So I would opine that, no, it does not mean that you're set for another 100k miles.
~Colin
Well, I start back to my daily commuting grind of over 100 highway miles a day starting in January. This car was with me for the last 3 years with heavy highway driving of 36k miles a year. I will be back to about 30k miles a year come January. I hope to get at least 2 more years (160k miles) out of the car.
Dad has an '01 Outback and it's fine, too.
Of course I just jinxed myself.
-juice
Also stick is less-fit for towing than an AT.
-mike
I don't think so. You will need a new hitch but I'd go for an after market Class II hitch. The Subaru hitch is rated at 2,000 lbs while the vehicle is rated at 2400 lbs.
You have to add a cooler if you are going to tow any weight at all (with an AT) up any incline at all. I had 13K out of 43K miles all over the U.S. It was great.
AT is fine too. And before 03 Subaru rated the AT's less than MT's. And unless they have improved that 4EAT it spends most of the time hunting and searching for a gear while towing..
I don't know much about performance, but I do know towing with a Forester.
To be honest I wouldn't be towing much with any Subaru, remember you want to tow about 25% less than whatever the manufacturer recommends as the max towing to comfortably tow on any vehicle.
-mike
In Australia they list the tow rating above 3,000 lbs. YOu can get Class II and even a weight distributing hitch. Same for the U.K. where Subaru won best tow vehicle for like two years in a row. That 25% thing is because American tow ratings do NOT take into account what is in the tow vehicle. So you have to subtract things like the driver and passengers and dog and kids and cooler from the tow rating...
The Subaru has a "pure" rating as in as long as you do not exceed the GVWR you can tow 2400 lbs.
The concensus is that SOA downgrades the towing capability in North America because we are a sue happy culture.
Whatever you say. I've been towing for years and unless you are towing a tiny trailer, a Subaru just isn't gonna do it.
-mike
So the SoA numbers are already very conservative.
Having said that, I wouldn't want to tow anything heavier than the tow vehicle itself, you don't want the tail wagging the dog. Leave plenty of space ahead of you to stop.
And BTW I agree that it's a bit easier to tow with an automatic, because you get torque multiplication since it allows a bit of slip. On a manual the clutch absorbs all that punishment.
-juice
This does not happen when the engine is warm.
The dealer claims that there is nothing wrong, but I think there is.
Thoughts?
assuming that you are not mistaken or exaggerating a bit and 3,000 is correct, I'd ask the dealer to ensure that the following are working properly:
idle air control motor (IAC)
manifold temperature sensor
coolant temperature sensor
Suby's are good tow beasts though...and I have torched one clutch... But it was my fault, not the clutch... And clutches are cheap compared to AT's. One learns from ones mistake if one is lucky. And we are not amused. I love speaking from the third person... IT seems so ethereal and apart from reality... kind of like a recipe for disaster... but I digress.
Then again I haven't towed anything less than 5k lbs recently, everything I've towed in the past 3 years has been 5,000lb boat trailer, 6,000lb car trailer, and a 9,000lb boat trailer with triple axle
-mike
I have noticed slightly more power in the car. Also, this may sound strange, but I can feel the power in the gas pedal- when I am accelerating quickly, the gas pedal shakes slightly now. I thought it was odd, but everything else is running great.
-juice
About the only thing I would recommend is to definitely use the crush washer, and that may be harder to find in stores.
Len
I have the same problem, 2006 Forester X, 7K miles, just bought used, has a normally barely detectable shudder, slightly more noticeable in Neutral or Park, but in Drive you don't notice it. Once drive a while, it randomly "shudders" at idle, to the point that it's nauseating and you can sometimes see the body shake. The frustrating thing is it comes and goes, but in order for it to act up, the engine must be hot. Idle speed never strays far from 750rpm whether this is happening or not.
Dealer says it's normal for this engine, but they only saw the normal behavior, not the bad episode. This varying behaviour makes me wonder whether it isn't something besides the natural vibration you refer to.
Any thoughts?
Second is that the filter material density and check valves in the OEM are set to the manufacturers standards. If you can get documentation or other evidence that the less expensive ones are of the same or higher quality then I say go for it. I either stick with OEM ones or some of the more expensive filters like K&N, Hastings, Amsoil etc.
-mike
'96 Subaru Wagon
DRLs.... on a '96? Are those aftermarket? The switch about which I am talking does not turn on your headlights.
I can't tell you why it isn't 100% smooth, but they all have that unpredictable random hitch at idle.
John
Ken
Happy New Year to All!
PS - Drove a Malibu Max while on vacation last week - lousy traction, wheels regularly spinning, and even prompting my Dad to mention, "This car rides rough!" Too bad I couldn't have my Forester with me.
As a side issue, this was announced by a steady "Check Engine Light" (CEL), and the simultaneous failure of my Cruise control, along with a blinking Cruise Control light. (Thought for the day: If the CEL is going to signal the problem, then, why does the CC light have to join in???)
