Anyone having air conditioning problems for a 2002 TrailBlazer?
Yes--but I haven't had it checked out yet. With mine, the fan is pulsing. It doesn't have anything to do with automatic climate control either. I know that for a fact. It's just not working properly.
Rando
Haven't (knock wood) had the problem since.
The service manager said that it is a problem with pressure build-up in the system during the heat soak and that the system must run for a while to take care of it.
He said that the mfr area rep had a procedure (have not seen it as a TSB yet) that involves some kind of "splicing" of the pressure sensor switch. This helped a little but not much.
The next time I had it in they lowered the charge pressure (on info from mfr). Again, better but not completely satisfactory.
The service manager has been great about working with me but said there is nothing else he can do at this point.
I plan on placing a call to the Chevy Customer Assistance Center (800-222-1020) so they are clear that there is at least one person that is not happy about it.
Hope this helps!
Here is part of the article.
"We initially figured replacing the refrigerant o-ring and seals would solve the problem we had with the air conditioning cutting out. It didn’t. A second dealer was enlisted to fix the a/c. They didn’t. Neither could a third dealer identify the source of the a/c problem. In all, we took our TrailBlazer to four different dealers, one of them twice, in an attempt to fix the a/c. Finally GM itself, alerted to the situation, came down and got our truck. We’re still waiting for documentation on what the problem was and what was done to fix it, but the air conditioner is now working.
Keep in mind, The General won’t be out to pick up the TrailBlazers of the regular Joes out there who are having similar, and in some cases, worse problems with their vehicles. (Believe us, we’ve heard from them.) But if you won’t come out GM, are you at least listening? "
http://autoweek.com/longtermtests/index.mv
I've got a 2002 Trailblazer EXT -- about as loaded as you can get. My wife absolutely loves it; and fortunately, we haven't had an endless line of problems like some people seem to. But we do have one significant, mind-boggling problem with the air conditioning. It doesn't blow cool air until you've driven for a few minutes.
We noticed this problem as we were preparing to drive off the lot (it's a tad warm in New Orleans in July), but we assumed we were just missing a setting to get it going good. And besides, once we got on the road, it began to cool off. Well...this persisted, and we realized it wasn't our inability to work the controls. It just will not blow cool air until it's been driven for a while.
My wife took it to the shop, and she was told that it's a known problem that it won't get cool while the car is idling. OK...but what's the fix? The best answer we could get was that they didn't have a fix, but the engineers are working on it.
Not satisfied, I emailed Chevy customer service. Their replies (after a few replies of my own) were:
"...We do understand your concern. As we said previously, Chevrolet is working on a solution for this. Your dealer will be advised of the status of this and will be able to address your concern once a solution is made available."
and "...We have spoken with Ms. Padgitt Pons, Service Consultant at your dealership regarding updates on the final fix for your air conditioning system. Ms. Pons confirmed that our technical engineers are still working on a final fix and the dealership will notify you once this is in place. As confirmed by Ms. Pons, your particular concern is isolated. We certainly understand how inconvenient this situation may be, however, we would encourage you to stay in touch with your dealership for the latest updates."
In other words...we can't and won't do anything for you. I believe a problem like this falls under Louisiana's "redhibition" claims (like lemon laws, only "if you buy something that has hidden defects that make the use of it so inconvenient that it must be presumed that you wouldn't have purchased it had you known of the defects prior to the sale, you may file a claim to rescind, or undo, the sale.")
Sounds good to me. Now I'm waiting to see what Chevy customer service has to say about that.
But...if anyone has a similar problem and actually got it fixed, I'd love to deal with it that way. If we can suggest something to the dealer to fix the problem, I'd much rather keep the vehicle.
After a couple of experiences with climate control, I tend to stay away from it.
Also once my A/C did not come on when i started the truck but when i shut of the engine and restarted the truck the A/C came back on. This has only happened once since i bought the vehicle in August.
1) the A/C system will take some time charging up. (cooling down the LP side)
2) even when testing an A/C, they tell you to put a thermometer in the vent, set it to the coolest setting, and drive. driving brings up idle, thereby running the compressor faster, and giving you cooler air.
Try this experiment... rev up to about 1-1.5k while running the A/C I can almost guarantee it will get cold fast(in fact, in my Honda, the A/C would very cold for about 45sec if you revved it real quick). I have had Honda, Toyota, and my Chevy does the same thing. I am pretty sure it's just that during idle, the compressor is not functioning anywhere near its peak. Remember the clutch can slow down the compressor, but not speed it up(faster than the pulley).
Just my experiences.
