Nissan Murano Maintenance and Repair
From reading the Nissan Murano Message Board, I see that many owners are experiencing some problems with rattles, popping noises, etc. If anyone is experiencing these issues (or others) with their Murano please post the problem and solution, if any.
I am experiencing a lot of rattles throughout the vehicle. Front driver's window/door and passenger’s rear door rattle, popping sound in the rear of vehicle and dashboard squeaks. Test drove a different Murano and aside from a minor rear noise all was fine. I will be bringing the vehicle back to the dealer so they can look at it and hopefully fix these annoying issues. I will post a follow-up message, hopefully with some solutions so others on the board experiencing the same problems can get them fixed.
I'm guessing the problem I have with CDs skipping is simply a bad unit, and the dealer agrees and has one on order to swap it out.
would ever need to be removed in the future.
buck80, I've previously had both the press board cover and the plastic tray completely removed and still had the popping sound. I'll investigate the area around the spare, but my recollection is that when I first got it, I couldn't budge the spare. Thanks for the ideas, I'll try it.
As to the question, would you do it again? Definitely!
We've owned Infinitis in the past and loved the treatment. So far, I've been disappointed in the afterbuy experience. Maybe that's just the difference between the brands.
We do enjoy the vehicle, though!
However, I am now pretty happy with the vehicle itself. If a building collapsed on mine, insurance paid the loss, and I was out shopping again, I'd head back to the Nissan dealer to see if they could do any better on the price this time. And I think I'd get the all-weather mats and the splash guards installed, too.
One of the few complaints that I have with Missan vehicles is that the front glass seems to be "softer" than it could be?
I've replaced both of the windshields on my Maximas (one at 150k, and the other at about 35k) due to lots of chipping and marks from all of my highway driving.
Then of course I suppose it could be my fault from the way I drive.
Have you checked the pressure in all four tires manually, to ensure they are all at least 33psi and under 44psi when cold, and that they are all within 1-2psi of each other? Weird tire inflation can confuse the ABS, VDC, and AWD systems. (What is SLP?)
The best benefit of following the dealer's advice is that you've just gotten a major piece of the potentially most expensive area to work on repaired.
This repair gives you a "partner" in the performance and diagnosis of any future issues related to any of the these systems.
I always play "dumb" whem making a "first" visit to the dealer for repairs. Let them show you how smart they are with their diagnosis and let them make the suggestion as to what will fix the problem.
Then if anything doesn't work out as they expected, their guilt will sometimes get you much further down the road quicker and at a lower cost to you.
Since your still under the bumper to bumper warranty, your decision is easy.
Re: door locks....I locked myself out of vehicle 3 times with the engine running. When driving the vehicle i lock all doors. when i stop for gas i open driver side door and the locking nob automatically opens up, but when i push the door open i accidentally close the nob. I thought the locking nob should automatically open but it doesnt. When using power door locks everything is fine. does anyone else expoerience this problem.
It just happens.
In case you ever get stuck or are starting out from a slippery place, you CAN lock the AWD Murano in AWD BUT this locking feature self-defeats after 19 m.p.h. and the Murano reverts back to front wheel drive. If I've misstated anything I'm sure others will clarify.
As to locking yourself out of your vehicle THREE times already, may I recommend some behavior change on your part, a stronger vitamin, or perhaps the hiring of a chauffeur?
In addition to the safety concerns about leaving a vehicle running when the pilot is not seated in the pilot's chair, why would you want to waste expensive essence of dinosaur while you are refueling? If you were in a ultra-frigid climate and the engine had a reasonable chance of not starting again if you turned it off, then you would have a reason. Are you in northern Alaska?
With respect to your question, your car unlocked the door for you when the door opened, you locked it again, and then you closed it. There are thus two possibilities:
(1) You are inside the car, and therefore you changed your mind about getting out.
(2) You are outside the car, therefore angry.
Since the car can't tell the difference (between you being inside and you being outside) and since every action it took was to save you from your own intelligence, that leaves you and you alone to blame.
Doctor, it hurts when I do this. Then don't do that!
Barryg1 needs to make some behavior modifications!
On the other hand, leaving your engine running while putting in fuel is not a great idea...
Just kidding, but I actually did see a "person" doing this the other day. I just got back in the car and drove to the next gas station!
Can you say, KABOOM!!!!!!!!!!!!!!!!!
It's also not a safe practice to hop out, start filling up, and then get back in the car - it's rare, but there have been a couple of instances where static created by sliding in or out of the car has ignited the gas fumes.
I guess everyone knows not to fill up the lawnmower gas can in the car too? (put it on the ground first).
Now with the Murano, I keep going but I tap the tire pressure monitor button occasionally for the next couple of miles to see if the pressure is dropping. If it isn't dropping, I don't need to stop. I like this car!
I would think that somebody leaping out of a car yet leaving the engine running, so that they can put their head down under the vehicle to check the tires, is a wonderful candidate for a book I've seen called The Darwin Awards.
barryg1, I have no idea what you're trying to say about someone not having the mental capacity or English comprehension to shut down a vehicle. My thoughts are that if somebody doesn't have at least that capacity, I don't want them to have the privilege (e.g. driver's license) to be operating a motor vehicle on the same roads that my family and I are allowed to use.
PS.... the local dealership reports 8 problems like the one I mentioned.
