Maybe over the years the GM had a better track record, although I think the methodology for testing vans has also changed. The old Toyota vans may not have done well, but that has certainly changed. What is odd, is that if the GM vans did do well, either when they last redesigned them, they were poorly redesigned, or the crash testing results got tougher. Either way, what is important as a new van buyer, is how does the new models fair?
And with that, the Sienna fairs well, and the GM doesn't. Hopefully this new Uplander/SV6 will address these safety concerns, and I would wager that they will score better than they had in the past. Whether they score as good as the Sierra remains to be seen.
I guess I do care about the safety record, but the single crash test is indicative to me of how safe the vehicle is. In the testing done by IIHS, the Sienna scored well in their testing. That to me, makes it seem safer, than a vehicle which scored poorly in all categories. In other words, I do equate safety record (of the current model year, not 10 years ago) with how it does in a crash testing. Hence my original feeling that the Sienna is safer then the GM van. Sorry if this sounds confusing and misguided.
In their September 2004 (most recent report)covering model years 2001-2003 (before the most recent Sienna redesign), the IIHS rates the Montana as "substantially better then average" and the Sienna (with a 37% higher rating) as "better then average". This continues a "record" of GM's vans scoring better then Toyota.
As far as the current versions of each car. In NHTSA frontal crash testing, the 05 SV6 and 05 Sienna scores are simular. And while they haven't done the side crash test on the SV6 yet, the new 05 Sienna is a close match for the old generation Montana.
The new GM vans are designed to be an improvement on the previous generation's excellent "record", (as opposed to a single crash test "rating"). And with standard DVD and OnStar, GM has designed them to have the most rounded safety package available.
I understand your point, in that you are looking at the overal track record, hence time. I am simply looking at what scores are available for the current model being sold. Even if it is just ONE test, the one test tells me that a) the Sienna aced it. Not statistically accurate, but doubtful that they are going to test 50 vans, and most likely with the same exact test they will score similarly, and b) the Montana didn't do well on this one test. Same "logic" as applied above, if it scored poorly here, most likely the same test 49 more times it won't have scored much better. Not scientifically accurate I know.
You keep mentioning the older Sienna (which still scored better than average)but I am not concerned with this model, as I am not buying it, or the older Montana.
The report I read, did not say good things about the Montana, but your reference says it scored substantially better than average. Seems like the IIHS is contradicting itself somewhat.
My (overall) point is that as a consumer, I am looking at all sorts of data, included the brochures, Edmunds, opinions from owners, as well as CR, and data from IIHS. I can't and won't spend all day looking at this data, I simply want to know how they view the current model offerings, and the Sienna scored the highest, while GM did not. That's my story and I am sticking to it!
True, the older style vans did not do well on "offset" head-on "test" crashes because of the foot area. The newer vans that are the subject of this discussion area have significantly extended noses and likely other changes that should provide excellent crash results with offset head-on crashes.
For me, the excellent antilock, front and side airbags and traction control on my older van make it the safest vehicle I've owned. The new GM vans should be even better for crashing, if that's your thing.
D
The old Venture/Montana/Olds Sil were odd ball in the way GM designed their vehicles in recent history: Low weight at any cost! They made a dumb mistake by making these vans "global vehicles" so that GM Europe and GM US can sell variations of the design. It sounded good on paper, but in practice, there were too many compromises made. One of the worst ones was "shaky" body integrity. They skimmed on body re-enforcement in order to lower vehicle weight. As a result, these vehicles shaked and rattled even when they were new. I am the proud owner of 97 Olds van when it first came out. Over the years (97-2003), I noticed GM has made some improvements in this area. But they were minor only. BTW, bad body structure is always proportional to bad crash test results
Now on 05 Uplander, I believe GM actually has beefed up the vehicle structure substantially. They add 200-300 lbs to the vehile. So, I suspect the new vans should be a different animals.
JT
I took it to the dealer and they couldn't find anything with their diagnostics. I told them that the problem did not start until we filled up van with gas from Sam's. The dealer put a gas additive in the fuel which helped. I have since done some research on the web about gas, and all the major gas companies, shell, phillips 66, mobil, chevron, amoco/bp, marathon, sunoco, put performance and cleaner additives in their fuels, but the off brand companies, speedway, citgo, sams, walmart, etc. do not. We will see if this is true as we are now ready for another tank of gas and will probably go with shell.
