Buick LaCrosse
Do not listen to him. Changing oil at 3000 miles is a waste of your money and oil. Remember the dealers are independent from the OEM (GM in this case) and want the service dollars.
Now, not sure why you have low oil but oil life system has nothing to do with oil level. The oil that is left is perfectly good for another 3000 miles or so (oil life said 55%). Need to figure out why oil was low. Could have been as simple as there was not enough oil put in at last change to something mechanical.
Bottom line is you got it in under warranty and do not le the dealer blame the not changing of oil as a reason for not fixing it.
That's exactly what I told them (I followed GM recommended oil care with OLS), they topped up oil level and now less than 1000 miles later is 3/8 above minimum level already. There is no signs of oil under the car, not a single drop. It is just burning oil...I used to add a quart between oil changes (6K) until the last one. Now it seems quite serious.
To be honest 750 vs. 1000 idle sure is not much. Amazed it was noticable.
Anyway the dealerships are independent from Buick. Go to another dealer.
This week, I took the vehicle in for normal service; asked them to check around the power steering for leaks; none found and the fluid level was still correct.
http://www.micronair.us/General+Motors/141
The service the ABS light and Traction control light come on intermittently.
One GM dealership said the the tire pressure was low and that was the cause of the problem.
I was not satisfied with that answer, so I took the car in to another GM dealer. The dealer replace the speed sensor control. The problem stopped for awhile but it is now back.
Also the front brakes "grab" and "grind" intermittenly. The dealers also say that the brakes are in good shape.
any ideas what causes this or who can successfully trouble shoot the problem.
It may be an educational exercise for you to start a spreadsheet for out-of-pocket expenses you pay for the various services/repairs etc.
As for buying the extended warranties: they ain't cheap, even if you pay "just" $200 over the base price. Warranties are insurance policies whereby you pay up front for anything which MAY go wrong with the vehicle. If nothing goes wrong, you lose the bet. IF you are in the financial position to "self insure", you may want to consider this option instead of buying another warranty. Self insure: you have a couple of thousand to spend on repairs without it creating a hardship.
We really like our 2005 LaCrosse CXS. We have taken it on several very long trips and it is a comfortable ride. Initially, we had to deal with a nasty water leak which soaked the passenger side flooring but after we (FINALLY) got that fixed, it has been clear sailing since then.
Still loving my 2009. Nicest car I've ever owned.
Last week I discovered the issue and that I had been fooled by the location. The center dash air vents each have a roller wheel that controls whether or not the vents are sending full velocity of air to the passengers, are closed entirely, or somewhere in between. The roller wheel controls go to the top to open the vents entirely, but there is a detent and if you push it thru that they lock into the full open position. Mine was at the detent but had not been pushed past it. For some reason that was the cause of the rattle. I could roll the wheel down slightly and the rattle would disappear, or push it past the detent into the full-open locked position and also lose the rattle. It was just that one spot where it rattled. I felt both relieved and a bit silly to think that I had feared this rattle would drive me nuts for years. Hope this helps.
Sometimes, in a situation like that, it could be as simple as the person getting out and the metal latch on the seat belt resting up against some plastic trim. You got in, and just by brushing up against the seat belt moved it, and no more rattle.
I have an answer for you. I was able to duplicate it with my dealer. Apparently GM/Buick is aware of the problem but does not have a solution just yet. Ask your dealer to look up #PI0172 (thats a zero). When I took my LaCrosse in they added more power steering fluid (above the full line). It helped reduce the instances of the noise. The way I was able to duplicate it was making a sharp left turn then with a sudden stop, putting the car in revers and turning the steering wheel to the right. I know its a little confusing but it worked for me. Additionally, there is a Document ID with the notice: 2498553. They should be able to look that up. YOU ARE NOT ALONE!
Check my posts. Several others have the same issue. :mad:
There are 2 issues with the steering; the one you described and the one where that fix doesn't work. Both issues are descrbed in GM's technical write-up.
Please post the dearlers name so I can check myself.
That is to raise front end and slowly turn steering from limit to limit several times, engine running.
"I have an answer for you. I was able to duplicate it with my dealer. Apparently GM/Buick is aware of the problem but does not have a solution just yet. Ask your dealer to look up #PI0172 (thats a zero). When I took my LaCrosse in they added more power steering fluid (above the full line). It helped reduce the instances of the noise. The way I was able to duplicate it was making a sharp left turn then with a sudden stop, putting the car in revers and turning the steering wheel to the right. I know its a little confusing but it worked for me. Additionally, there is a Document ID with the notice: 2498553. They should be able to look that up. YOU ARE NOT ALONE!"
My dealer is Thorson Buick -GMC in Pasadena CA. I also contacted Buick Customer service. They too are aware of the problem and gave me the same line that the "Buick engineers are diligently working on the problem." Good Luck!
The center caps are strictly cosmetic. If they have come off, it's because someone didn't put them back on correctly.
Uneven tire wear may be caused by front wheel bearings, but it is unlikely, and that would only affect the front tires anyway. Front tire wear would be caused by worn suspension parts, like ball joints, control arm bushings, that sort of thing. The only way that all 4 tires would be worn would be due to poor alignment and lack of tire rotation. If they are the original tires, they would likely have been worn out at 40,000 miles regardless.
That leaves us with the front wheel bearing issue. They have been known to be a problem on this car and other similar GM chassis, so the question is, what symptoms are you experiencing? If they are worn, do not get the dealer to replace them. Have the work done at an independent garage you trust. The cost will be much less.
