Well don't forget the last time the Mazda 3 was rated in reliablity by CR the 3 was only on the market for 5 months. The average car for 2004 models in CR's last full survey of cars had about 3,000 miles on them. In conlusion, we didn;t get enough data if the 3 will prove to be a reliable vehicle or not. Also, there were A/c problems with the 04 Mazda's. I'm sure Mazda for 05 3's fixed that problem. The Miata which has an above average reliability record by CR and is listed in CR's good bets for used cars is built in the same plant in Japan I think that the 3 is built in I think. The Protege was also built in the same plant as the Miata. In conclusion, I think the 3 will prove to be rock soild reliable.
I also hope the plant in Flat Rock, Michigan that builds the Mazda 6 has the its issues worked out with build quality.
Agreed. This leads to a question that I think many of us have asked ourselves: How important is the country of production to the quality of the vehicle? The Mazda3 which is built in Hiroshima, Japan seems superior to the Mazda6 which is built in the US. Recent studies by J.D Power (link title) and others link title) show that GM has increased its quality levels substantially and become top producer in the US, although Toyota continues to be the premiere car producer in the world. Hopefully one of the other automotive giants, Ford, has woken up and heard the call. Ford needs to follow GM and start drastically improving its build quality. Or putting it differently, is the real source of problems for the Mazda6 its affiliation with Ford?
p.s. several of the top GM plants are located in ... Canada
As far as build quality US vs Japan built well Toyota builds most of their Camry;s in their Kentucky Plant. Toyota also builds the RAV4, Sienna, and Avalon I think in Kentucky.
I think with the 6 the fuel recall and the staining killed its reliability rating. I mean the fuel system on the 03 6 was rated average. The "average model" for 03 rated a bullseye for excellent reliability with the fuel system. Other problem area's that the 6 finshed below the averge 03 model was Paint/rust/Trim with the staining, brakes, and cooling. CR puts extra weight on the trouble sports like Cooling, Transmission, and Engine. To compare the average 03 model go to page 82(CR' April 2005 issue) and then look on Page 89 to compare the average 03 model with the Mazda 6's reliability record. The 04 Mazda 6 which like every other 04 model's reliability record had only 3,000 miles on it at the time of CR's last survey. CR listed the 04 6 as a used car to avoid because it was below average in reliability at the time of the survey. The 04 6 finished behind in reliability with the average 04 model because it had more problems with the problem spot "Electrical" and "Body Hardware" problem spot than the average 04 model did.
As far as Ford impacting the 6's probably during its first year of bodystyle mostly and maybe a little bit in its 2nd year of bosystyle. The 6 was a totally different car than the car it was replacing(the 626.). I mean the 6 probably all had different parts than the 626 did in terms of assembling it. Also the 98-02 626 had mostly an above average reliability record except for one year with the 99 model it had an average reliability rating. Even the 97 626 had an average reliability rating in CR's last issue. The 626 and 6's reliability ratings are on the same chart on Pag 89(april 2005 CR issue.) Yes the 94-97 626(4 cyl auto only)had its tranny problems and it was a Ford Tranny. The 93 626 which is the same bodystyle as the 94-97 did not have a Ford Tranny.
To go more into Fords build quality well CR rates ford okay. The last generation Ford F-150 had as good as a reliability as some Toyota/Lexus and Honda/Acura Products. Ford seems to have work the bugs out of the Focus. For 03 and 04 model years the Focus ranks above average in reliability by CR. The Mustang from 97-04 has an average to above average reliability record. Most people think Ford sucks but perception is not always reality. Its just when you Ford parts in certain parts of a Mazda car it messes Mazda's cars up and I don't know why that is. If you put Mazda parts in a Ford it actually ups Ford's reliability. I don't know why that is either. I should also note Ford struggles with first year build quality. The 2003 Expedition, 02 Navigator, 00 Lincoln LS, and 00 Ford Focus do not have good first year reliability records. The 01 Focus also had a below average reliability record. The Navigator has had reliability ever since the 02 redesign. Its too early to tell if the Expedition will suffer the same fate as its cousin the Navigator reliability wise.
In summary I think by year 3 of a bodystyle the Mazda Plant in Japan and Flat Rock are even keel with reliability. I think year 1 and year 2 of a bodstyle Mazda's plant in Japan is faster at working out bugs in a car. I would never buy a year 1 car(not anymore) but I would probably buy a second year built in Japan Mazda and a 3rd year built Mazda car out of the Flat Rock Plant. I think Mazda's plant in Japan is like Toyota's plants are meaning they are very quick to reducing problem rates in cars.
