Can I replace the 2006 radio with a 2007? Dealer says no, but I'm looking for another opinion.
-mike
I think that's how it works.
If you are referring to an aux-in, it can be installed on any of the 05-06 Legacy/Outback radios. Check out:
http://www.jazzyengineering.com/
I had one of these kits in my 05 Outback XT and it worked great (and was only $25 back in 2004!). The sound quality was excellent. Stay away from the RF modulators and transmitters, which pipe in sound over FM. The dynamic range and the sound quality is not good at all (it is better than nothing, but as we know, FM quality is not that great).
-mike
kmclean, "Subaru Legacy/Outback 2005+" #9576, 30 Nov 2006 12:25 pm
Fourth vote for a pebble. Had that happen to me last summer - sure got my attention. Stopped the car (no effect on braking noted), backed up about 20-30 yards or so, that solved the problem. I assume the reverse motion helped back out the pebble the way it came in.
The last week here in Fairbanks was 80+ degrees most days, so I gave it a work out. I agree - I think it is weak. It works fine for 85 degrees, but it keeps the car at *just* comfortable going full fan and on recirculate.
The problem is that it does not run on full cold continuously. It will get extremely cold for about 5 seconds, then it is cool for another 5-10, then extremely cold again. If it stuck to extremely cold, it would be excellent and I would actually need to turn the fan speed down to keep the car at a comfortable temperature.
Now, were I to take it to Eastern Oregon again in August with 100+ degree days, I think it would fail miserably. Or maybe it would just fail and I would be the miserable one!
There was a fella here a couple weeks back complaining about the A/C on his car in Georgia. I can certainly see his point now.
It may be more effective in the sedans (which have less air space and fewer windows). It is not bad, but it is not great either.
I agree that the CR-V's air conditioner was much cooler and was able to get the car really cold, really fast. However, I've had no problems with either Subaru's air conditioner (The 2.5i has the standard AC, the 3.0 has the temperature control). It's not as strong, but still effective.
Overall it's a relatively minor thing. The Subaru is a much better car- I've owned 3 Honda Accords before the CR-V. I'll probably stick with Subaru for a very long time.
We've tinted our Outback and Legacy (just a medium tint, nothing really dark), and have absolutely no problems with the car cooling. $250 should do it. Don't go with cheap tint or a cheap shop... with tinting, you generally get what you pay for.
I've been planning on getting the Outback's windows tinted- the Subarus on TV commercials and catalogues look cool with them tinted, not to mention what you said about helping to keep the car cool.
I still have to work on my wife. I think she doesn't want the tint because then she can't wave at her friends when she drives!
See more Car Pictures at CarSpace.com
The 20% would look nicer, but I felt it would be too dark.
Mark
We have 35% on ours, too, same reasoning... plus 35%'s the legal limit here. We had ours done in a subtle bronze color (can look pinkish if it's 20%, though), which I think works well with the ivory interior and allows warmer-toned light into the cabin, which I like in my often gray corner of the world.
3.0 L outback ?
What ticks me off with this system is that I had to crank the climate control to 25.5 celcius (80 degrees F) just to get the AC to run so that wasn't freezing my arms off. Geez...I get enough cold during our winters!!!
Other thing that irks me, and not sure if it is still a problem on current Soobs, but if I want fresh air (no AC) coming in thru the vents and set the climate to lowest setting (ie 18 degrees C), the system blows out HOT air! This is especially true if the car is motionless while the engine is running a while. Frustrating.
-mike
http://www.cars101.com/subaru/airfiltration.html#00-04legacy
Also is there a instal kit for a new deck. I've had people tell me that there isn't and they have to fabricate one. :confuse:
It takes a little work, but you can do the install in about an hour. Perfect connection with no loss in sound quality. I use it with my iPod and Sirius deck. Get the ground loop interruptor if you plan on using it with sat - not really necessary with the iPod unless you use the car charger (it can introduce some alternator whine).
I would suggest doing the jazzyengineering thing on the OEM stereo. That's what I plan to do on my 05 LGT.
-mike
I need some help. I'm planning to buy a legacy 2008 and I wanted to know if I will be able to have an amplifier in the car without changing the stereo.
martin
-mike
So, that points me toward the XT Limited with 5speed. Some questions:
- Does the 5speed receive the SI Drive with it? I can't see that it would be necessary but I see it listed as standard.
- Does this have VDC? Again, I have seen it listed here on Edmunds as Std, but on other sites Std only on the Auto.
- Anyone out there have one? Even here in NH, they are hard to find on the lots! I wonder if I will ever be able to test drive one before ordering it. The local dealership in Exeter, NH has an Auto XT.
My dealer here in Seattle has 8 XT Ltds in stock w/manual tranny, by the way. You can use subaru.com to search inventory (by state, I believe).
The 6-cyl has smooth, continuous power delivery, the turbo has more peaky power and delivers more gut-wrenching "oomph". Fun or smooth, they're both good engines. Sounds like you've got smooth covered with the Lexus, so the XT Ltd might be fun for you!