At any rate, the local mech explained the details I have related, and pointed to no less than six CATs (plus tailpipe sections), stacked along the garage wall. Okay, so I'm on th e waiting list...
Is this the start of a recall? or something local to the Monterey, CA area? I have used nothing but unleaded regular.
In the meantime, I am minus Cruise Control. A small bother, except that the damned light is still blinking! :mad:
Gaucho
-mike
First, your Dad is right -- it may darn well be an electrical problem, such as the fuel tank level's sending unit. It could also be a shorted wire or a loose connection. You'll need to pull out all the carpeting and liners (and maybe the back seats) to visually check the wiring.
It could be the fuel tank float itself, but I doubt it -- the problem is intermittent, which indicates a short or a loose wire.
Finally, as an old helicopter pilot: a fuel gauge is *never* to be trusted. Best bet is to time a full tank, and keep track of the running time between fuel-ups. Second best, and better for ground vehicles, is to mark the mileage between fill-ups, and do not exceed the mileage for a full tank!
I hope this helps. As long as you keep track of the mileage, you shouldn't wind up walking.
Gaucho
True enough. However, the Aviation world had a better idea worked out decades ago.
It consisted of a "master Caution Light" on the dash, where the pilot couldn't miss it, and a push-button switch to turn it off. Down on the console was a battery of smaller lights, each wired to a particular fault system. The light for that fault in question would come on bright along with the master Caution Light, but could be tipped to a dim position, so as not to distract the pilot any further (never mind the fault in question, which would be usually distracting enough...) If a second or third fault condition occurred, then the Master Caution Light stood ready to do it's thing.
That was back in the mid-60's, when everything had to be hard-wired. Today? A matter of programming, mostly, and perhaps the addition of a touch screen. (there is still going to be a wiring bundle involved, but that's what designers get paid for.)
To get them on the right track, any old UH-1 "Huey" cockpit, or perhaps a look at a Blackhawk or Apache cockpit can show them the way.
The Aviation world saw the integration of systems a long time ago, and came up with solutions. As cars attract more systems, it's time for the designers to go look at existing solutions outside the office.
Gaucho
-mike
Any help/advice would be greatly appreciated.
While driving home, I noticed that the lights on the dash had gone off. I immediately checked the Cruise Control, and it now works. :confuse:
Okay, all my prior experience with things mechanical and electrical say that they do not get religion and heal themselves.
The shop has no idea, beyond the notion that the two Oxygen sensors (before the intake manifold, and after the CAT converter) may have been mismatching themselves, for some reason. (That's also the way they determine a "bad" converter.)
All of this points to some weak programming, IMHO...
Does anyone know if there are any hackers working on car computers? Subaru Forester computers, in particular? Any points of contact?
The shop is also recommending I go ahead and replace the CAT converter, since it is already on order. (I'm of two minds, there.) I do have a 3k mile trip coming up, but I hate to bother with a new converter if the existing one is good. OTOH, I'd miss the Cruise Control for that kind of distance.
Gaucho
Sounds like a loopy sensor, but I wouldn't know which one, offhand.
When it happens, have you tried goosing the throttle pedal? Sometimes, the change in fuel-air hitting the manifold will cause the system to re-evaluate the fuel-air mixture, and adjust itself.
Gaucho
I am guessing it is electrical. I bought the car in March of 2006. Recently I noticed two things:
- Every once in while the CD play will just turn on;
- When I first purchased the car, the car would beep when I activated (locked) and deactivated (unlocked) the alarm. About 1 month ago, the beeping stopped. The remote entry and alarm still works, but no beep indicator.
bh
-juice
I appreciate all the info on the things to look for, though.
-mike
Their showroom had 3 STi WRXs and one Forester. No Legacy or Tribeca to be seen inside or out!
BTW, two weeks ago my daughter drove a WRX in bumper-to-bumper LA trafffic. Afterwards, she complained about extreme soreness in her left leg. I don't think it made a positive impression...
Jim
Oxygen sensors can fall into the latter set. The front sensor deals with fuel/air ratios and the raw exhaust. The rear sensor assesses how efficient the cat is at futher reducing it. If feedback from the front sensor strays for a fraction of a second it can throw a code, but the light will clear itself if it does not happen again. But the system captures the code and a 'snapshot' of conditions posted by a dozen other sensors for a total of 40 cycles so that it can be read out by your mechanic.
Interpretation of what the codes mean, and what to change, is very much in the hands of the mechanic. It could be that the sensor itself is bad, a wiring problem, or something else that the CPU is misinterpreting. Remember that there are no dedicated sensors 'watching' the performance of sensors. The total system is monitored, and when certain conditions are met, a logic table dictates what code to show. It is not always right or absolute, which is why sometimes they end up having to change multiple things until it does not re-occur.
Steve
