'17 Chevy Volt Premiere
Sorry to ramble here... quick question.. the car sits in the garage for over 24 hrs.. I back it up in the morning and it won't move.. like the back brakes are welded together or the emerg brake is still on (it's not).... it's not until I rev high that it moves but with a forceful jolt sound coming from the back wheels.. thoughts? opinions? comments? thanks.
The dealer checked the E-brake after I mentioned something to them, and they said that it was okay, and within specs.
From now on, after washing or a rainstorm, I just park it in gear, without the E-brake, and give it time to dry. Haven't had a problem since...
My car also has the infamous 1-2 shift shock problem when I drive it first thing in the morning. Has anyone found a reliable solution for this? Both dealers I've taken the car to say "lots of people have that problem, but we don't have a fix."
now the "infamous 1-2 shift shock"... i'm not quite sure what this is but here's what i experience on my 5 speed manual - tell me if i too have the 1-2 with mtx!!!.... first thing in the morning going up the street: the acceleration has a life of it's own while in first gear... for a nanosecond, it's like i'm pushing the accelerator further but i'm not.. i receive an uncontrolled and unwanted burst of acceleration energy... but it's not coming from my foot... if this is the 1-2 shift shock, i was told by the dealer that it's normal and it's nothing to worry about... hope this helps..
:confuse:
Higher octanes are generally used in engines with higher compression ratios for this reason; the higher compression ratios require a fuel which will not spontaneously ignite under the higher pressures, leading to knocking. Of course, the flip side to this is that if your engine knocks on the lowest grade of fuel for which it is rated, you may have a problem with your timing being advanced out of spec, or there may be a quality problem with the PARTICULAR fuel you are using (and you should thus try a tank or two of the same grade from another supplier before going up in grade).
Of course, there are some who say that regular unleaded, being a commodity (it's traded on commodities exchanges like gold, or pork bellies), is often purchased by retailers, especially no-name or off-brand retailers, at lowest cost, and so there may be quality issues with it, whereas a regular supplied by a branded retailer is more likely to be of better quality and have few impurities and more consistent and/or better detergent components added. I don't know how true this is; speaking for myself only, I've pretty consistently used discount brand suppliers for 87 and have never noticed a problem with it (but then, I live in NJ, the refining capital of the east coast).
Seems to me that being hard to turn wouldn't necessarily be because of an alignment issue, and that there could be another cause (e.g., low fluid, loose belt, faulty power steering pump, air in fluid, etc.). Did your dealer check the power steering system for any of these possible causes, or did he just do the alignment and not really try to get to the bottom of your problem?
I'm not trying to blow up my car; I assume that after a first occurrence the dealer usually resets it, says nothing's wrong, and sends you home hoping it doesn't trip again. Then if it does, back to the dealer. I'm just trying to save myself a trip for a false alarm.
Another question: was the alignment performed under warranty, or did you pay for it? I'd hate to suggest the dealer was less than scrupulous, but I'm having a hard time seeing how tight steering was diagnosed as an alignment issue in the first place....
Any input would be greatly appreciated...
I've taken it to the dealership about 4x for this problem (it's in for the fourth time as I speak) and as of last week they updated the 'software' that was supposedly going to be the magic solution. Then today the problem reared its ugly head again.
I was curious as to whether or not anyone else has had the specific problems I have had. When I first got the car in Oct 03 I had 'cold stall' issues which were resolved by the software upgrade back then. But about once a month or so, when I'm getting on a local highway onramp that's downhill and curves to the right, my engine starts to surge uncontrollably around 40mph. It feels as though the car is having a seizure! It refuses to accelerate past that point and I end up having to pull into the shoulder or exit immediately. Then I turn the car off and back on again and it's usually fine. I haven't noticed any engine lights on any of the times this has happened.
The dealership has been pulling a "if we can't make the problem happen then we can't fix it" type of thing with me :mad:. It irritates me. Normally I wouldn't care if it was just a vanity issue, but my feelings are that this is a SAFETY issue. I don't like being stuck at 40 when trying to merge onto the expressway. One of these days I'm going to get rear ended by some fool behind me or someone trying to exit.
Has anyone else experienced these problems even AFTER the 'software upgrades'? Any suggestions on what to do about it?
I haven't done the conversion because I use my high-beams often (I live out in the sticks!) I know that LEDs are sensitive to heat, and the high-beams generate a fair amount, so make sure you buy a few sets just to be prepared...
Apparently a small number of cars have been having similar problems. They replaced the fuel injector. So that was the problem with my car... perhaps it is the problem with yours as well. You should bring it up with them!
