The ceramic pads on my front tires cost ~$30-40 more than the semimetallic, not a huge jump in price. If you're that concerned with braking, you might want to install ceramic pads all around. I'm not sure about their stopping power, but they ARE silent. I'm not an expert on the various brands of brake pads. Someone else can chime in on that one.
Regarding brake pads--I am not too worried about stopping distance--as all are pretty OK and I drive cautiously :P --It`s whether they reduce the steering wheel shake/shimmy?
Did ceramics on your Quest reduce the shake?
Also do frozen rotors help with the shake?
never experience the Yoko Avid TRZ. Read of some issues but overall a very good tire. go over to Tire Rack and read the reviews and surveys.
Now I have a new issue with a low pitch ticking noise and feeling coming through steering wheel at constant rate whenever I turn corners.
Does anyone have guess to what may be causing this? There is also random high pitch squeal from steering wheel but the source of this problem has been found (or so I heard.) The mechanic insists he has done nothing wrong and these must be pre-existing conditions...
I'd appreciate any inputs.
Of course this wasn't always the case. This is our 3rd new Quest. Our new 04 was so troubled that our dealer, who's amazing BTW, told us "pick another off the lot" and we drove off in a brand new 04. As hard as this may be to believe, about 19k miles down the road, the new one also became such a rattle-box (along with one nissan tech who decided to damage the 2 front doors on the lift) again we were told to "pick another off the lot"...this time going for the loaded up 05 SL. Third one was the charp I guess because it's been perfect in all ways.
Oh and as for the tires, we're now on our 2nd set of Yokohama Avid TRZs and love them! They turn this van into what it should have been from the start. No more front end wandering in the rain and what a smooth ride. But there is one BUT. They only lasted us about 30k miles and they're an 80k mile tire. No problem though because we got them at Mavis Tire and Yokohamas warranty is prorated so they replaced the tires and the percentage from 30k to 80k was applied and the tires were less than half price!
So don't fret a little rattle from that damn door. The van is mechanically sound with an engine that is just fantastic. Enjoy.
Also did u have any rotor warping/brake pad/steering wheel vibration issues?
A lot of folks on this forum suggested Frozen rotors for the 04 Quest.Do u have any info on them?
What other problems did u have on your 04 model?
I had the auto tranny flush/coolant flush/cabin microfilter recently and always use full synthetic oil.I am also planning to buy the Yoko Avid tires now..
Do u suggest any other care that I need to take?
Thanks..
Our SL has the 5 spd tranny and we had Nissan change the fluid not too long ago. I can't rememebr now if we had the coolant flushed. I'll have to look into that. I changed the cabin filters myself and geez...what a PITA! The Bose amp on the firewall behind the glovebox has to be removed! Yeah, those AVID TRZs are amazing the way they change the charactoristics of the van...especially in the rain. The tires are cheap too!
Not too much else to do really. I use only Mobil1 synthetic every 5 to 7k miles. That's it. It's been trouble free with only regular maintainance.
No shake after the installation and even now (~ 12,000 miles)
Front about 90% life; Rear about 80% life
The only downsize of HPS is that it takes some extra distance to stop when it is cold!
Goodyear is wearing down and have around 50% of the tread life 22k miles on the tire; Winterforce still have 90% tread after 2 seasons (8k miles). i also agree these new Quest eats the tires... I have a older model (first gen) and it shows very little wear on OEM after 6 years (still has 70% before i replaced it).
btw... this is a 2005 Quest base model!
heh...hated those OEM's...I would get the 'stink eye' from my wife when that would happen...sort of "slow down...there are kids in the vehicle".
The van handles like new now. Regarding the tires, I'm also on 2nd set of Yoko Avid tires, purchased from tirerack.com both times, and as many have noted they are great in rain and also pricewise. If I hadn't run over a piece of brick on the freeway at 65 mph which ripped my rear tire, the 1st set of Avids would have lasted about 40k.
I am also impressed with the Michelin Primacy. I hope they last longer than the hankook Optimo H418. The Hankook performed OK but only lasted 25k miles. sometimes it is not worth buying based on price.
The good thing is Quest owners have more options for tires other than the Goodyear OEM.
I tried crutchfield but wasn't able to find much information. It looks like many aftermarket systems can be installed - but it also warns me that we need to fabricate a harness for correct fit.
Any responses/advice is greatly appreciated.
I've asked this before, but no one responded. Has anyone ever done their own adjustment on their 2004-present Quest power door. When ours was in warranty, the dealer adjusted it at no charge "as a courtesy", but it never lasted more than a couple months. The door gets about 90% closed & reverses. Nothing is obvioulsy gumming up the track, etc. If someone pushes it will close, but it is annoying at best . Any ideas?
