Honda Accord 2000 brakes maintainance
tgozdalski1
Member Posts: 34
we own 2000 accord lx 5 speed. Right now we have 85,000 miles on odometer. The only problematic area with the car so far had been front brakes. At about 45,000 miles the new pads had been replaced by a local garage. Before replacement I could feel a little of vibrations coming from the wheels under hard braking. The garage replaced pads and turned the rotors. After about 2-3,000 miles the vibration returned. I had the same mechanic turned the rotors once again which fixed the problem for about 10,000. Today I bought a set of new rotors at $60 each at Auto Zone and new metallic pads and replaced them myself. The job was relatively easy. The only problem I had was to find torque specs for a caliper holding bolts. If anybody knows them could you please let me know?
I considered purchasing performance rotors and pads, but almost all of them require at least 16" rims. Did somebody find performance rotors, drilled or slotted, for standard 15" sized rims?
Tomek
Tomek
Sport Compact Car magazine has several advertisers that show slotted and/or cross-drilled rotors in stock size for the Accord.
I consider myself a relaxed person, I just asked for advice. My type of driving is 90% highway in a low traffic conditions. I hardly use my brakes. Also most auto magazines in their accord reviews estimate front brake life span at about 70,000 miles. hondadude, thanks for advice. I did purchase lifetime warranty metallic pads this time. I hope they will last another year until we trade in for 2003 ex 5 speed. Anybody with the repair manual can tell me torque values for caliper bolts?
Tomek
I get about 25K-27K from the pads on my 87 LeSabre which ends up being one year of driving. I change them every fall before it gets too cold. I seem to get two pad lifetimes out of my rotors before rust overtakes them. I just got about 52K out of a set of KVR/Brembo rotors which used up a set of KVR Carbon Metallic pads and then a set of the Bendix TitaniuMetallics.
But then I drive really hard and brake deep in the curves
TB
Or the pads will be made of a very hard material. These will squeek and drive you nuts.
BTW, my 99 EX V-6 coupe just had it's 45,000 mile service. Replaced rear pads they were getting thin. Front pads at 4MM. They are 10 MM when new. The rear pads only come with about 4 MM when they are new.
maybe about 7500 miles left on it. This seems
unusual because normally the front brade pads wear out first and the rear pads usually last
almost twice longer than the front. Is there
something wrong with my rear brakes? Anybody have similar problem. Please help. Thanks.
Never let the repair guys "true" up your rotors by grinding or turning them unless they really wobble when braking. Some places sell up for this "service" and it ends up costing a lot when u have to replace the disk rotor. Cheaper on the newer accords though-not necessary to press the thing into the wheel and bearing assembly.
SO in answer to your question-usually rear pads wear out first-you probably live in a city and are on the brakes a lot.
rear brake question. I do drive in the San Fran-
cisco bay area and traffic here is terrible. Also
thanks for the info on turning/not turning the
rotors.
Timadams-why did they replace the rotors-did u have incredible shake in the front end while braking??. If not you did not need rotors. What did they stick you for pads on all 4 corners and rotors?
N1010-57760 (I assume this is Honda Brand pads)
N1010-25912 PBR
N1010-87985 ACT Ceramic Japan
N1010-84172 Nissin Super Japan
N1010-99441 Advantex
N1010-45299 Nippon
Does anyone have an opinion on these various brands in terms of performance, durability, quietness etc... Any information and recommendation is welcomed.
I won't replace brake pads without either turning down or replacing the rotors, and my rear rotors were rusty enough that my mechanic suggested replacing them rather than turning them. I told him to go ahead and replace all four.
The whole job cost about $450.
(Ok, if the car sits for a while the swept area might develop minor rust. The pad removes this in the first few applications of the brakes. Or, for you unfortunates that live in heavyly salted areas, I understand lots of thing rust up and fall off of cars. Where I live, I don't see this happening.)
Your mechanic used the FUD factor on you. Fear, Uncertainity, Distrust. He's the one I would mistrust with my auto repairs.
(Now on the caliper part of the brakes, there are some areas where rust will effect function.)
In terms of longevity-have a 72 VW van - bought new - still has the original rotors-replaced pads a couple of times-and rusty rotors are not a problem-it just grinds the rust off.
Find a new mechanic-this guy is not your friend. I have gone with friends a couple of times when their dealer tried this stuff and put a stop to it.
What do you use on these plates to prevent squeeling? Also, what high temp grease do you use on the pins?
This is the first time I'll be changing pads since my 1972 Toyota Corona, so I'm a bit rusty.
Norm
I live in NYC, and do a mixture of city and highway driving.
I drive 50-50 highway city. I'm not a brake rider or a brake slammer. I let let off the gas to slow
down before i break in most cases. I've
replace the frontbreaks under 20k and the rears
under 25k.
Is that normal ????
Anyway, front and rear brakes were replaced at 26,000 miles. Make sure you correctly torque those caliper bolts.
Norm
Please advise.
JJ
put new wagners and china made rotors,they warped, had them turned and problem still came back.
started to suspect the rear brakes weren't doing there part causing the fronts to over heat.
After driving the front rotors are very hot while hardly any heat comes from the rear[i know the fronts do most of the work but i can hold my hand on the rear drum for a couple of seconds before I can feel heat and it doesn't burn
replaced the rear drum and shoes and the proportioning valve.[bled the system real good]
installed new rotors worked good for a while, just starting to warp again
anyone have any ideas I can try next
I have four other hoda's in my family that i have done brakes on and my 94 accord is the only one that is giving me problems
specs. I knew 4 has higher boiling point but didn't know it absorbs water more easily, Thanks!
Yes, I bleed the brake system but I can do nothing about the fluid in ABS unit.