BTW, I have an 02 Acura CL(second year of that particular bodystyle)and it was built in Ohio. Its been great so far so mechanical problems. I've just had problems with the tires. A relative of mine has an 03 Ford Escape its been fine.
Here are two categories and the areas tested for problems.
Electrical = Starter, alternator, battery, horn, guages, lights, wiring, wiper motor
Body Hardware = Manual mirrors; sunroof; window, door and seat mechanisms; locks; safety belts; loose interior trim; glass defects.
In the case of the 2004 Mazda6 (see CR April 2005) the problem score was in the range of 2% to 5% which is close to perfect; perfect = less than 2% of the respondents reporting problems.
According to Consumer Reports, a car is graded against the CR average vehicle for a specific year. If the car in question receives problem reports from users that exceed the average number of problems it gets rated below average; if the category is critical or if there are several categories in which it failed, the car is rated unreliable. The problems are reported by hundreds of thousands of subscribers to CR. CR is not only important to its readers but also to the auto industry which recognizes it (along with JD Power initial quality and satisfaction surveys and others) as one of the critical assessments of their products. A few years of problems with vehicles gives the automaker a "reputation"; GM and hopefully others have learned that lesson.
Are you asking for specifics like 45 reported= alternator; 22 reported =starter, etc.? If every car's problems were detailed in such a manner the April issue (the annual auto issue) would be a book. :surprise: On the other hand, I agree with you that putting this type of information on the CR website, would be useful. Would you like to suggest that to them or would you prefer that I do that? More of this detailed information could be very helpful for current owners and prospective buyers
Therein lies another flaw in CR's methods. The other is that the reports are based only on those who decide to respond, and then on what the responders decide to report. For example, if a Lexus owner has a faulty fuel gauge and the dealer fixes it promptly with no fuss, and the owner gets to drive a nice new Lexus loaner while their car is being repaired, is this owner going to be more likely or less likely to report this as a "problem" when surveyed by CR? Then there's the question of how the customer's expectations affect what they choose report, or not to report, but that's a topic for a whole other discussion.
Washington (AP) -- Mazda Motor Corp. said Monday it had halted the sale and production of the 2006 Mazda5 crossover because a potential heat buildup in the exhaust system could lead to a fire.
http://www.indystar.com/apps/pbcs.dll/article?AID=/20050927/BUSINESS/509270370/1003
PF Flyer
News & Views, Wagons, & Hybrid Vehicles
The weekly Mazda Club Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
I hear you : these are human beings, with all their foibles, reporting. Because the survey results are anonymous, perhaps the face-saving exercises are reduced. On the whole, wouldn't you agree that it is better to have the actual owners reporting than relying solely on manufacturers claims or some media person whose firm is being paid by the manufacturers?
If Mazda dealers had an avg gross profit in the range of Lexus (almost$5000 per copy) We would have a fleet of Lexi for customers to drive. We would also have somebody to cut hair, do nails, give messages, serve Crystal and cocktail weenies.....Mazda would be on top of the CR charts.
Crossed the big 10,000 mark yesterday. No problems to report in my 2005 Mazda3 hatch!
Meade
No, thats not the way it works. Mazda's reliability records from 1998-2003 were right up there with Honda, Toyota, and Nissan. The Protege, 626, Millenia, and Miata were all above average for the most part during the late 90's/early 00's. As a matter those 4 cars are all listed in CR's " used car best bets lists".The MPV mini-van which is built in Japan was rated above average for 00 and 01 model years. The MPV then sipped to average reliability with the 02 model year. For 03 and 04 CR downgraded the MPV reliability to "much worse than average" because of Transmission issue's.I guess mazda slipped in a new tranny for the MPV in 03 and didn't have the bugs worked out of it. Somebody also said on these boards that there was a software problem with the MPV's tranny. If thats true thats ridiculous though. I mean if the Tranny doesn't break than they just shouldn't downgrade its reliability. That cost a manufacturer some sales if they do that. With Mazda's releases such as the 6 and RX-8 reliability slipped because of first year issues. CR's new issue comes out in what a month and a half so will get a full year report on the 6 and 3 for the 04 model year in regards to reliability.
"Are you asking for specifics like 45 reported= alternator; 22 reported =starter, etc.? If every car's problems were detailed in such a manner the April issue (the annual auto issue) would be a book. On the other hand, I agree with you that putting this type of information on the CR website, would be useful. Would you like to suggest that to them or would you prefer that I do that? More of this detailed information could be very helpful for current owners and prospective buyers"
Yes it would be helpful if CR broke down the problems with a specific "trouble spot" but they don't.
