Anyway, I can't get the spare tire back in due to the hitch. Anyone else run into this and if so, what did you do? I am contemplating taking all the air out and seeing if it will fit back in. I hate to do that, but I don't see if I have any other choice.
The car is equipped with 19" rims. I think a 17" spare would have fit fine.
P.S. Just found this forum and it is great. Keep it up. Thanks!
I have tried to read the board, but since some of the posts are so old, I thought I'd ask for help. Same story - we have a 2006 Pacifica that we need to add the screen for. It has the player in-dash.
What is the least expensive way to get this done? Is the wiring harness there, or not? Also, does anyone know how to remove the trim piece next to the windshield?
Sorry for all of the newbie questions, and i really appreciate any help.
Mark
Any help with the same questions as post #819 would be greatly appreciated!
Sincerely,
-JW
Well, the easiest way to find out if you have an amp is to look in your trunk, If i remember correctly, the amp is located under the last row of seats in the pacificas made in the first half of 2004, and located in the VERY back of the trunk against the right side under the hatch door. Theres quite a few threads in the archives about if a wiring harness will work with the CD changer or not. That was a big arguement...lol
The nav should have nothing to do with the stereo, I have a custom stereo in my ride and the nav has its own speaker on the dash for the voice. I didnt have to use any special wiring to keep that working. Thats all the info I have.... good luck.
1 - X114 20GY/TN - FUSED B(+)
2 - X211 20YL/GY - IGNITION RUN/ACC SIGNAL
3--
4--
5 - X915 22GY/LB - VIDEO CONTROL
6 - X515 22GY/OR - VIDEO SIGNAL
7 - X530 20GY/DB - VIDEO RETURN
8--
9 - X555 22VT/OR - VIDEO PLAY SIGNAL
10--
11--
12 - X955 22 - SHIELD
I did this myself, but if you are not one who works on your own car, then your installer will know how to do it.
About the NAV, that system is totally seperate from the radio system, one doesnt effect the other. You wont have to worry about that. Sorry about the changer though, I MISS IT TOO......
Post some pics in your profile.....
Where do I go about buying the correct wiring harness for it or can I some how get around that? I've been told around $190 and it may or may not let me keep the DVD and Nav! I really just want to put a CD player and amp and a pair of 12s in my Pacifica for now.
Thanks for all your help. I can't wait until my sounds get put in!! I wished you lived around me so we could meet up because no one seems to really know what is really good with this car.
I know it is possible to install and still keep all features except the CD/DVD changer (due to size problems not compatability issues). The only think I have been able to drum up is several single din kits. I don't want to abandon my double din dreams for a weaker flip out model that will burn up it's motors within a year.
If anyone has any info PLEASE POST.
You can email me at
Matt_Keenum@ Hotmail.com
Pacifica 06 has dvd changer but no screen. I found this link http://starparts.chrysler.com/info/default/k6858779.pdf that shows how to do it with the factory dvd, which I have, but where do you get the wiring? how much is the wiring? I need all the installation kit I guess. Does anyone know where to get it?
I called chrysler parts and they are either not sold or very expensive.
If there's another screen I can get that is cheap and easy to install and works with the factory dvd changer, please someone share...
Thanks!!
well i hooked every thing up and used an extension cord, for now.... to power the ps2. so when i turned the ps2 on the screen never showed anything.
the only time i ever get the screen to show anything is when i put a dvd in.
Somebody please help me. Im bad lost!
I'm not sure if the jumper harness is installed (didn't know that was a possibilty until after reading these) Is this the only fix for this problem?
Thanks in advance
Regards
