1970's & '80s Volvos
The 940, which was essentially an updated 740, came later, and wouldn't yet qualify for discussion in this Classics board.
I kind of like the boxy look (although not to the exclusion of other styles), which is what attracts me to these old Volvos, late '70s-'84 Mercedes sedans, and the '82-'90 GM A and H bodies. My favorite Volvos, styling wise, are the 240 and 940.
I think the Mercedes is a ten times better built car in that era...there is simply no comparison. But the Volvo might be easier to work on and cheaper to fix.
I think one reason the 240s lasted so long was that they were very understressed---but once that turbo got in there, that changed the dynamic and I don't think the car was up to it.
I know it's been a long time since a post on this thread, so I thought I'd post this.
I still miss that car...
My younger brother had a '69 144S, but with the B18 (1.8L) engine, and the B/W automatic - it was a real slug, but safe and reliable.
I really like 140s, but I hated those biodegradable knobs and the exhaust systems always falling off.
Did you get metal timing gears in there? I"m SURE you have an IPD camshaft--the B20 needs camshaft help.
These ARE easy cars to work on. I can't think of anything that's really hard to tackle on them. Well I guess banging out those teensy-weensy U-Joints were a hassle. Could they have made them any smaller?
The clutch is a heavy duty Sachs clutch and pressure plate with a lightened IPD flywheel. The engine was kept reasonably close to stock, as the 122S used the D cam, but I got rid of the troublesome Strombergs, and the combined intake/exhaust of the original design. I had tried Weber DCOE's back in the '70s, but went back to the SU's. When properly set up, a good set of SU's are fine.
The primary improvements are in the suspension area. The suspension uses shorter, and higher spring rates, IPD coil springs, larger front sway bar, a rear sway bar, and Bilstein competition dampers. Also, a custom IPD air dam is on the front, and driving lights on the front bumper. The wheels are 15" ATS from the '70s, and the tires 185/70VR15.
Yes, the knobs do tend to come off in your hand, especially the fan knob. Soft knobs for crash safety - right!!
I guess I'm a Swedish Iron masochist at heart! However, I do have two much newer Asian cars to revert to when needed (when I'm not under the Swede's re-working something). As usual for the average car nut, too many cars, and not enough garage space!