Whats interesting is for the 04 Mazda 6 it actually had more electrical problems than the 03 model when surveyed by CR. Thars interesting because 04 models only had a total of 3,000 miles on them and at the time of the survey the 04 model year was only half way over. The 03 model had an excellent reliability rating where as the 04 only had a better than average reliability mark for the trouble spot "Electrical."
I think the reason CR hit it so hard is because while it wasn't a very serious problem it was quite widespread. I think it's strange that severity doesn't seem to be much of a factor.
-Jason
Actually, I wasn't talking about the reliability records, but the methods used to collect them.
http://biz.yahoo.com/ap/051003/mazda_sales.html?.v=1
Meade
PF Flyer
The Good News:
-It was the 3rd straight month of a sales increase in terms of month to month 2005 to 2004 figures.
-Mazda 3 sales were up 45% last month from september 04 sales.
-Despite the hurricane sales were up by 1000-1100 units last month from september 2004 sales. That shows even during a time of adversity or downturn in the US Mazda can still get some sales.
The bad news:
Yes they couldn't sell 5's for a month
Mazda is getting killed in the mid-size category by Altima, Accord, Sonata, and Camry. Either that or some dealers sold out of 05 MZ 6's during the summer. Mazda only sold 4,307 6's last month.
Mazda getting passed in sales by Kia by 15,000 units.
Also one more thing:
Mazda might want to look at what Honda and Hyundai are doing in terms standard safety equipment in their cars respectively with the 2006 Sonata and 2006 Civic. I think the 2006 Sontata and 2006 Civic are getting standard Side-Impact Airbags and ABS across the board. It took Mazda 2 years to get the MZ6 standard ABS across the board where as the Honda Accord had it with the 03 redesign. You have to keep with your competition and Honda and Hyundai are 2 competitors that Mazda goes up against directly. The MZ 3 is still without standard ABS on both the "I" and "S" where as the Civic gets standard ABS all across the board. I would expect Hyundai to put Standard ABS and Standard Side Impact Airbags on the redesigned 2007 Elantra.
I support safety equipment being made available on all models but not necessarily being standard. Personally, I would opt for ABS and SAB but I have heard others here complain about being saddled with ABS. Providing options allows for choice. On the other hand, providing options complicates the maufacturing and sales processes. The worst case scenario is getting a mix of options like moonroof and ABS, one being cosmetic/lifestyle oriented the other being safety oriented.
I agree. When I was looking at the Mazda3, I wanted SAB. SAB isn't standard, but it was pretty easy to find a Mazda3 with the SAB option (and ONLY the SAB option). As long as SAB is readily available to those who want it, I think it's good for the customer to have it optional, it gives them more freedom/choice and probably helps Mazda's sales numbers.
Now, of course, if SAB/ABS is standard across the board, then the MSRP goes up and Mazda makes more profit per unit. Also, a reduction in the number of build combinations would save Mazda money. So, there are some potential plusses for Mazda if they make SAB/ABS standard across the board. But they're probably finding that a good number of their customers don't want to pay for SAB/ABS...they'd potentially lose those sales by making SAB/ABS standard.
Should we be aniticipating a remodelled Mazda6 sometime soon? Seems like it has been around a while. I am sad that the RX-8 seems to be going begging for buyers now. Yes, it has been around a while too. But everywhere I look, there are screamer ads for this model as low as $22K, and the rebates are running fast and furious now.
The 6 got a very mild facelift for '06 (restyled front end, new taillights, new center console, among other things), and I've heard two different rumors for '07-'08:
1. The 6 will grow in length, width, height (and weight, unfortunately) to better compete with the larger mid-size offerings, or...
2. A new, larger model will be introduced by itself (mazda 9, possibly?) on the Ford Five Hundred platform, and the 6 will continue on, albeit SLIGHTLY larger, on the Fusion platform.
Again, it's only rumors. Nothing concrete yet...
From what I gathered, they are going to create a 6 specifically for the American market. Hopefully, if they do that, they'll still offer a smaller, sportier version. It worked for Honda with the Accord and Acura TSX (the TSX is the regular Accord in Europe and many other markets).
In regard to ABS/SAB- they're now standard on all 3 s models and optional on i models. I agree that they should be optional to help keep the price down, at least on the base models. I don't understand why reviewers and some shoppers complain they're optional when they are readily available. And for those who don't want them- they save $400 or so.
