the door frame that is the issue. See if you can get the weather stripping replaced.
Serge
Granted, tires like the OEMs can "get you by," you will feel and appreciate a marked difference with something more adept at snow and ice. Tirerack.com can provide you a breadth of information.
Examples here (just a google result, I've never used this retailer):
http://www.gruppe-s.com/forester/fortrn.htm
~Colin
Karl
Oh, this is going to hurt so bad, I have an estimate of around 800.
~Colin
I've spent $300 in Subaru Bucks, and have another $600 saved up. You can use it for service, parts, accessories, etc.
Here's the kicker - even the body shop at Fitz accepted them, so I used $200 for that and pocketed the cash from the other guy's insurance co. KA-CHING! :shades:
-juice
Can someone please, please help me?
Hopefully you got it and had the stuff added.
If not, well, maybe that's what they're trying to find out now. Will your dealer provide you with a loaner?
-juice
Any ideas what the problem might be?
I'm shocked at how uncaring the person at Subaru of America is. He said he'd call the repair shop on Friday. He didn't. He didn't call until I called him again, on Tuesday. When I called him this morning, Wednesday, he said something like he didn't want to bother the people at the repair shop, because they are busy in the morning. He definitely cared more about disturbing them than about helping me.
I've completely had it with Subaru and will never own one again. I'm going back to Toyota - I should never have left them in the first place.
That hurt but it was my fault. Don't take an 1800 lb trailer down into a campground at the bottom of a hill with only one way out. I finally had to get pulled out. Stupid Stupid Stupid. Not thinking... "trailer behind me stupid you can't do normal things."
The mechanics had never seen anything quite like it. I turned the metal deep blue noticable particularly around the inner part and the springs so the temper was blown on the disk...and the springs. That was why it got "mushy" quick and the release was wierd it was happening more often with any load at all.
And I got it so hot that I warped the disk but... and this was most confusing was that most of the actual clutch material was still there. They couldn't figure that out. Normally it is toast. But what was happening was that only about the outer 1/4 inch of the clutch was "biting" (it was thin right around the edge) and since the temper was gone on the disk it would heat up quite quickly and the warp would change and the rest of the clutch would grab.
That was why I was getting this slipping and then feeling the clutch bite after it heated up almost like an auto tranny shifting.
Now remember, I know how to drive a clutch as I got 147K and 123K respectively out of my last two clutches (previous Subys/without a trailer). I may have feathered it trying to come (and keeping the truck from ripping my front end off...up) just so...that I protected the clutch material, while cooking the metal. Difficult to do I gather.
I have learned an expensive lesson and provided others with a unique experience. I would prefer to avoid the pleasure in the future...but clutches are cheaper than transmissions.
But as long as I don't do anything too stupid again, I feel confident in the OEM clutch for a trailer.
Quite true, though the Subaru automatics actually tend to be sturdier than the clutches. They can handle more power and last longer, on average.
-juice
I pumped out a litre of fluid -- it was clear and slightly pinkish on the stick, dark red in the receiving jar. The level was then OK -- i.e., between the lower two holes with a cold engine. I ran the car around the block. The level dropped a bit to the lowest hole - I put 0.1 liter of fluid back in and felt happy. I checked fluid level the next day, after 10 miles; it was fine -- i.e., between the two bottom holes when was engine cold.
After two weeks and 150 miles, lo and behold ... the fluid level is up once more -- it's above all 4 holes when the engine is cold ! What's going on ? Where does this fluid come from ? What should I do next ? Take out still more ?
Thanks for any advice -- brewce (new poster)
John
I had the same issue with my 98 OB after having the tranny flushed. No where did it say to check the level with the engine off (at least not that I could find). Once I checked it with the engine off (and cold too, I think) it was right on.
Let it cool off and then measure it and see how it is.
Karl
brewce: you have a miracle car that produces ATF. You should sell the stuff.
Just kidding, I have no idea why the level would read that high. I wonder what the proper procedure is for checking the ATF level? Warm or cold? Make sure the parking surface is level.
And yes, I actually did have a CHIPMUNK in my engine bay, he chewed up some wires on both my and my wife's Subarus. I had to replace plug wires and an ignition coil!
-juice
This latest measurement was with the engine stone cold ... but still the fluid level was above all 4 holes on the dipstick -- i.e. above the level it would be at if the engine were hot! I still have the 0.9 liter of fluid in a jar on the shelf, so if someone is sneaking in to the locked garage at night, they are bringing their own AT Fluid with them !!
Do either of you know why it is important not "to overfill" with ATF ? Can I damage something by having too high a level? Or can I just let it be till I finally figure out what the heck is going on here?
puzzled brewce
"The ATF should be maintained at the proper level as follows:
1) Drive the vehicle several miles to bring the transmission to the normal operating temperature. 60 to 80°C (140 to 176°F) is normal.
2) Park the vehicle on a level surface.
3) While idling the engine, move selector lever to all ranges. Then return to P range.
4) Remove the level gauge and wipe it clean.
5) Reinsert the level gauge completely.
6) Remove it again and note it's reading."
The above is typed verbatim from the manual. I think the reading is taken with the engine idling. (Sorry, but I'm too lazy to run down to the garage to check the Owner's Manual.)
Jim
Edit: Sam types faster than I do and he's more succinct.
Then check the stick.
I've never seen an exception to this rule - some sticks are easier than others, some do give you a "cold" mark for when the transmission's not been run long enough to get to full operating temperature. But in all cases the engine's running.
The dipstiick on my 04XT is a nightmare. After about 20 times I finally came up with a way to do it that doesn't either burn my arm, torture the adjacent lines to the dipstick hole, or smear the fluid so I can't get a good reading.
BTW - on most of the later 04EAT's including the Forester's (which is slightly different), if you do a warm drain and fill you'll use about 3.5 quarts so it really doesn't change much of the fluid at all.
Also, I think someone already said to check for a nice red/pink fluid. It shouldn't smell burned, and it definitely shouldn't be brown (as was my FXT's @ 28000 mi). That was where I got to perfect my stick reading technique since I did 4 drain and fills in 3 weeks, until the fluid was the right color again.
Last piece of tranny fluid (ATF) trivial pursuit info - its basiclly 10w oil, colored so that when it overheats or loses it lubricity it will turn brown.
HTH
Larry (Who saw an 06 OBW in blue that's making my wife forget about piston slap in her 03).
Rich F.
CK
