4x4 vs. 4x2
I'm looking at purchasing a pickup. I live in
Minnesota so snow is a major concern for 6 months
out of the year. 4x2 pickups are so much less than
4x4 that it is really tempting, but the thought of
using a rear-wheel drive car in the snow gives me
the willies. Is there any way to make a 4x2 safer
in the snow? How about putting weight over the
rear tires? How much weight?
You may not have as difficult of a time with a smaller truck. Mine was a 3/4 ton that weighed about 5000 pounds. It's just a lot of weight for the empty rear to push. The 4wd permits it to pull and push the load. By the way, a front wheel drive makes all the difference. People with front wheel drive vehicles in Alaska get great traction by putting studded tires on the front, or at least good snow tires. The pull vs push makes all the difference. Do any of the smaller pickups come with front wheel drive in their 2wd models?
1 - Get a "posi" rear end
2 - Have large narrow tires on your truck
3 - Use weigth in the back (not to load it
down but to balance the weight) over the
the rear axles.
4 - If you can, get a stick
I drive a tow truck in the North East and see a lot of 4wd in the ditch. A truck in 4wd driven over lets say 45 mph on a slippery surface will slide easier and you will not have a chance to correct it. I do drive 4wd vehicles but the 4wd is there when you absolutely need it and it's purpose is to get you going and not to "flop" it in there and go fast.
I will disagree with you on the front-wheel drive car comment in one aspect. Front-wheelers are awful climbing hills in snow. My dad used to have a 1984 Pontiac 6000 wagon. Good car, but forget uphill when it got slick, because you just weren't going there. The CG on a front-wheeler uphill defeats the "weight-over=drive wheels" advantage they enjoy in other situations, simply from the gravitational shift rearward.
There\'s actually been talk about making pickups front-to-4 drive instead of rear-to-4 - God, I hope not...
Now I have a 4x2 F-150 but I live in Delaware now that has inconsistant winters. I agree with Brutus that a larger truck would be easier to move with 4x4 traction as opposed to a compact truck. To be honest, if I lived in Minnesota and had the extra money, I would get the 4x4. I really don't miss the days of creative driving 101 in that S-10! Lots of North Carolina mountain nightmares come back to me whenever I see a snowflake.
a manual trans gives you control to use the rear wheels for braking without losing control on fronts (Braking system force is higher in front than back).
I was not willing to spent the $4k on 4x4 when it does not give me any advantage. When most other drivers are going slow in front of me, it is of no use. Spend the money on anti-lock brakes, this helps you from losing control when slowing down. The 4x2 drives much better (less unsprung suspension weight) and gets better mileage, and is much cheaper.
But, that's just my $.02 :-)
I chose my words poorly. I didn't mean stuck, unmovable, I mean stuck, driving at the 20 mph like everyone else. Nothing would tick me off more than going 20 mph on a road that has been plowed when my vehicle has good grip. I always got back to the question why did I pay for this when I use it two or three times a year. The better choice for me is good tires that will give me good traction when I need it. Snow tire are really a good investment since most are cheaper than the road tires these days, and you are going to wear tires anyway.
I agree with all the situations you folks have presented. If these types of situations occur to you often enough to pay the extra cash and accept the other downsides to the 4x4s, then you do need one.
Here in NY, plowing is ussually pretty good, maybe once a year the roads will have 6 inches of snow before the plows hit them again. Usually plowing and salting is kept up. I consider the conditions when choosing my route to work. The quickest way also is the worst in snow, and I don't bother with it when bad conditions exist. I will stay on the main route that is plowed well. When I still had the 4x4, I started to test this. I found that at no time I needed the four wheel drive. I just left it in two and was able to get there.
I'm not sure that I'll ever go have that kind of fun in the dirt with a crew cab dually though...
becomes the "old truck" "
How TRUE!!! I'd love to buy a new truck, but there's no way I could spend close to 30K and beat the living crap out it like I do with my '85 F150 :-) What a blast!!!