It's great to see sales of the 3 rising. I'm about to add at least one more sale to that number (I'm 90% decided). Rising fuel costs should help them continue to sell well.
One question I do have- I wonder how the new Honda Civic will affect 3 sales? The Civic has been my other main consideration, but I've only been able to test drive an automatic. No dealer around me has been able to keep a manual in stock long enough for me to test drive. Based on the automatic, though, the 3 is the winner in my book. The sportier handling, 20 extra hp and great looks close the deal.
ABS is standard on all Mazda3 s trim levels.
SAB/SAC is only standard on the Mazda3 s Touring and Grand Touring, not the Mazda3 s "base" model.
Yeah, so the stripper Jetta is still more expensive than a loaded 3. I just went to VW's website and "built" a Jetta 2.5 and, after adding the floor mats, aero kit and wheels that came standard on my Mazda3s hatch (which cost me under $17,000), the Jetta came to $24,103. And the 2.5 isn't even the top-of-the-line Jetta -- the Mazda3s is the top-of-the-line Mazda3.
Meade
Now me, I have to have a moonroof and alloys, which is just one of the reasons you won't find me in a Jetta any time soon (would be close to $24,000 sticker, as you suggested), but lots of people don't mind going without moonroof and alloys, especially in the compact class.
Meade
They better be careful about how much they soften that suspension up. They tried to build a soft riding car with the 98 626 and it flopped. They did make changes to the suspension with the 2000 626 mid-cycle refresh but by then it was too late too repair the damage of the first couple couple years the last generation 626 had with the soft suspension. Even consumer Reports didn;t like the 98 626 as much as the 93-97 626. CR did however like the changes Mazda made for 2000 with the 626.
"From what I gathered, they are going to create a 6 specifically for the American market. Hopefully, if they do that, they'll still offer a smaller, sportier version. It worked for Honda with the Accord and Acura TSX (the TSX is the regular Accord in Europe and many other markets). "
No I don;t think Mazda will make a smaller car to slot in between the 08 6 and the Mazda 3. That would be like Ford did in the mid 90's when they slotted the Contour in between the Tarus and Escort and the Contour flopped.The same thing would happen in my opinon if Mazda slotted a 4 door sedan in between the 6 and 3. Their best thing to do would be to bring the MX-6 name back and make a 6 coupe sort of like Honda makes an Accord Coupe but to do this Mazda would have to differentiate the 6 and a coupe model of the 6 in terms of styling and the coupe model 6 having a slightly sportier ride than the sedan version of the 6.
"In regard to ABS/SAB- they're now standard on all 3 s models and optional on i models. I agree that they should be optional to help keep the price down, at least on the base models. I don't understand why reviewers and some shoppers complain they're optional when they are readily available. And for those who don't want them- they save $400 or so."
Basically with the ABS Honda has made it standard on all their models. Anytime Honda does something the rest of the Japanese makes have to follow like it or not. Toyota was forced to make ABS standard on their whole entire Camry line for the 04 model year I think because Honda made ABS standard on all their entire Accord line. Like I said before Mazda was also forced to make ABS standard on their whole entire MZ6 line for the 05 model year. Its good to see Mazda making ABs standard on the "S" model trim of the 3 in order to keep up with the well equipped 2006 Civic. Finally, I wonder if the 2006 Toyota Corolla will have standard ABS on any of their trim levels(CE, LE, S, XRS.) BTW, I wonder how much the price increase is for the 06 3s models considering they are coming standard with SAB and ABS.
Would you like to supersize that order???
Seriously, Ford took the platform, kept the good stuff (hadnling/dynamics/steering feel, and just made it a bit roomier, and quieter I think. basically kept the Zoom Zoom in a package that better competes with the CamCOrd in size and comfort.
Any bigger than the fusion, and it will have to be a whole new big car IMO. Maybe a new 929 off the 500 platform?
Hey, Mazda used to have 3 distinct platforms/sizes (929/626/323), why not do it again? They can either upsize the 6 and slot in a new car below the 2, or pull a Honda and upscale the 3 (4?) to make them fit. COuld also keep the 6 and add a whole nother unit up top, but I agree that it wouldn't like sell too well. Mazda peopple would either go for the 3 or the 9, not the 6.
I bet they did too. If they didn;t soften up the suspension though Ford does a good job of taking the best from their other car companies that they have an interest in(Mazda and Volvo) and using them in their own products. Case in point: the 500 having Volvo underpinnings and the Fusion having the MZ 6's underpinnings.
