About a year ago I impulsively bought a sale-priced set of universal fog lights from a nearby Harbor Freight Tools outlet. I recently (finally) decided to install them on my 2004 Jeep GC Laredo. Luckily, I didn't need any extra parts or whatever, thus holding the home installation to the original $10.00 purchase price as the total expense. The kit works like a champ, and only required some 8 or 10 hours of my time to cleanly install... aaaaaargh!
Here's a complete diagram for you!
How To Wire Up Fog Lights
-mike
thanks a lot.........
gio
I don't have any RAV electrical schematics, but did you do any research into all of the parts that you needed to make fog lamps work in that vehicle?
Can you look at a 06 rav that has foglights, and see what switch they need to turn on?
You may want to haul yourself over to a dealership, and go buddy up with the parts guy.
my name is rob i have a 2001 highlander all my lights are perfect except the parking lights all
grounds,fuses,relays,etc are fine but still no parking lights ... i have brake headlights, turn, reverse,etc no parking lights.
Please im begging yoiu toyota highlander (GODS) if u can lend a kind hand for im disabled and
no money in the till to bring to a shop...
Please ill do what ever to try anything any suggestions or better yet the fix would be most
appreciated. So if any one can lend me opinons,facts,real thoughs,anything to fix this,Its for
my wife and i cant have her driving home in the dark with no tail lights (AKA) parking lights
Please i await your help with great egarness.
thanks and godbless you all
rob aka codmyster
If so make sure you get the led wire and put it on the switch side of the switch that way when you turn on the fog's the led as well as the fog's turn on. If for some reason you have to add a diode or relay mess me back and i can help you wire up most anything for that. Im sorry i hope this helped you.
Cod
1. unpack pack the fog's and get the wires and what else that are in there..
2. now you going to have to run the wires from the hood area to inside the car and please make sure to use split loom, and groments when going thur the firewall.
3. your going to need to wire them up after market or go thur the pain finding all the factory plugs and relay slots in the hood area. Or you can
follow the details ill help you with.
4. ok last and not least you need to mount and wire up ill do my best in order to lead you simple steps.
ok first you need to get your hands on 1 bosch dbl poll dbl throw relay 30 to 40 amp . you can find them at any radio shack online even walmart i have gottem them there before. you going to need spilt loom, black tape, tie wraps, and some butt connectors, female spade insulated connectors that will fit on the relay u need to wire in..
ok here is simple wiring diagram for relay on fog..
LOOK ON RELAY you will see numbers 30,85,86,87,87a.....
ok the easiest way is to get a battery supply from the battery with a 20 amp fuse, and try and use no less then 10-12 gauage wire.
ok here u go ..
30 is to the battery all the time FUSED.
86 is to ground. chasis ground to the body or good ground spot, dont skimp make sure its clean ground connection..
85 is from the key of the ign.. this mean when u turn your key on there is 12 volts coming from this wire here.
87 is to the switch of the fog lamps switch side the off postion then the wire you ran thur the fire wall goes to the on side of the rocker or on off switch for fog lamps.. here is my email rgullo@cfl.rr.com if u need i can give u my number i have done all kind of electronics for over 25 years..
Make sure if u email me give your name and say im the one with the fog lamps.. then ill email u back and we can go from there..
I hope this helps your GOODLUCK & GODBLESS...
CODMYSTER
-Nauman
