A/C, Heater blower fan doesn't work
My interior A/C, Heater fan doesn't work. I've checked all the fuses, interior and under the hood, and all are ok. I've removed the fan and hot wired it to the battery and it worked. I've also checked the resistor with a multi meter and it show's that it's ok. I've also removed the dash to check the fan switch and it was ok. I'm lost as what to check next. Any suggestions are welcome. The dealer wants over $50.00 an hour and I would like to save some money and fix it myself.
Thanks, Paul
Thanks, Paul
the a/c may have a limit switch that shuts off the fan. there may also be a set of outputs from a general-service electric module... aka a power control module.. that are part of the circuit. these modules are not without failure, and they are priced without modesty
a wiring diagram for your can may help. if this is the focus you also ask about in other discussions, and there is warranty left, get what you can and let the dealer charge Ford $50 an hour.
Thanks for the info. I should have mentioned that this is my 94, 1.9 liter Ford Escort Wagon. The car has been great except for this blower fan problem. Do you know where the general-service electric module... aka a power control module is located. It looks like it's time for me to get a repair manual for this car.
Thanks, Paul
Paul
Well, not really a fuse.
There are 3 coils, each provides a certain amount of resistance and there is a diode in the circuit.
Location and what it looks like.
Is it possible to just replace that diode?
I suppose you could replace just the diode form one at Radio Shack. But unless you get the right one, you may create some other problems.
And a new resistor is less than $15.
Ok, back to your problem. Look at the image I linked to again, I added the connector view.
On Terminal 2B, with the fan switch on, do you have power?
In low, med and high, do you have power and if so, what is it?
If you have power at that terminal and it is different in each position of the switch, then check the terminal on the fan motor.
Let us know.
The design is to drop the voltage and not feedback to the other circuit.
A fuse will feed either direction, where as a diode only goes one direction.
Most of the schematics for the resistor only show resistors, no fuse.
I went out to see a Ford resistor tonight to see what you were talking about.
I didn't find a temp on it, but I did find a marking for 1.3 ohms.
hmmm.
Personally, when you start getting into what stuff is called, that wastes my time. Regardless of what it is, it is not a serviceable item. For a $15 item for the resistor, you spend far more time messing around with trying to solder something in there to make it work.
Don't be so cheap, if the resistor is bad, replace it with an OEM part and go on.
Thanks for your help.... )
Paul
bad things would happen if the diode was installed backwards, so replacing the resistor assembly as one piece makes the most sense.
Installing a diode in place of this device will make the blower work as long it is installed in the direction that allows conduction. As I said before, even a jumper wire will work. The motor will run slightly slower as a result of the 0.6V drop of the diode. Look and see if the device in question looks like this:
http://www.radioshack.com/searchsku.asp?find=270-1320
Been trying to find my 1st gen Haynes Explorer manual which I remember indicating this part. You don't get detail often on unit replacement items. Depending on heater design, this may not be needed for fire protection. You said you have seen this two lead device that looks like a diode. I've replaced a number of these in small appliences and they work for years afterwards. This leads me to believe that some of them fatigue or go bad for some reason as they age.
An $8 item isn't worth even attempting to solder a 75 cent item in it.
You say creek, I say crick.
and then I thought, why screw up a beautiful afternoon?
ain't even worth settling my curiousity over. it's eight bucks. pay the man and be done with it.
Opatience:
"Ford has a thermal fuse
There are 3 coils, each provides a certain amount of resistance and there is a diode in the circuit"
Just goes to show you are young enough to learn something.
Although, I have to deal with engineers all day long, if you tell them that a fire engine is red, they will argue that it isn't really red, just how the light refracts to you.
I don't wat to grow up, I have too much fun being a little kid. LOL!
Please someone help me. I have a 97 Escort. email at "tkenney@mn.rr.com" thanks.
two, have a two-gauge check made on the a/c, I strongly suspect the charge level is wrong or you have a sticking relief valve that is causing overcooling.
it could be a little icy drool down the housing freezing the blower cage, or it could be sticking a damper, but I'd attack the icing problem first and see what others remain afterwards. it is not good design practice to make a/c that ices up the blower, you are wasting energy and spending a couple bucks too much on the a/c when you build it. if you think like a nickel-shaving engineering department when you look at something, it leads to some trouble-shooting clues.
I may be assuming too much to assume the blower motor has already been tested and found working... blower motor dead so no air flows would also help explain everything, but it still shouldn't ice up that bad, suggesting there is another issue in the a/c. obviously, if the blower is dead, that needs to be attacked first to help isolate and determine how big the other issue is.
this is why I am really hard to live with over the fact that they do NOT have a cleanable filter ahead of the coils. I have had to take a system completely apart to deal with it once, and that should not be necessary.
We had to split the site into 2 different domains, so some images were moved.