Did you test drive the Fusion at a Ford dealership?
"Would you like to supersize that order???"
"Seriously, Ford took the platform, kept the good stuff (hadnling/dynamics/steering feel, and just made it a bit roomier, and quieter I think. basically kept the Zoom Zoom in a package that better competes with the CamCOrd in size and comfort."
Yes and no I agree with you. Maybe Ford did take the 6 platform for the Fusion to better compete with Honda and Toyota but at the same time when Mazda comes out with a new 6 the Fusion will be based on older technonlogy since the 6 will get redesigned for 08. Ford has to wait till 2011 to release a new Fusion so be time they release a new Fusion the so the current 6 platform will be aged be time a new Fusion comes out. I wonder if the 08 6 gets its own platform from Mazda or shares one with Ford.
"Any bigger than the fusion, and it will have to be a whole new big car IMO. Maybe a new 929 off the 500 platform?"
I don't see your any car bigger than than the Fusion that it has to be a next generation 929 theory. The Altima and Camry are still roomier than the current the 6 and the 6 still has growing up to do in terms of interior room. With that said though the current 6 does have a good amount of interior but not up to Camry, Altima, Sonata, and Accord Standards.
"Hey, Mazda used to have 3 distinct platforms/sizes (929/626/323), why not do it again? They can either upsize the 6 and slot in a new car below the 2, or pull a Honda and upscale the 3 (4?) to make them fit. COuld also keep the 6 and add a whole nother unit up top, but I agree that it wouldn't like sell too well. Mazda peopple would either go for the 3 or the 9, not the 6."
Yes they are going to upsize the 6. A Mazda exec said that last year in a Wall Street Journal article that they need model that fit the North America or American tastes more. The 2 is a sub-compact car or an entry level car isn;t it? I know Mazda has a challenger to the Honda Fit and Scion TC in the works in terms of an entry level car but I forgot if the 2 is a Aztek or Element type of vehicle or if the 2 is a supcompact. I hope with Mazda's styling DNA it will look a whole lot better than the Aztek and Element came out. I lost my magazine with all the future models in it. I think I threw it out. The photo I saw in the mgazine did look like a Scion XB, Aztek, or Element type vehicle.
"Mazda peopple would either go for the 3 or the 9, not the 6."
Why would they buy the 9 considering a 9 would be esentially a replacement for the 929 and Millenia that failed before? An entry level luxury car Mazda is not ready for in my opinion. One they can establish the 6(which they haven;t yet) as a Camry, Accord, and Altima fighter they would be ready to put out a 9 in my opinion. The 9 would be a Hyundai Azzera(now XG350), Avalon, and Maxima fighter.
I don't mean to be hostile with this post I;m just replying.
Another idea, would be to bring the excellent 2.0 common rail diesel that they sell in other markets. It makes 134hp and 228lb-ft of torque, strong numbers. It would make a great addition to the 3, 5 and 6 models. It would be an amazing opportunity for them to be the only Japanese automaker to offer a diesel. Alternative fuel vehicles are hot and most analysts think they will continue to be. I know I'd buy a 3 diesel...then again, I'm about to buy a 3 anyway.
It is impossible to not get some on your hands (many diesel drives carry gloves) - go look at the ground next to the diesel pump - it will look like an oil spill - because diesel does not evaporate as fast as gas - so you will also get it on the bottom of your shoes - it smells real bad. Once you get it on your hands & feet it finds its way to the inside of your vehicle - and then on your clothes - you will be in a meeting (at work) & someone will say - whats that horrible smell?
I know several people who have diesel vehicles - they love them - would never have anything else - but know the down side before you buy one.
Also - don't forget that a diesel will cost THOUSANDS of dollars more to buy - and it is also (normally) heavier that a gas engine. Most 3/4 - 1 ton or larger truck owners don't care that much about an extra 300 pounds - but an extra 150 pounds in the engine bay of a Mazda3 would have a very negative impact on handling.
Diesel is $3.50 a gallon in Houston - reg gas $2.74 - but even if I assume they will cost the same $3.00 a gallon how much will you save?
100,000 miles at 40 MPG (diesel) = $7,500
100,000 miles at 30 MPG (gas) = $10,000
So you save $2,500 in fuel - and just about break even on total cost.
If you ever have an engine problem out of warranty get ready to pay extreme amounts of cash to get it fixed.
If I was buying a heavy duty truck to pull a large RV SEVERAL TIMES A YEAR - I would look at a diesel - but for a small car I will take gas every time - and I don't care one bit what they do over in Europe.