After running a couple tanks of shell through the engine, the problem still persisted, so I took it back to the dealer. They did every diagnostic that they could do and couldn't find anything wrong. They then worked with the GM engineers, sending them data and pictures of the inside of the cylinders, and still no solution. Finally GM sent a field engineer to the dealer with his equipment, spent a half day on it, and gave up.
The dealer then told me that the vibration was just inherent to the Uplander, Terazza, Relay, and SV6 control systems, as all the vehicles on the lot exhibited the same problem to some degree. They then told me to look for a service engine light or bring it back if the problem gets worse. Apparantly I was the first to complain about it, and the problem in my vehicle was more noticeable than the others on the lot. In fact in some vehicles, it would probably go unnoticed, unless you were looking for it.
The night after picking up my vehicle, I noticed that the vibration also occurred at higher RPM's right when the vehicle starts rolling from a stop, and then goes away. I produced that incident by driving up my inclined driveway very slowly. The engine speed was about 1200 RPM when the vehicle started to roll and then vibrate. I tried to reproduce the vibration with the transmission in reverse, but could not.
If you own any of the 2005 GM minivans, please look for this problem and then complain about it, so GM will address the issue.
Also, a common complaint with these minivans is that the interior and head lights flicker, and there is a whining noise upon engine acceleration that might be a problem with the alternator. This problem might also be tied in with the vibration. Unofficially I have heard that GM is coming out with a fix for the alternator, but my dealer knew nothing about it.
http://www.relaytraining.com/PDFs/RELAY Product Guide.pdf
Full Test: 2005 Buick Terraza CXL (Inside Line)
They should be decent though.
What sort of $$$ we're they looking for at this point?
http://www.nhtsa.dot.gov/ncap/cars/3062.html
tjhsmith : Crash tests look pretty good so far. looks like only some have been done so far.
1. Headlights / dash lights flicker - Response -IT WAS DESIGNED THAT WAY.
2. Voltage varies between 12.1 & 15.2v while driving at highway speed - Response - IT WAS DESIGNED THAT WAY
3. Instrument dial pointers do not light when manually turning on the lights - Response - IT WAS DESIGNED THAT WAY.
When I asked if the power issues were the same as previously resolved on the Montana - Response - COMPLETELY NEW TECHNOLOGY.
So, I guess if you design it that way you will never have to repair it, because it already does that
Our 2004 Montana has no such issues after 10 months of service.
And the 2004 Montanas (whole previous generation for that matter) does not have the same charging system design as the new 2005 generation. The 2005s use a regulated voltage control system that will vary alternator output based on operating conditions and battery conditions.
Only incentives were 1.4% for 60 months or 0.5% lease rate for 36/48 months. No cash at all, but the dealer was willing to take off about $2500 with out me asking. List price was in the low $30K (Canadian) range I believe. It had remote start, On Star and big alloy wheels. Looked great.
Still considering it though we are not 100% a van is for us right now.
4,654 kms (2,909 miles) - 53% remaining.
I operate in what I would call severe duty climate - frequent remote starts, sub-zero temps most of the winter, 50/50 highway city driving
What are other owners seeing?
I'm working on her though. I like the standrd MP3 player, I can burn all those songs I have on my computer and listen to them!
Mostly highway. 40% towing a trailer
Looks like this reinforces my thoughts that these vans will go about 9,000 kms or 5,600 miles between oil changes. GM has warrantied these to 100,000 kms at that oil change interval. Kind of blows the theory of 5,000 km oil changes out of the water. (assumes most modern engines have similar oil specs)
This huge oil conservation news.
The advertising has us changing oil twice as much as required.
However, the flickering issue is there, but appears to be lessened after a recent service visit for that complaint amongst other minor points.
Personally, if this is your first oil change, I would change it at 3000 miles, then rely on the oil life indicator afterwards especially if you are driving under severe duty climate.
Just a thought.
I think I'd escalate it up the chain; maybe a letter to the CEO is in order (or maybe you have one of those "on your side" TV shows in your area?).
Why would you call GM direct on a problem like that though? The dealer would fix that.
In contrast, my '88 Dodge Shadow had a 125 amp alternator that I drove for 13 years and I never touched the alternator, same for my Dad's 1970 Toyota, etc. Large diesel tractor trucks have alternators that last about over 500k or aboutu forever, just need brushes, so clearly this is an issue of trying to save $1.50 on parts and it causing problems.
As a GM fan, its disheartening to see problems that could be easily fixed persist.
DD