Calvin1962
Today I opened the moonroof on my Quest 05 SE to let the hot air get out while turning on the A/C. After a few minutes of driving I tried to close it but it didn't. I could hear a little noise "click, click" but the moonroof wouldn't slide back to close. I'm hoping to find some advice here. Anyone having experienced this problem before? Any input is greatly appreciated.
Phuc
My van takes bumps and road imperfections smoother and without any noise. the sterering wheel shakes are about 95% gone.
Hopefully this helps someone.
Best thing you can do is make sure the contacts are cleaned, nothing is on the track and there is plenty of grease.
.I thought it needs engine oil change.SO did oil change.But after that I still see Service Engine soon.So I took it to Autozone and they told I have I P0420 error .After reading this forum I understood it needs a new catalytic converter.Emission warranty is like 8 years/80K miles.Will I be still covered undered warranty?
THanks
sarathb at zenbedotcom
I had a replacement Audi part go out in about 15 months; and about 1000miles over , and they refused to cover it...I think the replacement part only had 1 year 10-12k miles or so..
Anyway, I'd look for an after market part...or a junk yard piece...or re-manufacturered.
Also,any reason why you bought such a high miled Quest ? And what did you pay for it? Good Luck.Keep us posted for any follow up.
http://www.nissanhelp.com/diy/obd_codes/p0420.htm
I would have a mechanic looks this over before replacing the catalytic converter. Actually if there are no other drivability issues, i would erase the code and see if it came back on. Then have a mechanic look it over.
I don't have drivability issues.This issue started recently.How can we erase the code?
I did find Nissan parts through http://everythingnissan.com/ (actually an Infiniti air intake) which was 50% less than the dealer...not sure how the exhaust compares to OEM in price and quality.
Usually Nissan,quest/honda runs like 200000 miles right.So I thought I will drive those many miles.I dont drive much.Like 1000 miles in a month or less than that.I bought for $8000
Or you can ask your mechanic to erase the code for you. Reading the link in my previous post, I wouldn't be so quick to change the catalytic converter because of this code. There are other possible causes and the converter is pretty expensive. If the code comes back or have drivability issues, then you can deal with it.
Not familar with Quest sunroof, but it could simply be stuck.
hankster7
But yes,a new Nissan Quest is totally junk.25k-37k for a new Quest?? :sick: That`s crazy for the crap Nissan has put out. And it has got lots of quality issues-problems with brakes and rotors,power doors,horrible squeaks and rattles,steering vibration.Nissan should be really ashamed at this overpriced junk. :lemon:
And these problems have yet to be fixed even in the newer Quests.Slightly better than 04/05 but still very problematic especially for a new car price.Totally unacceptable.
A Sienna or Odyssey are infinite times better.No comparison really!!
I believe many owners (including myself) experiencing many headache before 100k or even below 50k...
my Clarion radio if officially dead. I receive an "offer" from the dealer to replace it (375$ in parts, 190$ in labor). I am out of the warranty period. :mad:
I have been looking into 3rd party radio, there is no way I am paying this kind of money for a very average radio. This price is for a re manufactured unit !
Anybody had any luck with generic DIN radio installed in the CD player opening? If so, please post pictures ...
1) try EBay. Sometimes you get lucky and find one available.
2) contact a few local A/V shops to see what your options are. It can be a place like Best Buy or a local shop. They'll be able to determine what can be done.
3) Call Clarion direct
How to Remove a Stuck CD
Steve, visiting host
The door does not open or close now, you can manually unlatch it, but it wont slide at all, I can get it to move a few inches by really moosing on it...but that sit. The door motor is definitely not turning, and it feels like there may even be some kind of clutch in there.
Does anyone know where the door motor is, and how to access it? I could really use an expanded parts drwg or even just a few photos of what the sidewall looks like. Also, could use some electrical input as wel...I am sure the door motor has a fuse...but where is it?
Tom
2006 quest 44K miles
tjshan68@aol.com
http://www.carcomplaints.com/Nissan/Quest/2004/tsbs.shtml
Good luck
I've driven countless times with the door still moving...and it will stop operation automatically if you drive too fast. You have to manually close it at that point.
Also we've manually stopped the door's operation by grabbing the door and pulling in the opposite direction without the motor burning out.
I would check the obvious items first before going to a mechanic...maybe a fuse (not certain of location)? Or a toy, stick, art work...jammed in the doors.
It should work without the motor running...sounds like something is jammed.
I'd use it as a manual door before I forked over nearly $1K...
