PLEASE HELP
Gene
Joe
Also this 3.4L engine have 3 Spark Plugs close to the firewall that is a pain in the neck to replace it, check this out too.
Check and let us know!
Good lock!
Please email: [email protected] if you see a fix., thanks
thanks!
I have a question, I have a 2003 Hyundai Elantra and lately when I stop at a light the car act like it wants to stall but doesn't. Can anyone tell me what it may be. I want to take it in but lately when shop see a women they just tell us anything and then wouldn't fix the real problem :sick: of shop owners......taking advantage of women
Mechanics are unable to determine the problem. Throttle body was cleaned, Oxigen senser changed ("Service engine soon" light when on), gas filter changed.
Can anybody help? Pleeeease.....
The car idles great in park but will not idle in drive, it keeps stalling out. Any ideas?
Car starts OK but stalls sometimes when put into drive, usually after sitting overnight. May or may not stall again during the day at stop signs. Happens in summer and winter. Recently, it idles rough erratically.
Just had crankshaft position sensor and camshaft sensor changed to the tune of $458. Didn't work. Read lots and lots of forums about PCM tricks and O2 sensors. I just don't know where to go from here.
I am a car repair novice. What can I do to check out some other things? I am willing to tinker to death and get dirty but don't have a lot of tools.
Jeep has been in the shop three times for the same problem. They can't isolate it and there are no error codes. It's getting expensive to guess.
If anyone has a suggestion for a novice, please let me know. Jeep has 194 K miles but it's how I get to work every day. Thank you.
When I try to start the engine while warm, it will turn over normally but it won't fire. When the car does eventually fire, the engine will catch, shudder and chug as if it is not getting enough gas. Then the car will jerk and stall out.
If I press the gas pedal when the engine fires, I can push through the chugging, stuttering stage and the engine will stay running but the idle will be very rough.
If I let the car sit for couple hours after it was warmed up, (so the engine is cool again) it will start up normally.
I have had new plugs and wires installed.
Fuel pump tested o.k.
Fuel Filter replaced.
Crank shaft sensor replaced.
I had the entire fuel system and spark plugs thouroughly cleaned.
No sensor lights are on.
I have invested over $1000 in the car and it still has this problem. Does anyone know what is going on? I would really appreciate any input as I am really not in a situation where I can afford to buy a new car.
Thanks so much!
-Kelly
My mechanic is a bit stumped. Car runs great for a bit then starts stalling out.
Anyone having this problem? I need some help here.
Any technical Service Bulletins? I have owed the car for 6 months now. Pasted a very thorough inspection before buying it. Now I am having this trouble. I need some help here and fast!!
Thanks, Lorraine.
Thanks, Lorraine.
The truck has a bypass switch and the forward fuel tank was removed. Both of these modifications occurred before I owed it. Also, the clutch is a bit grumpy. Sometimes I'm unable to get it into first (I usually "granny start" from second), and every once in a while it doesn't want to go into reverse.
When I bought the truck, it would just choke and cut off after driving for 30 minutes or so. It would restart after cooling down. My mechanic said it was a problem with the fuel pump and replaced it, and that fixed that problem.
After that, the truck began to have trouble starting. I would flip the bypass switch and the engine would rev up, then drop RPM's quickly until choking off within a couple seconds. When I flipped the switch again, it would start up fine. It would run fine after that.
A mechanic recommended having the fuel injectors cleaned. The fixed the problem for about a week, then it started again. A friend of a friend who has a home garage suggested a vacuum leak, and we found a leak in the EGR value, which we replaced.
Replacing the EGR valve fixed the problem again, for a couple days, but it came back. Meanwhile, immediately after the EGR valve was replaced, a new problem started. Periodically while I'm driving (I haven't been able to detect any pattern), the engine will just shudder or choke a bit. It feels like it's threatening to choke, but it never actually does. Once it starts, it typically does this every couple seconds until I shift gears.
I'd really like help in diagnosing what might be causing the choking when it starts and the new shudder when driving. I realize it could be a number of things. I'd like to prioritize things which are least expensive and which would need to be done anyway for routine upkeep. Any ideas?
This is a very generalized symptom--and "stalling" can encompass a wide variety of causes, especially without any history on the car or any trouble codes being scanned.
Here's an OVERVIEW" of stalling conditions and what might cause them.
2001 Sunfire 2.2L automatic stalls when slowing down. Has a strong smell of fuel when it restarts but starts back up as soon as the key is turned. I can keep it running at stops but only if I throw it into neutral and drive it like a manual. RPM's start bouncing back and forth between 1000 and 500, then 500 and under just before it stalls. This is the first time I've had any problems with the car other than an intermittent misfire that it's had since I got it. It has 209k on it. I've read that this could be a temp sensor causing this but which one? The tranny temp sensor or the coolant temp sensor? It's been between 1 and 30 outside lately but the car only has problems when it warms up to the normal 195. Temp gauge is reading properly in dash. I gave her a tune up this spring (plugs, wires, oil air and fuel filters, coolant, etc.) and been a champ till last night. Has all original sensors. Any suggestions on which temp sensor could be causing the issue? Or could it be something more? Also, it doesn't like to get up to speed when it's cold outside. It takes a long time to shift and seems all around slow to get up to speed. Thanks for any input! I'd really like to keep her running for as long as I can, She's been good to me!!!
We have a 1996 Nissan Quest - but only 72000 miles (we bought it from our daughters' 90 year old piano teacher who only used it for camping trips with 45K miles 3 years ago) I have an intermittent stalling problem. Only at low speed, sometimes going up hill or into a turn, I get a compete loss of power. Still have steering, (not power) so I wrestle the beast over, and it restarts right away. No check engine light. This has happened about 6 times. Not low gas level, usually 1/2 + tank.