As far as the colored lights being illegal, they definitely are illegal in southern california, but it's southern california, and no one really cares! :shades:
wedge
Any advice or websites I can try?
Try out these places:
autolumination.com
superbrightleds.com
I've never personally ordered from these places, so I can't personally vouch for them, I was going to try autolumination for the chrome-coated turn signals that glow amber when lit. I like that look!
Good luck!
We recently had a pulling to the leftproblem, but that was due to low air pressure from a small nail & slow leak.
Schedule an appointment at your Mazda dealer for a CEL. When you fill out the paperwork, include a copy of the info below. Good luck.
These CEL codes indicate a failure in the part of the electronic throttlebody. Either through the failure of the electronics, or the sensor, the throttlebody no longer functions as designed. This results in a Check Engine Light with one of the following codes P2135, P2101, and whose appearance indicates that the entire throttlebody assembly must be replaced.
The electronic throttle actuator can't be serviced itself, and thus the entire assembly must be replaced. Below are the codes the scanner will pick up and display.
Originally this also included P2110. That CEL has been upgraded to a full Technical Service Bulletin, and is solved through a PCM update. The other two CEL's above appear to still require replacement of the throttlebody assembly.
DTC P2135 [AJ]
TP sensor No.1/No.2 voltage correlation
DETECTION CONDITION
The PCM compares the TP sensor No.1 signal value and TP sensor No.2 signal value. If the signal correlation for both is out of specification, the PCM determines that the TP sensor has a malfunction.
Diagnostic support note
This is a continuous monitor (CCM).
MIL illuminates if PCM detects the above malfunction condition during first drive cycle.
PENDING CODE is available if PCM detects the above malfunction condition.
FREEZE FRAME DATA is available.
DTC is stored in the PCM memory.
POSSIBLE CAUSE
TP sensor malfunction
PCM malfunction
DTC P2101 [L3]
Throttle actuator circuit range/performance
DETECTION CONDITION
If the PCM detects any of the following conditions, PCM determines that throttle circuit has malfunction.
Default throttle angle that PCM memorized and the throttle angle with ET control relay OFF is not much.
Voltage from ET control relay is too high or too low
PCM detects big voltage difference between from ET control relay and from main relay
PCM internal malfunction
This is a continuous monitor.
MIL illuminates if PCM detects the above malfunction conditions in two consecutive drive cycles or in one drive cycle while DTC for the same malfunction has been stored in PCM.
PENDING CODE is available if PCM detects the above malfunction condition during first drive cycle.
DTC is stored in PCM memory.
POSSIBLE CAUSE
ET control relay and related circuit malfunction
Main relay and related circuit malfunction
Throttle position sensor No.1 and related circuit malfunction
Throttle position sensor No.2 and related circuit malfunction
PCM malfunction
Shift shock is when you start up from a light (somewhat lead-footed) and the engine is reving like crazy and, suddenly, it surges forward violently with a sound like you've been hit from behind. Since it's been doing this, I've learned to accelerate a bit more gently. Somewhere in this forum, someone gave instructions on what to tell the dealer but I dislike all the dealers in my area. I mentioned the shift-shock to a service advisor once and he said "I've never heard of the 6's doing that" and I didn't want to push it. The car runs great, except for that. I've never had any other real problems. So I don't want the dealer to mess up the good that I've got - call me cynical.
AT "shift shock" is just a harsh or hard shift between gears, not from a dead stop in 1st first gear. The behavior you describe from a dead stop isn't "shift shock" and isn't normal, assuming that this is all happening in 1st gear and not during to the 1-2 shift. It sounds more like low trans fluid or some other trans problem. Some cars will do this a little when the trans is cold. If you try a start from a dead stop using your AT in manual mode in 1st gear and get this behavior, you've got a problem.
Registered on the mazda owner website (mazdausa.com, follow the links) and ran across this, which I thought I would share:
Unbelievably Affordable Oil & Filter Changes With Coupon $6.79
You can pre-purchase oil & filter
changes for as low as $6.79 per oil
change. That's a savings of $444.60 over
a 7 year period that no one can touch!
Please call for details.
Plus applicable taxes. Valid only at SKYLAND MAZDA. Cannot be used with any other applicable offer. Mazda vehicles only. Some vehicles may be slightly higher. Hazardous waste fee is applicable. Expires: 07/13/2005.
Who knows whether there may be a catch, but it seems worth investigating!
Any help would be appreciated...
