Chris
Mark
2004 Quest SE
Does anyone know where the fuse that controls the alarm/remote is?
My alarm keychains don't work anymore, both stopped working at the same time so I figure it is not the battery; anyway, all manual controls work, rear hatch, power door, windows, etc (anything you would normally do with the remote); but... the remotes just don't work; I looked in the manual and the fuse box cover (inside and under the hood) but it does not give a hint as to which fuse controls the remote function.
If anyone has had this problem before please let me know, I don't want to give the dealer the pleasure of ripping me off again.
Chris
I've been following your Tranny saga with interest!
I have an 07 Quest 3.5s with 5 speed.
I'm interested in your Quests "down shifting". I may have a similar issue, however, dealer thinks I'm nuts!
Thanks a lot...
If the entire key fob does not work, you may need to reprogram them, if you are positive the batteries aren't dead. Here's a link that shows how to reprogram Nissan fobs. make sure you scroll to the bottom of the page.
http://www.nissanhelp.com/Ownership/Common/reprogram_key_fob.htm
just to keep you up to date, took the 06 Quest SL in today for thrid oil change at 11K miles. At last oil change we had expressed concern over a slight vibration at 2K rpm under load (uphill...), the tech had told us he could not feel anything. Today, I got to ride with the service writer, he felt the viab immediately, but upon inspection they were unable to find anything loose or amis. the tech is saying 2K rpm is the "harmonic range " of this engine...I dont buy it. Service writer is saying he will try to drive another 06 quest when one comes in and see if he feels it on another car. Has anyone had a similar viabration?
Otherwise, only other issue was the rain gutter trim on the pass side has popped up, they are ordering another piece. We just got back from a 1200 mile trip and are sure glad we have the extra space...how would we have lived with the smaller Hundai? Avg mileg was 25.1 on comp, 24.4 real.
Again, has anyone tried one of those clear plastic type bra shield?
Tom
Eduardo
I understand some of these posters have legit issues, but some folks must never have driven a 1979 Dodge Omni.
I bought mine 04 Quest a month earlier than you and have 35K miles on it. Today, I took it to Dobbs for brake pads (front) check, they said pads could still last for 3-4 month. Changed 2 tires at 28K miles and 2 tires + rear pads at 31K, our quest has been great and I enjoy driving it everyday. No problem at all so far. The QN engine is really good and powerful. The car is easy to handle and cornering with both independent suspension on both front and rear (only Honday had the same suspension when I purchased it), and more safety features compared with other vans at that time (side curtain, etc).
Our 2004 Quest has 36000 trouble free miles. Just finished a round trip from St. Louis to New Orleans. Gas mileage was 22.8 MPG with air conditioning on all the time and speed mostly at 80-85 MPH. We really appreciate the handle and stable of the van, especially in the heavy rain road. It handles like a Champ and boost the driver's confidence during the merge and pass other cars/trucks.
BTW, the front brake pads are still the original factory installed. Had it checked in Dobbs and they recommended changing it after the summer.
The 2004 Quest has been a really great car for us so far.
getting better
I've been thinking about changing the air filter myself. Glad to find your recent post. Do you know how often it is recommended to change the air filter on Quest? Where can I find some instructions on how to do it? Which brand did you put in? On autozone website, they listed 3, 2 generic ($6-9), and one K&N filter ($45). There was some discussion about air filter on this forum a while ago, but I can't remember if it's worthwhile to spend $45 on the K&N filter. Thanks.
Phuc
It was actually fairly easy to pull the filter out. The cover has two clips on the right side and two pins that snaps into two slots on the left. You unbuckle the two clips on the right side, then push the cover down while sliding it to the right to pull it out of the two slots on the left. Then you just replace the filter. The hard part for me was close the cover back up. I don't know if it was me not being handy enough, but the rubber seams on the Fram filter were too big. I ended up tearing them off to close the cover. I think next time I'll try a different brand to get a better fit.
BTW, the directions for replacing the air filter is in the owner's manual.
Now I worry the filter is too leaky without the seams.
Fuel economy also improved since the oil change, although still lower than what we got in the pacific northwest. I thought the southern california climate would give better fuel economy due to the lower humidity. But I guess that's not the case.
I think from now on I'll try to change the air filter every year, which is about 10K miles.
So, they checked the oil a few times, changed it, checked the oil pressure, ran a computer diagnostic, and all OK.
Time to call the engineers in TN. So, they were on the phone with those guys for almost an hour. They have never heard/seen this, and the engineers hadn't either. They authorized the dealer to drop the engine and check the timing chain and tensioners.