Infiniti G35 Programming Possibilities:
Door Lock/Unlock (with single click on keyfob)
Mode 1: Unlock left front door only
Mode 2: Unlock all doors
Anti-lock Out (prevents locking keys in car)
Mode 1: Master door lock switch can activate door locks w/ key in ignition
Mode 2: Master door lock switch cannot activate door locks w/ key in ignition
Dome Lamp Timer
Mode 1: Interior lamp comes on when left front door is unlocked
Mode 2: Interior lamp does not come on when left front door is unlocked
Retained Power (Amount of time windows and sunroof will operate after turning off ignition)
Mode 1: 45 seconds
Mode 2: No delay (Will not operate after ignition key is turned off)
Mode 3: 2 minutes
Auto Light On (headlights turn on as it gets dark)
Mode 1: Factory setting
Mode 2: Lights come on sooner than factory setting
Mode 3: Lights come on later than factor setting
Mode 4: Lights come on later than Mode 3
Head Light Battery Saver (applies when headlights left in “on” position, not in “auto.”
Mode 1: Shuts lamps off after 5 minutes
Mode 2: No time delay (headlights turn off immediately)
Headlamp Illumination delay (time headlights remain on after exiting car when headlight is in the “auto” position)
Mode 1: 45 seconds
Mode 2: No Delay (lights turn off immediately)
Mode 3: 30 Seconds
Mode 4: 1 minute
Mode 5: 1 ½ minutes
Mode 6: 2 minutes
Mode 7: 2 ½ minutes
Mode 8: 3 minutes
Hazard and Horn Reminder Mode (key fob allows you to choose between modes 1 & 2, but there are 4 others)
Mode 1 (C Mode): Lock = 2 flash, 1 horn /// Unlock = 1 flash, 0 horn
Mode 2 (S Mode): Lock = 2 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 3: Lock = 0 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 4: Lock = 2 flash, 0 horn /// Unlock = 1 flash, 0 horn
Mode 5: Lock = 2 flash, 1 horn /// Unlock = 0 flash, 0 horn
Mode 6: Lock = 0 flash, 1 horn /// Unlock = 1 flash, 0 horn
Remote Auto Locking Function Mode (Doors automatically lock after exiting car)
Mode 1: 5 minute delay
Mode 2: Function disabled
Mode 3: 1 minute delay
Remote Panic Alarm Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Trunk Open Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Power Window Down Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: 3 seconds
Mode 3: 5 seconds
This should be the last thing to be considered a problem.
Well, Nissan, get your act together! A car that requires conscious thought to operate? How unfair!
Teach 'em a lesson barryq1- sue their sorry socks off. Thought should NEVER be required to operate a product in the US!!!
thank you
If your local Nissan dealership has sold to 8 other people that don't think when operating their vehicles, please provide your zipcode so we can ensure we never visit that area of the country.
div2, you're hilarious!
I definitely don't agree with the idea of pumping gas with your engine running nor can I remember the last time I left my car running without being in the driver's seat.
BUT, that said, there shouldn't be anyway to lock the door from the outside with your keys still in the car. That is just a prescription for lock-out. It is not at all unsual for somebody to get out of the car and accidently leave their keys ont he seat (not smart- but also not unusual).
My Honda will not allow me to do this and neither should the Nissan.
I also fail to see how a car allowing a driver to be locked out while the engine still running could be conceptualized as a "safty feature." It is bad design. Pure and simple.
The Murano is, on whole, very well designed. This is just one example of a ergonomic gotcha.
I always thought people who locked themselves out of their cars were, well, stupid, until guess what? Yup, I did it to myself in an old VW Bug at a car wash. Then I saw the event in an entirely new light!
Would you lend your Murano to a friend or relative and not tell them of this potential problem( assuming you would lend out your car)
IF YOU DONT MENTION THE POTENTIAL PROBLEM THEN YOU HAVE FULL FAITH THAT YOUR PHONE WONT BE RINGING IN THE MIDDLE OF THE NIGHT...
OK, so in this thread we have established that the fact that the door does not unlock when manually opened, manually locked, and manually closed is an ergonomic snafu for people who don't think where their hands are when they are in a running vehicle. And it can just as easily be a safety issue if you're about to be carjacked. The more creative folks here can think of any number of scenarios in both areas.
The point is, trading off even the remotest possibility of having an extra safety feature in a crisis, against the inconvenices caused by somebody being clumsy or stupid, is an easy one for me to make. In my opinion, the Nissan engineers made the right choice.
Yes
Anyway, upon delivery of my Murano in February I have had significant alignment/balance issues, a stress crack in my windshield, and a faulty fuel-gauge. Additionally, I have experienced the same popping or rubbing noises others have experienced.
To make a long story short, the alignment/balance had been taken care of. The windshield has to be pulled from the assembly line and the faulty fuel gauge still needs the part. I have complained to NISSAN Consumer Affairs and told them about my issues. I told them that I have been dissatisfied with the quality of my Murano and that I propose one of two options. Return my vehicle with no penalty to me, or I would be willing to purchase the higher quality FX35 or FX45, if they would make up for my loss on the Murano during the trade. Guess what - they turned down both. They told me to go through the lemon law in my state.
So, now I believe that NISSAN really doesn't care about me as a customer and is acting pretty silly when it comes to my second offer.
Any advice or suggestion would be appreciated because after nearly three months I still have a stress crack in the windshield, a faulty fuel gauge and a car company that doesn't want to be reasonable.