You may be able to find a Forester XT Sports with a manual tranny to test-drive. It'd give you a good idea of what the Outback would feel like, performance wise, though the Outback would be a touch slower (it's heavier) and ride smoother than the Forester.
SI-Drive's "intelligent" mode is good for driving in slick conditions & for improving fuel economy when you're just toolin' around town. Pulled this from Green Car Congress website:
"The SI-Drive controls the electronic throttle system’s response and fuel and ignition curves to modify engine torque characteristics, changing the performance character of the car in each mode.
With “Intelligent” mode selected, the system reduces engine torque and maximum power and switches to a more relaxed throttle response curve. Intelligent mode is an ideal choice for smoother response while commuting in traffic, for example, where it can also help boost fuel efficiency by up to 10%, according to Subaru.
Intelligent mode’s more relaxed responses and lower torque output complement the low-traction surface driving safety provided by the Subaru Symmetrical All-Wheel Drive System.
When “Intelligent” mode is selected in vehicles with a manual transmission, a shift-up indicator blinks to signal the optimal shift point for maximum fuel efficiency.
In “Sport” mode, the performance of the 2.5 GT spec.B (and other 2007 turbo Legacy and Outback models) is similar to the 2006 model, with quick throttle responses and powerful, linear acceleration. The linear acceleration characteristic of this versatile mode makes it ideal for driving on freeways and suburban streets or for climbing mountain roads.
In “Sport Sharp” mode, SI-Drive modifies the engine’s electronic throttle mapping to deliver lightning quick throttle response and more power sooner."
On the automatic models, SI-Drive also changes the transmission's shift pattern.
I have researched the dealerships in my general area- between NH and ME and I found only one XT with an Auto transmission. I just have to broaden the search and keep looking as they are stocking up on the 08's right now.
Yes, it will be fun to have the gut-wrenching oomphh of a new car. My trusty Outback is great but never going to win at a drag race
Last week the turbo unit blew up and the car now sits at the dealer waiting for Subaru to find a new replacement (it has been 10 days now and they haven't yet located one). It will be covered under the warranty (barely) ... he still has the option of buying the extended warranty (which I am pretty sure he will get). Call this a lesson learned.
I urge you to go into the turbocharger option with your eyes wide open.
DB
Furthermore, your words "rocket" "blew up turbo" suggest to me that your buddy has a bit of a lead foot (presuming he has owned this car from new), which would certainly influence mileage, and longevity of any car, regardless of turbo or not. My turbo has performed flawlessly for almost 3 yrs now...then again, I don't drive like I'm in a F1 race either.
My only gripe about the turbo is a persistent "hesitation" issue upon acceleration. I think this was a symptom of some 05s and 06s. It's never worked itself out for me, even though I understand it has for others.
Wow, for all the modified LGTs and WRXs (and DSMs) in my peer group, that is the first time I have heard of any kind of issue like that with the turbo.
Glad it was under warranty for your buddy! Whew! (I'd probably get the extended warranty at that point too, if that happened to me.)
I have seen that the gas mileage is not too good for the XT. Plus, I just read it takes only premium fuel. I currently work from home so right now, the driving will be easy and won't have to get gas too much. I am in sales, so it could be different tomorrow.
I guess I would consider the 4 cylinder manual- but are they actually offering that in the Limited or LL Bean edition?
The XT is his wife's car, so I think you can rule out any F1 driving techniques. It is a 5EAT so it is (at best) difficult to wind it up. Most of it's miles are on long highway trips in the northwest. I choose to think it is just a random failure, but I am puzzled by the difficulty in finding replacement parts.
This reminds me of the turbo failure I had with one of Volvo's early turbo models. I got to replace its TC with no help from the manufacturer. After that experience, a TC was of little interest to me.
DB
Think about it - the STI makes 300hp, so that's what the block is designed to handle.
If you drive a typical amount (say 15,000 miles/year), premium fuel will only cost you about $250 extra over the course of a year. More of a psychological effect than a burden on the pocketbook, but yes, it is a little more cost. All Subaru's turbo models require premium fuel.
Subaru recommends premium on the 6-cylinder, but does not require it. (I heard they were going to drop the recommendation, but I haven't been able to substantiate that). It won't void your warranty or damage the engine to use regular unleaded in the 6-cyl. Some folks have reported mildly reduced power and fuel economy using regular unleaded, however, so your cost may end up the same whichever grade of fuel you choose.
A 6-cyl manual LL Bean might be nice for you. Still good power, you get to shift on your own, there are plenty of creature comforts, but you don't HAVE to put premium in. Or, give up on the manual transmission & go with a 4-cylinder for better economy. Lots of options, just no perfect option, eh?
There is no such beast, is there? I think the 6-cyl OB's only come with Autos.
As an aside, I have an 06 3.0R. I have a significant hesitation when I really get on the accelerator if I use 87 octane gas. I now use 90+ octane even though it is not required since it gets rid of the hesitation.
