Fuel Injector Cleaner: Does it really work?
I've seen those STP Fuel Injector cleaner commercials quite frequently lately. Has anyone actually used it or similar products, and have seen actual improvement in your car's gas mileage and overall performance?
don't want to dump in my fuel tank something that doesn't work...
See also: Fuel and Oil Additives
There are some professional/industrial grade cleaners which are super-nasty and I've used them and they can definitely work (sometimes).
Injectors can be cleaned [on car] with a rail pressure flush and 30 minutes of idling with BG Injector cleaner pressurized system [usually at a higher rail pressure 50 psi]. ~~$100
You can remove injectors and send them out for ultrasonic cleaning at $25 EACH plus 2 way freight
You can replace them for $80-$150 each plus o rings and labor.
I usually don't mess around if I know the bad injector and just replace it. Problem is you don't know if the rest are going to go, and that gets expensive.
Study the failure rates by gasoline regions.
On a certain V8 the injectors are $155 x 8 + $750 to change........almost no failures in Southeast region, in Arizona/parts of CA [lots of other regions also] they go out every few years.
The new compounds attack the coil insulation through the seal.
vidtech, sorry, that argument won't fly. Some chemicals are designed to be used diluted because they are safer that way. Would you say the same thing about hydrochloric acid diluted and sold as muriatic acid?
Buying a used car and dropping in fuel injection cleaner is a huge waste - diluted cleaner simply cannot clean dirty injectors.
Not that I was aware of anyway.
BTW, what is it about alcohol? We get 10% ethanol in Colo. due to air pollution requirements. The only problems I ever heard about it was that it would loosen the gunk in older cars' tanks and lines and cause problems. Supposedly it's more of a solvent than straight gasoline. Wouldn't that tend to keep things cleaner? Or is that what fouls up the injectors in an older car that hasn't run alcohol blends before?
now, if you're burning the old lawnmower gas in the car twice a year, that's not going to do you any favors. better to mix it with Sta-Bil at the end of season and leave it for the one-lunger.
The variance in the shut off rpm drop tells you if the same amount of fuel is reaching each cylinder.....ultra smooth [as brand new idle] or shakey unmaintained one?
Really depends on injector type and internal design [pintle, disc, multihole, etc] as to the clogging time and characteristics.
I will post gas mileage result after the next refuel...
