I find it difficult to believe that an exhaust odor is coming in from the sunroof. Do you get this odor when parked in a garage with the engine running. Do you smell it under the hood?
Anybody came across this issue?
I have an 2003 Denali and now the speedometer starts at 50 mph and won't go below that. Also the check stabilizer light keeps coming on and off and the dealer says they can't find anything wrong.
I had this same problem so I took it in to the service dept. where I bought the car from. The service manager first tried to tell me that the the rear heat and A/C would not be the exact temp in the rear as in the front. I proceeded to tell him that if my children had to dress like eskimos just to ride in the back thae they could have the car back! So he finally got his little temp. gauge out and went to check it out. He told me that it needed a new actuator and that they would grease the assembly that opened and closed the vents. I hope this will be of some help to you.
go down any & did your engine light come on? Mine is idle low & sounds like it will stall but never does. I keep getting a code of Lean Banks. Thanks Bryan
thank you for the reply. How much did they charge you to get this fixed? i am already over warranty.
Thanks again!
Hiten
I am new Denali Xl owner, my front passenger headlight went out. I checked under the hood to replace, and I dont know if this is a DIY or should I take it to the dealer. It looks like I have to remove the whole headlight assembly.
I hope not. (TIA) Thanks in Advance for any help you guys can provide.
Dealer tells me its either a full tranny replacement or seals ranging from $1200 to $2600 for repair. This is an 2003 with 58k miles.
With as many problems with the trannies on these vehicles, is anyone having any luck getting $$ from their dealers or GM???
Thanks in advance.
Any ideas?
I have and 2003 Yukon Denali XL and when I press on the brakes and vehicle starts to slow, I hear a clunk. It does not always happen but I especially notice it when stopping at slow speeds. It does not clunk immediately after I push on the brakes but more as the vehicle nears a stop.
I don’t think it is ball joints or the abs system, anyone else have this issue are any thoughts on the matter?
Regards
After calling a couple of people and taking their advice, to turn the wheel and try turning the ket at the same time might work, still no go. The steering wheel is not locked,(problem), any sugestions.....????
Tom Bastian
Tom">
I will not in a week or 2 when the part comes in and is installed I will keep you posted.
The bad news is it will start to always read zero or just bounce around a little.
If it is like our '04 DXL it will just stop working.
We were told "It has happened to almost every DXL we have seen ..." cost estimated at about $400 and TEN DAYS to fix. remove, send off fix and replace.
Anyone have any informatin on if this is a recall or not?
Jim