If I understand this correctly, an locking rear differential applies equal power to both drive wheels. A "limited slip differential" allows one wheel to "slip" when stuck and transfers all power to one wheel. Which wheel gets the power and why, I am not sure of, but I am sure someone will chime in on that and whether it would help.
Thus, you may be able to get a better deal by looking in a place that doesn't sell many 4 wheel drives. Then have it drop shipped to you.
P.S. I'll sell you a 1992 Ford explorer that is 4x4. I think I have used the 4x4 two times since I bought the truck 6 years ago. My next vehicle will be 4x2 as long as I stay in Atlanta!
Four wheeler mag took a postal jeep and rebuilt it. It came stock with a locking rear diff and only was a 2x4 and the staff was amazed at what it could climb. Now descending was a nightmare.
As a sidelight, it is well known that 4x4 configurations allow descent in a controlled fashion over using your brakes. In that respect if I see that I'm going to have to stop I can slow faster and in better controll in limited traction situations by using the engine drag through the 4x4 than by goosing the brakes.
Kcram, I agree somewhat about the fwd loosing a lot of their advantage in snow going uphill. In 1983 Atlanta had the mother of ice storms. That storm moved in here from the gulf and was seriously wet.(which froze to the roads as ice) My Honda civic wagon was not a happy camper until I took all the crap out of the back and put it in the front floor and seat. It did OK then! We don't have the advantage of salt/sand trucks and snow plows that other more snow prone states do, and our snow is of the wet variety that lays down a sheet of ice on the road. It makes for some real white knuckle driving experiences. My friend from Long Island New York really curses our "SNOWS". He used to be of the opinion that we just didn't know how to drive. But, now he says, "How in the H... can you get used to this stuff when your truck won't move"? kip
There was a two inch snowfall in Atlanta soon after some of my relatives moved down there from NJ on the early 80s (before the 83 storm - I remember them telling us about that one). My uncle, being used to this, drove happily around without any trouble, but was just amazed at the natives' lack of ability in the white stuff. Granted, as you say, Atlanta is not equipped for snow removal, but up here, we wait for two inches to melt on its own. I don't see a plow on my street for anything less than 5 inches.
Every year, two types of people go out driving and get in nice big wrecks: young kids in sports cars and visiting Northeners who don't listen to the natives.
I agree that folk up North drive well enough on snow that will leave folk down South housebound. I also don't care how good a driver someone is, or what kind of car they have, when the city is paved in ice (often having half-thawed and refrozen overnight).
I agree, a real ice storm will shut anything down. Recall the one that hit the northeast US/southeast Canada this past winter, and basically caused federal-level states of emergency. We get an occasional "glaze" here in NJ; the accidents are almost never on the heavily iced roads. Instead, they are almost always on black ice - that REALLY thin stuff that looks like puddles of water. Last winter, a car and a flatbed semi tangled around the corner from my office when someone braked too hard and lost traction. The GW Bridge between NJ and NYC gets closed quite often after a storm because the icicles (some an impressive 50 feet long) come crashing down to the roadway as they melt.
The thicker ice (usually partially-thawed snow which does a quick freeze with a temp drop) isn't that tough to drive on if you keep the tires rolling.
The right tool for the job is a 4x4 with studded snow tires all the way around.
After a snowfall, the roads are bladed. Often then the weather clears and temp. falls.The roads glaze over and are literally sheet ice where there is not adequate sanding.
Rubber on ice doens't cut it. Good studs make a big difference, especially on short wheelbase vehicles. I had a Dodge Raider (jeep like) and my wife swaped ends of it a couple of times before the studded tires. I also pulled out several people from snow banks who didn't have them.
Of cource you have to have a set of regular tires for summer use as studs then are banned.
A good "snow tire" is essential too. The best "snow tire" is only a moderate tread pattern, not a course tread that might be good for mud off road.
You actually want the tire to "load up" with snow
(vs. a mud tire that needs to clear itself) because snow sticks to snow better than to rubber.