So, no van for the beach trip!
After working on the engine, sure enough, it was the timing chain hydraulic tensioner that had gone bad. So, be aware of that, as you couldn't tell unless reving the engine....
Mark
2004 Quest SE
42,000 miles
Chris
Have had our 06 SE in twice for exactly the same thing...the service mgr keeps trying to tell me it is the car's "natural harmonic" please keep me appraised of what yours says...we are bringing ours in Wed again for the same issue and could use some backup
Tom
tjshan68@aol.com
I have 2004 Quest mid level package (SL?) and had to repace the tensioner pully on the serpentine belt. It may be unrelated, but now at idle I get a clocking sound, almost like valve lifters (from my old 4 banger Chriysler days). Is this similar to what you heard? My mechanic put a stethascope on all the parts related to the serpentine belt and could not track it down. The top side of the engine is the next logical place...
Mark
low down
2004 Quest SE with 80,000 km
serviced by dealer until July 2006, when I went out of the country for almost 3m
Just started job - was pricing out tires and brakes before winter. And a trip back to the dealer for the next PM.
Noise starts - and disappeared while running warm engine (sometimes) or became quieter.
Took to garage (not dealer) they checked it over quickly and believed it was something 'inside' - schedule an appoitnment
Van dies, have towed - told ENGINE GONE
OK, so say - now what?
They check the ECM - needs to be replaced - says failed (this is my second one since purchase). Takes 10 days - put in & try car and it starts, and then stops. The ECM they removed was not 'programmed' properly - apparently the 'maintenance modules and warnings were shut off'. Implied "I" did it - hell - I still don't understand all of the stuff to run my radio!
I was told that the ECM should have identifed the problem to me - ie - low oil level. Then, I was advised by a service manager that a 'dipstick can be dry' and not set of the sensor. Sounds fishy actually. I would think if there wasn't enough OIL - the oil light should have come on. I would think that the engine would heat up, it would tell me. I would think that there would be something that would signal me to check it - especially when the wierd knocking sound came AFTER all of this!
Dealer tells me that I didn't do a recent oil change. That was the reason the engine is broken. OK, maybe that is the case. But my van was running awesome and it was part of the upcoming PM work for end of Sept.
So here is where things are:
I have warranty still, but they want me to pay about $1000 for the dignostics to see if there are ANY component failures - which could mean some/all of the engine is under warranty.
OR
Put in a new engine - @ $9500 plus $2600 for installation, plus parts (if needed) plus taxes @ 15%
OR
Put in an engine from a 21,000km car crash victim, at a cost of $3-5000 plus tax and parts, but would NOT be eligible for a warranty AND my Nissian warranty would then be NUL & VOID for the remainder of my car.
OR
Trade it in, for a fair deal against a NEW ONLY vehicle from the dealer.
I figure my vehicle would have still be worth somewhere around the $20,000 mark - cause I had upgrades and add ons and my intent was to drive it into the ground - timing of which would be the leaving of my kidlets from home. Giving me the chance to then buy an adult car again - whoooo.
So, I'm trying to find others who have had engine failures! I have heard, and the dealer has said in passing remarks that there have been 'other vehicles with noises which have experienced engine problems'. I want to find out if there is potentially a problem that happens to this vehicle (and those which are in infinity models) @ the 80,000mile mark. My vehicle was at 80,000km. So relatively speaking - it was a bit early.
Don't get me wrong - I love my Quest - I bought it for specific reasons! I can't say I was not disappointed on the milage irregularities, but overall, I want to keep my Quest.
I want to find out if this 'noise' and 'engine failure' is something is a problem that others have experienced.
Based on what you are saying, the dealership is doing the classic, blame the customer, first. Keep fighting! And find any of your oil change recceipts. Also talk to you other mechanic about what the dealer said. I'm not a mechanic but what they are saying does not sound right.
Edit: Do a google search on Nissan 3.5L engine and oil loss and see what you find. In a small percentage of engines, they have had excessive oil loss due to malfunctioning piston rings. Again do a google search and see if you find what I found. And check out this site with TSBs on the Quest: http://www.nissanhelp.com/Ownership/Quest/EngineM.htm
Get all your ducks in a row, and keep fighting the dealership. You may want to push this to the next level and get the district/regional manager involved.
Mark
If it was out of oil, regardless of any other problem, that is your fault and is not covered by warranty. I've also heard stories of dealers voiding your warranty if you have too much oil in the engine.
Mark
2004 Quest SE
