Cracked radiator, some questions.
acuraowner
Member Posts: 57
My 97 Integra with alittle over 100,000 miles has been diagnosed with a cracked radiator.
I am pretty car saavy and know quite a bit about cars. This was very unexpected and really quite unusual for me. I have seen neglected radiators rust out, or get so plugged up they cannot function, but for it to be cracked is new to me.
The fellows at the Acura dealership said it was quite normal for it to happen as the upper and lower half of the radiator are made of plastic and the thermal stress eventually wins the upper hand.
I have taken pretty good care of my cooling system, I had the coolant changed at 60,000 then again around 90,000 (which is the recommended service per the owners manual).
Also my last question is, could I have them salvage my current radiator as I am not in the financial position to shell out $560 for them to replace it with a new unit.
Thanks in advance
Thanks in advance
I don't think you have any complaint with your car on this point. Sounds about like the expected life span.
The price of replacement is debatable, though, and you may do better elsewhere.
If you know about cars and can spin a wrench or two change it yourself. I checked on http://www.autozone.com and a new radiator with a lifetime warranty for your car is $180, so for less that $200 including the new coolant you get the car back on the road for about 1/3 the cost of the shop. It's a fairly easy job that can be done in a few hours. The hardest part of the job is usually loosening the auto trans cooler lines, after that it's a cake walk.
If you find a lower price, contact them and they will beat that price. They use top quality radiators, such as Modine, AC Delco and Koyo.
They may or may not be built as well aluminum thickness, etc but usually you can get 50k out of any of them.
On critical cars [V8] we have seen this 5F rise in back to back testing factory vs cheapo aftermarket.
The other thing to look for is does the radiator have a foam surround to block the air feedback around the edges bottom etc. Failure to replace this will raise the idle temperature. Make sure the system doesn't allow air to sneek around.
Back in the late sixties when I was a struggling student, there were a lot of old fashioned radiator shops around.
They would take your plugged up, leaking radiator and do a "rod and repair" on it.
I remember if we pulled the radiator ourselves and brought it in they would charge us 15.00.
Can you imagine how the enviromental watchdogs would like the acid tanks they used to soak the radiators in?
When a little old lady in her new (mid 1980's still RWD) Olds Delta 88 decided she had been stopping at stop signs enough, and she wasn't going to do it anymore, I hit her car with my 66 Chevy hard enough to total her car.
I drove home about a mile with the fan stuck in the top tank of the radiator, while a tow truck took away her car and hubby picked her up in a matching Delta 88.
Took out the radiator and hopped on my bike, radiator in hand. I think I paid about $25 to have the radiator fixed and maybe another $20-25 for new antifreeze and new flex hoses.
I kept the rest of the $500 check her insurance co "gave" me and kept driving the car, dent and all.
Sometimes I miss living in a small town.
FWIW,
TB
Ah, the good old days when the amateur (and living-in-poverty college student) mechanic could do a lot of work on a car with only a cheap set of hand tools. All I can do on my wife's new BMW is check the oil and tires (and the BMW service manager tells me not to bother with the oil - the computer monitors the level as well as the pressure).
Those were times when you didn't need more than a test light, timing light and some hand tools to work on rigs.
You pulled the radiator, threw in the back of the truck and they brazed it up for you and off you went. Radiator caps were pretty much 7-8lbs max. Now they are 15+lbs.
Temps were a maximum of 195F and that was considered very hot. Now, 200-212F is pretty standard.
A pickup radiator was heavy enough that you had to make sure you had a good grip on it to pull it.
Now, you could use one hand to pull them out.
You could run a vehicle on stright water if you had to. Now, that isn't possible without overheating the vehicle.
We used to tank the radiators, rinse them off over the drain and then crimp off the tube that was leaking, braze it and stick it back in the tank and pressurize the radiator to chek for leaks. If no leaks, rinse it off over the drain again, let it dry and paint it. Yep, there is no more rinsing it off over the drain, the chemicals hardly work at all and a large percentage of radiators are plastic and aluminum.
I could go on and on, especially about the ignition system. LOL!
The first vehicle I ever actually got to tear into was an old Dodge pickup with a flathead 6 cyl. Used copper straps to the plugs. LOL!!!
I don't remember exactly when they went to the insulated wiring, but I am pretty sure the early 40s Chrysler flathead 6 had the copper straps.
I don't really recall what vehicle it was, but I do remember reaching down to put my hand on the engine while it was running and hitting that copper strap. It left a very definite memory. LOL!
thats what I do
most die at 110,000 miles
Had to replace it because the fins on the radiator had dissolved in the road salt and it would not cool enough on hot days-had to drive all the way back from So IA with the heater on full blast in 98 degree weather-so if you are having cooling problems-turn the heater on high-worked for 200 miles.
Opatience, I never say the brass plug wires except on my Model A.
I do remember trying to adjust the points on my '62 Impala SS. Those were the ones with the trap door on the side of the distributor cap.
While the engine was running, I stuck an allen wrench through the little door. I managed to miss the hex hole but I hit the points instead!
Of course, I was lying on top of the engine when this happened!
Ah...memories...
I once saw (and heard) a guy do that to himself!
He ran circles around the car screaming obsenities for a good ten minutes as he held himself!
I went ahead and replaced the radiator with a OEM Acura/Honda radiator. To the tune of $700. The crack finally showed itself on my way home from work (car nearly overheated). It is right where there is a seam in the plastic upper tank.
I really find it amazing that it is quite usual for this to happen right around the mileage of my car. It makes me wonder...what is the point of the 30k miles coolant changes.
By the way. My car is actually running alittle cooler (according to my temp. gauge) since getting my new radiator.
Thanks for your insight.
Besides... If i remember correctly, the Honda's dont have the greatest amount of slack on their hoses... and they have all the mounts off the tanks... =o)