Front wheel drive vehicle w/ cable chains work pretty good to. Either way YOU MUST keep your speeds down.
In the first year I was in Tahoe, I saw more accidents then I have seen in my entire life. Speed on snowy roads was the lead cause.
For those more comfortable with studs, I say more power to you. But people shouldn't drive as though it's summer (with a false sense of security) because there are studs on the vehicle. And please have them off before the streets get totally bare come spring - break-up. They really chew up the pavement. We all pay for stud rutted roads at the fuel pump.
Studs are not for all people. They are hard on the roads, but they defineatly add a margin of safety on icey roads.
I might add that most of the accidents I saw were caused by tourists that just couldnt seem to figure out that you cant drive like you are still on dry (or even rainwet) pavement.
Thank you for making my point!
Maybe it's just that us Yoopers and Canadians know how to drive in the snow.
'Course when you're up to your waist in it for 6 months out of the year you tend to learn quickly..............
order a dodge quad or a silverado. I like the
Dodge styling/looks. I need some guidance. The
Dodge would have the 318 or 360 and the Chevy
would have the 5.3. Pro's & Con's. Thanks
out for a 2WD rear-wheel drive truck with weight
in the bed of the truck, stay home! A little
common sense and 2WD is all you need in almost
all instances. I live in Wisconsin, and the most
I use my 4WD is about 5 times a year while
driving to and from work about 400 miles a week.
In Wisconsin, at least, everybody thinks that
they must have 4WD. That is the only reason I
buy a truck with 4WD - RESALE to buyers who
probably will never need 4WD in the first place.
Simple as that!
If you have problems getting stuck you just answered your own question. Factor in the increased resale value, comfort factor and option to go off road and IMHO it's worth it if you can afford the increased cost.
Here in Pittsburgh, we seem to be on our second record breaking warm winter in a row. I bought the 4x4 mainly because of all the hills around here but the way things are going I may never take it out of 2wd this year at least for snow. But if I get to spend more quality time outdoors...well I can live with that.
Hey, another Pittsburgher!!! Although it does look like the 4x4 needs may not be often this year, remember the winters we had about 4 years ago!!! I was the happiest man alive that I had a 4x4 during those winters...
kamberis:
I agree with mikec13 in that you seemed to answer your own question. If you've found yourself already getting stuck in the past, the 4x4 will definitely make you happier on those bad winter days. The one thing I'm not sure on though is the added resale value. Has anyone actually looked to see if the resale value on a 4x4 is greater than the same 4x2 to the same degree that the extra cost initially incurred? Just something I've always wondered about...
btw... I have an old Tercel 4x4 wagon. When we had that record snowfall, I couldn't drive my Ford across the street (despite weight in the rear and limited slip), but had no issues taking my Tercel on a 25 mile trip. If money isn't an issue, and you know that the 4x4 isn't magic, get one.
Regarding "I will be buying a compact p/u (dakota or ranger) in a couple of months.........I have a 2wd '87 Nissan p/u".
I had the same year and style Nissan you have, and although I thought it was a good truck, I too switched this year, to Ford. So it's obvious that several months ago, I went through the same pickup selection thinking process you must have had recently, and it seems we both came out the same door. Since the new Nissan 4x4s appear to be very competitively priced, could you perhaps indicate why you're not inclined to buy another?
don't buy it. However, I don't hardly use it, but I admit it does come in handy when we receive a foot of snow (once or twice a year) and I can blow by everyone else stuck spinning their tires. If I was a farmer, I would definitely buy it because you are in mud, etc. quite a bit in the fields.
As far as re-sale value, if you can afford 4x4, you will almost always get the extra $2,000-3,000 more it cost to purchase 4x4. However, by owning
4x4, gas mileage will suffer by about 3-5 m.p.g. and the lack of power the engine has even if you do not operate the 4x4 also suffers somewhat. I should know, I owned and do still own a 4x4 and non-4x4 Chevy truck. The 2WD zips while the 4x4 model operating in 2WD is slightly behind.
