Nissan Quest 2004+: Problems & Solutions
As some of you may know (or just look at my posts) my Q has been plagued with rotor issues. Finally I said screw it, Im installing these performance rotors. All the quests have Disc's BTW. Up until this point my dealer has performed all work on my brakes for FREE (BTW, Lynnes Nissan West,NJ Great Svc Dept) which included ROTOR replacement twice. Alas, I dont see any point continuing with the OEM crap, so I went with the frozenrotors which essentially are warpless. For me its worth the $, as opposed to the agrivation of going to the dealer constantly. At some point after the 50K extended warranty im on my own anyway.
dtownfb - I dont know the actual size of the rotors for the rear, but they are different to the front ones. You can look them up at www.frozenrotors.com.
Interesting I did notice that the rear rotors said "Made in Italy" that they sent me. I did not take notice on the front ones.
carzzz - They probably will cut them, which will essentially speed up the warping again because you have less metal now to dissipate the heat. Expect them to be warped within less miles than the first time.
Take care. Be back soon.
Dealers: "Front rotors out of round disassemle and inspect brakes. Brakes slightly blue due to hard braking or riding brakes req's machining"
they said the resurfacing is not covered under warantee in my case... what a shame...
Also, just wondering how much you can turn on the steering wheel on the Quest? I could turn over 540 degree(more than 1.5 circle) to left from center position and but i could only turn exactly 540 degree to the right from center position(exactly 1.5 circle)...is this normal?
I had the "Service Engine Soon" light come on and the code was P0745 (Pressure control Solenoid). It turns out I had a loose wire. NO big deal.
Just to let you know that I experienced similar "problem" some time ago. Since nothing seemed to be wrong with the van except the SES light being on, I didn't take it to the dealer. For about 2 weeks I just tried to tighten the gas cap when I filled up. The light didn't go out after the first few attempts but finally did (perhaps 3-4 times of opening and retightening the cap). If nothing else seems to be wrong with your van, don't worry about SES light. Just fiddle with your gas cap when you fill up, perhaps to help it fit in better with the grooves, and the light should evntually go out.
Good luck,
Phuc
This is my first Nissan product but in all new vehicles that I've owned of other brands I've never once ever had to replace break pads before 50,000 and for that matter it's usually been much more than that. I live in a flat area, not mountains and I'm easy on the breaks.
According to warranty documentation break rotors and pads are not convered under warranty except for the first 12,000 miles unless it is a defect.
I would think needing break pads at 29.000 miles would be a defect? I'm told from the dealer this is normal for factory pads to last only 20 - 40 thousand miles?
Is this true for Nissan, break pads do not last as long as in other vehicles? What have been your experiences in this matter?
I'm thinking it is a defect in the system and this should be covered under warranty. I had to pay $350 to get the rotors turned and new pads which I'm going to ask Nissan to re-pay me under the terms of their warranty that it is a defect.
... Gary Cox - garycox@netten.net
I have other vehicles and have never replace brake pads at this mileage. Now I have to spend more than $500 to replace brake pads and resurface rotors. This is my first Nissan and will never buy any again. Wish would have bought Toyota or Honda. Let me know if you are are able to get paid by Nissan.
I have a 2004 SL and currently has 26k on it. The brakes just started to have this exact problem. I talked to the dealer and they say it will need turn the rotor without even checking it. How do I go about to make the dealer or Nissan fix this problem? I mean, does Nissan know this problem (well, they do, but the question is would they admit it?) The dealer obviously doesn't help, they even denied there is extended warranty for 2004 Quest. I almost order an aftermarket rotor thinking I will just fix this myself until I found this site and your post. Please help.
As a comparison, I just bought an '03 Honda Element for myself with 4 wheel discs with 33K miles, and the dealer had replaced the front pads before it went onto the lot. The driving style has LOTS to do with brake wear. If you have a vehicle with rear drum brakes, they will go a lot longer, but you usually don't get the same level of performance - notice that performance cars always have as big as disc brakes as possible. Sorry you're unhappy , but better performance usually takes a little more than average maintenance, but 25K miles on these brakes isn't bad.
"how the heck can you warp a rotor at 2000 miles on a new vehicle?"
This is what i was wondering about too. Because the rotors were not installed properly at the Mississippi Plant, they got overheated due to the "high spot". I found it's very irritating that the dealer said my driving habit caused this problem (2000 miles). My other cars were on original rotors at 70k+ and 80k+ miles. But oh well, they give me a new set!
I will keep my eyes on both the petal and steering! i will keep updating...
I know that when my wife adjusts the fan speed it goes off of the “Auto” mode and will stay that way when the van is re-started (annoying air in my face).
It sounds like in your situation the Auto mode is still on and puts the heat to the floor where it should go I think you need to turn off the Auto mode to have it “save” your setting.
I just leave it on Auto mode all the time unless I open all the windows/sunroof.
If you want the straight scoop on Quest brake problems go to brakeinfo.com click on common brake problems click on lateral runout. All you folks will see that your brake problems are not warped rotors as thought but lateral runout. This site explains the problem PERFECTLY. Again, how the heck could you warp a rotor on a new vehicle at 2000 miles? It's now warped, it,s lateral runout. Check it out.
In general I love the Quest, and the service dept. has been more than fair, but this whole experience has really soured me on Nissan in general.
All you folks with rotor problems please check out this website. It explains exactly what the problem is with your rotors. The spoonster
The Spoonster
that was an interesting article. it seems that the key to the rotor issue is to do the on vehicle machining as opposed to the bench mounted machining. I had my rotors machined back in April 2005 at about 8,000 miles. All has gone well since then. I'm at 37,700 miles now and have done more city driving the last 8 months. I think the rotors are starting to get thin and will need replacing soon.
My question is how do you insure that they install the rotors correctly to begin with? I don't want to have to worry about lateral runout in 2000 miles.
Would you like to save $10-15 everytime you fillup on gas? Everyone I've talked to who has used this fuel additive has saved 25% or more with every fillup. Also, it lowers emissions my more than 50% AND increases horsepower!
If you don't believe me, believe the facts at www.ahellerstedt.mybpbiz.comto see for yourself. Please send a message if you have questions.
I'll ask when I take it back in (they gave me no idea how long the parts would take to get here). Is there something specific I should be looking for?
