1997 Dodge Grand Caravan relays clicking but no lights, horn or ignition
I bought this car last week from a pvt. party and took it to mechanic for diagnostics. The can needed front brakes and also the power window(Driver side) was not working. He changed the power window motor. Everything was fine till yesterday, this morning the van won't start, as soon as I open the door the relay in the fuse block starts clicking. The instrument panel is not lighted, again when i try horn, one of the relay in fuse block started clicking. SAme thing when i used the power lock.
I tried to jump start the van but nothing happened. I am frustrated as I bought a used car and then paid 650 doolars in repair of window and brakes. PLEASE HELP ME.
if you have a maxi-fuse that keeps blowing, there is a serious short in some wiring. you can narrow it down by identifying which sub-systems the maxi-fuse protects, and pulling their fuses one at a time to see what allows you to stop replacing those two-dollar maxi-fuses.
the relays are on a smaller and separate control circuit... they switch the power circuits coming off whatever 12 volt bus is dead due to an open wire or a dead maxi-fuse.
if the owners' manual doesn't provide enough help in chasing it down, one of the $20 parts store manuals for your model car ought to. alternatively, if you are wrench-challenged enough to require a mechanic to replace light bulbs, telling a mechanic this much ought to cut the cost of diagnosing the issue quite a bit.
You may have a clockspring problem.
http://www.allpar.com/fix/clockspring.html
But we found out my relays were burnt. Maybe you should get them checked.
This may not apply to you though.
Same thing happen today when started, but there's an additional noise. I turned off engine but the starter (the belt) just keep running (chugging), and smelling pretty bad. I unscrew battery to make it stop, and a lot of smoke were coming out with very bad smell. The smoke came from between radiator and engine. Please help.. also, is this car ok to be driven to the mechanic ?? Thanks so much."
This could be a timing problem, an overheating problem, maybe a leaking injector along with a high-carbonization issue in the cylinders. It is certainly correctable, and I don't think it harms anything to drive to a shop.
Often you can stop the post ingition by flooring the gas pedal after you've shut the engine off, OR...just put the car in gear with the engine off.
No need to disconnect the battery.
