air conditioner recharge???????
I have a 1992 Madza Miata. The air conditioner isn't cooling like it did when I bought it a 1 1/2 years ago. I have 3 cans of R-12 (14 ounce cans) and the adaptor to put it into the system, but the adaptor does not have a pressure gauge on it.
What do I need to do to recharge my system???
Thanks, Joe
Thanks, Joe
there are federal laws now against working with R12 systems unless you have tested in and have freon recovery equipment. no venting into the atmosphere. that means no wild refilling is the rule of law, leaks need to be fixed.
it is most likely if you have a leak that you will be encouraged to convert to R134a by the shop... or by the price tag... after repairs are done and the system is evacuated and ready for a reload.
I've done this conversion (some time ago) and now it's much cheaper and more convenient for me to service my A/C, so it all works out eventually over the long run.
Don't try to fill it yourself. A face full of R12 can blind you.
for that matter, if you screw up and connect to the high side of a car system under operating pressure, the leakage stream can freeze and wreck your hand(s.) a turbine commercial cooling unit might not have the delta-pressure, but the amount of refrigerant that would get you negates the supposed advantage.
that's one reason you should always review a potential repair before digging in... lots of hazards and places for, uh, detrimental outcomes whenever you deal with a system using lots of energy. don't figure on duct tape holding chassis springs in place, use logging chain... and don't figure that escaping refrigerant is only pollution. it's also lifetime SSI disability payments for the unprepared. I'm finishing rehab of an old but grand ham radio that has beryllium oxide blocks insulating 1500 volts from the outside case... two suddenly-deadly hazards for the price of one... and fortunately for the "Darwin factor," they are identified and easily prepared for.
If you haven't waited too long internal dmage may be at minimum.
Conversions to R134a are always less successful as the 4F warmer outlet temperature is the equivalent of a 20% less effective AC system.
and with R134a systems having less power than R12 units, it takes a minute or so to get the evaporator cool again once the engine computer lets the a/c clutch back in again.
not the end of the world. and if you know how things work, you realize that it's not an a/c intermittent failure.
if this is news to any friendly readers out there, use a lighter foot or lock out overdrive and see if you get cooler on those nasty hot days. it just might work.
It is sometimes called a WOT cutout switch.
Worked great too!
shattered 'em, and we had to scrap the thing.
that's presumably in the training book for the EPA refrigeration test... don't do it.
